Humidifiers
Problem for Humidifiers
Generic problem for all Humidifiers
HE220A1019 Whole House Humidifier
By craig859 on Jan 26, 2009
Were you referring to the furnace blower turning the wrong way.. I assumed you were talking about the humidifier blower... the furnace is new and working fine, it is an up-flow. The humidifier is not a bypass type, it just has a fan inside which is pulling air into itself... I was assuming it would push air through the filter and into the hot air plenum. I have it installed just above the furnace and the humidistat on the return air side. hope this gets on the same page if there was a misunderstanding. thanks for your time...
Solution #1
posted on Mar 29, 2009
Not Rated)
hvac teacher
Rank: Guru
Rating: 91%, 51 votes
The humidifier is designed to "pull" the air through the water panel. After it does the humidified air will re-enter the plenum on the side of the opening that it is pulling in from. Just keep the water panel replaced every year and you will be fine.
Was this helpful?
Yes
No
Popular Solutions for Humidifiers
Questions and Unsolved Problems for Humidifiers
Answer
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find... (More)
Answer
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of... (More)
Answer
I Opened uo the slant fin gf 200 humitifier and ia=saw corrosion in it what do I do
Answer
My 1042 L General humidifier is not putting moisture in the air eventhough water is getting to the... (More)
Answer
what do i do with the demineralization cartridges
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Humidifiers:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2543
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
