The Verizon set box for TV makes loud noise
It's like maybe the fan is running but very distracting can hear in next room this noise on set top box. This is a new Verizon box I get today.
SOURCE: TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Posted on Mar 03, 2011
  • 87 Answers
SOURCE: Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Posted on Nov 08, 2007
SOURCE: Plazma TV buzzing noise
The transformer is resonating. Get it replaced, Don't do it yourself.
Posted on Sep 27, 2008
  • 2318 Answers
SOURCE: Hissing.
If the hissing noise is from the LCD, it could be from the power supply due to failing capacitors. This noise is generated when the TV is trying to compensate for the lack of voltage/curent requirements.
Posted on Nov 04, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
My Verizon HD &DVR Set top box has a noisey fan running loud
The only thing I can suggest here is ask Verizon to replace and tell them why. If that is not an option move the box to a cooler location where the fan won't kick into high for cooling.
Jan 19, 2013 | Televison & Video
Loud knocking/banging inside dash/glovebox
We had the same issue on our 2009 Flex. The problem was the motor or the gate (I can't remember which) that switches where the air comes out for the climate control. Took it to the dealer and had it replaced under warranty. It didn't take long (maybe 30min - 1hr).
It seemed like the system had a built-in fail safe that shut the motor down after a few seconds when the gate didn't make it to the desired selection. If you change the blower around when the fan is running (e.g. switch from floor to bi to dash to defrost), you'll probably hear the thumping come back as the gate tries to move, but can't.
May 24, 2012 | 2009 Ford Flex
There is a loud vibration noise whenever the compressor is running. Everything, including the coils on the back of the box vibrates so loudly that it can be heard in the next room. The compressor appears...
Is the evaporator coils froze up? Sounds like maybe the compressor is getting liquid back to the compressor or the compressor is running real high head pressure. Also check and see if the compressor is mounted on springs or pads.. Make sure all of the refrigeration lines are not bent and causeing vibriation.
Dec 19, 2010 | Kenmore Refrigerators
I know it is normal for the console to be making a
is there plenty of room around console so it can get plenty of air through the fans,it sounds like it overheating and emight get 2 red lights,placing it on a hard surface with aboput a foot gap all around should sort it.hope this helps
Apr 06, 2010 | Microsoft Xbox 360 Console
Revolver 'Rebel' Turntable extended leads Rotel RA 50 Amp - hum
could try fitting a serpresser as like cars do
also try a farraday loop which means put a few loops in your lead
Sep 07, 2009 | Audio Players & Recorders
Seems to be a noisy fan on mb4210 combo
Could very well be the fan. The motors can cause interference. There may be a solution to get rid of the noise. Some copper shielding tape may help. You could rule out it being a microphonic preamp tube by turning the amp on as normal and tapping the tubes with something non-conductive. If you hear the tapping noise coming thru the speakers while doing this to a particular tube, replace it. With power tubes, the tops of them turn white on the top when they become microphonic, along with plenty background noise.
Apr 18, 2009 | Marshall Music
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Samsung DLP HDTV wide screen
Sounds like the colorwheel (used in DLP projection sets with a single DLP panel) is going bad, either the wheel itself or the bearings on the motor driving the wheel are starting to fail. I would recommend getting a professional to service the TV set.
Jan 11, 2008 | Televison & Video
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
562 people viewed this question
Top Televison & Video Experts
Electro Med Services...
