Question about Jacuzzi Bath Maxima EL61 959 White elongated two-piece high-performance toi
Need to increase bowl water level. how do I do that
The toilet is only about a year old. The water level in the bowl was ok at first. Now for some reason it barely fills the neck. I have to hold the handle down slightly to add more water to the bowl
  • 4 Answers
Step 1:
Remove the top lid of the tank, ...carefully, so as not to break the ceramic by dropping it on the floor accidentally. Inside exists a "lever" attached to a "float" acting as a "fulcrum," with the "float" resting on the level of the water in the tank. The more water in the tank, the more water will enter the bowl, at flushing time.
Step 2:
The level of water in the tank corresponds to the level of water entering the system upon flushing the commode (bathroom fixture). At the bottom of the tank exists a "flap" type of device (usually). As the water exits the tank into the bowl the flap seals off again, discontinuing the water's entry into the bowl. This should always seal off at the end of a "fllushing cycle." The more water in the tank at the beginning of the flush, the more will enter the bowl.
Step 3:
Therefore, raise the arm of the "lever" (sometimes it's a "vertical" post with an "adjustable float" on it; in what case one raises the float on the post, by depressing a "clip" like device on the float itself, sliding it up versus down) by bending the arm upward, ...carefully. The increased water in the "tank" by the above process should solve your problem. Be certain to note whether the "flap" closes prematurely (It shouldn't), adjusting the flap's "chain" (held up by the "handle" itself) should it close prematurely.
Step 4:
You may need to tighten the "nut" (fastener) on the "handle" inside the tank as the "chain/flap" may simply be closing prematurely, because it's "loose" (easily tightened by hand at times, versus with a small, adjustable wrench bought at a "hardware store" like "Ace Hardware").
Step 5:
The above items (one, versus several of them), should solve your problem.
Posted on Jan 19, 2013
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
Water level in bowl low
Turn knob on top of float ball to increase ball height which will increase water column. Up to 1" of overflow tube.
Nov 08, 2012 | American Standard Cadet 3 Right Height...
After installing a new flush valve, the water level in the toilet bowl seems to be much lower than it was with the old flush valve. Is there any adjustment for the water level in the toilet bowl?
Yes,there it is!You can adjust your water level at the flush valve..You can see the ball there you need to adjust that so that the water level of your tank goes to your desired level.
Jul 29, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
I just installed a new perfects. The pool of water in the bottom of the bowl is small, how do i increase the pool of water in the bottom of the bowl.
The toilet you just installed is a 1.6 gallon flush water saver and will not have the same amount of water in it that your old 3.5 gallon toilet had. The water level may not be able to be raised as this is the nature of the beast.
If you can raise the level it will only be a little and will be done in the tank area by increasing the water level in the tank. If the water level in the tank is at the mark provided it a done deal.
The amount of water refilled into the bowl is done by the tube that runs from the fill valve into the overflow tube of the flush valve so if you put more water into the tank more water will be put into the bowl but the bowl will only hold as much water as the trap weir will let it hold (what the factory has sit it at and is not changeable
Mar 07, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
My kohler toilet is only about 1 year old. no problems with the flush but the bowl only fills up with about half the amount of the normal water. I looked inside an all seems to be connected. Thanks
You might follow this link to see if you can adjust the water level:
http://www.acmehowto.com/howto/homemaintenance/plumbing/toilet/filllevel.php
Hope that helps.
Aug 21, 2010 | Kohler Home
The water will not refill! The inner plastic part doesn't work and it's only one year old! I must pour a bucket of water into the bowl to flush waste.
Does this tank have the plastic bucket around the flapper inside the tank. If so this is a water saver toilet. A few tricks to increase the water. I have had to remove the bucket by cutting it maybe half into to increase the gpm.
This will increase it to more than 1.6 gpm's. It can be cut down just be careful in doing it if this is the problem.
Next make surethe fill valve has line running and attached to overflow tube. This will fill the bowl with the needed water for it and the tank.
Next make sure the water is set to the mark either on the tank or the overflow tube. If no mark to within 5/8" to top of overflow tube .
Jun 27, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Increasing water in bowl
You really can't because of the design. Any water above the level now will drain off. Sorry
Nov 04, 2009 | Toto Toilet Onepiece Neorest 600 ...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Not enough water in the bowl
The fill valve probably has a float that surrounds the pole that extends from the bottom of the tank. The float usually has a metal rod that comes down with a clip to adjust the float. Move that clip up so that the float sits higher-this should add more water to the tank.
Jun 26, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Jacuzzi Bath Maxima EL61 959 White elongated two-piece high-performance toi Logo
173 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
