Question about Arrow Tools & Hardware - Others
Ebn 160 arrow nail gun
I only used once for a trim project and the nail jam in the unit . Any tinps ?
sbg_ofp
  • 10 Answers
SOURCE: rapesco pro 140EL nail gun repair/ manual sought
Perhaps [url=http://www.tacwise.com/tools/view_prod.asp?code=21&back=2&type=1]This Link[/url] will get you going in the proper direction. It's not a schematic but it is the Tacwise homepage, hopefully they can be helpful to you.
Posted on Nov 05, 2008
jj505
  • 195 Answers
SOURCE: Arrow ET200 Electric Nail Gun
This is a known recall due to electrical solinoind malfunction,be sure to return before 90 days.
Please rate. Thank you. jj505
Posted on Mar 30, 2009
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
SOURCE: Arrow ET200 nail gun only put nails in 1/8 of inch.
I solved the problem. I took the nailer outside and plugged it into the outlet on my electrical post. It worked perfectly. I was not getting enough power from the outlet I was using in the house.
Posted on Jul 24, 2009
SOURCE: my nail gun jammed up in the loading mechanism
how do I stop the gun from shooting two nails at a time
Posted on Jul 30, 2009
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
The gun will fire the first time but will jam when i try to fire it again.
Assuming that the gun will not jam with nails removed and the driver returns to top of cylinder when fired without nails. If the driver is bent the nailer will jam without nails. Jamming is usualy caused by bent driver, driver tip worn (not square), or wrong nails. If the driver is not bent and the tip is square, suspect wrong nails. Easy test. Place a strip of nails on outside of rails with the nail heads aligned with top of rail. Move the strip of nails toward the nose if gun. With the heads aligned with the top of the rail, the first nail should align with the path of the driver. If the first nail does not align with the path of the driver and the head is angled slightly away from the path of the driver, the driver may strike the shaft of the first nail pushing the nails back into the rails. If the head of the first nail is forward with the nail shaft angled back away, the nail will flip causing jam. The first nail should align with the path of the driver to prevent jam. It is difficult to find perfectly made nails that align correctly. But certainly check the nails with test mentioned above with every new box for accuracy. You might find that you will need to change brands to get a good fit. Good luck.
Nov 06, 2012 | Air Tools & Compressors
Ridgid coilnail gun jams and safty jams in place and gun will not fire. also somtimes will jam
if safety is jamming, its either bent or the pin that keeps it in place is missing/broken, you can find the pin right in front of the trigger. now as far as the nails jamming could be a few things. 1. wrong nails 2.right nail but may have gotten a defective batch 3. bucket that holds nails is adjusted to wrong size. 4.nails have been dropped/ squished and coil is not round anymore 5. nose is very worn and two nails are trying to come out at a time 6. driver is worn/broken and is trying to push out two nails at one time
Sep 18, 2012 | Ridgid Air Tools & Compressors
My ridgid r213bna nail gun won't fire a nail, but has good pressure & no jam...
If a gun is firing and nails are not being driven into the work it's because of one of two problems. The nails aren't feeding fully under the driver or the driver isn't fully retracting each time the gun is activated. Is looks like you've eliminated a feed problem so you are going to have to take the gun apart to find out why air is not being held in the bottom of the head long enough to push the driver back up the cylinder. Go to www.ereplacementparts.com and bring up your model so you can follow along. Remove the four screws holding the head cap on. The things that can cause your problem are: the piston seal & o-rnig are damaged, the cylinder is badly scored, the o-ring & cylinder ring on the bottom half ot the cylinder are damaged or out of place, or the driver guide under the bumper is broke or missing. If it turns out internal parts are damaged or missing, I highly recommend the overhaul kit to replace all the 'soft' parts inside the gun as long as you have it apart.
Jul 22, 2012 | Nailers Ridgid Finish Brad Nailer R213bna...
My Hitachi nv65ah nail gun won't set nails into 3/4 trim. I have played with the turn/screw set adjustment and it is set for the deepest setting. This gun was purchased second hand off e-bay but
If every nail is stopping at the exact same height, a likely reason is the tip of the driver is broken off so it's not long enought to drive the nails all the way to flush. If the height of the nails is slightly different you may have worn or broken o-ring(s) inside the gun and air is leaking around the driver's piston or elsewhere in the gun so that the driver isn't getting full pressure. You can take the gun apart and inspect the o-rings. If you push the driver all the way down the tip should come flush or slightly past the end of the nose piece (not the safety tip). Parts are easy to find online or at a service center if you have one nearby.
Mar 10, 2012 | Hitachi NV65AH 212Inch Coil Siding Nailer
NR90AE Nails jammed how to remove
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
Nov 14, 2011 | Hitachi NR90AE Full Round Head Framing...
Jammed nail gun fc350a
Nail guns will jam when driving nails thru very hard wood, solid objects, allowing the gun to double fire hitting the first nail or using the wrong nails(amoung some of the reasons, you get the idea that jamming is common) . There is no special tool to help in case of jam. You must be creative. I use an old driver shaft from nailer that easily fits into the nose of the gun (you can grind a piece of allen wrench to fit into nose and allow space for the stuck nail). The metel that you use must be very hard and strike with heavy copper or brass hammer (caution, steel hammer may splinter metal, use protective gear ). You will need to strike very hard to remove some stuck nails. If first or second strike results in no movement of driver, remove the head and cylinder of the nailer and place the body of the gun squarely on piece of plywood over concete floor (this will protect the head of the nailer from being damaged). Worst case, you will need to remove the rails. Good luck.
Jun 25, 2011 | Porter Cable Factory-Reconditioned...
How do I load nails into the 5700
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
May 20, 2011 | Garden
Nail Gun support
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Delicate problem
Aug 27, 2008 | Arrow No. ET100 Electric Heavy Duty Nail...
Tools & Hardware - Others Logo
114 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
