My Aspire 5670 screen is dead.
With the external monitor (in VGA mode) there are some vertical pink blinking lines http://prntscr.com/ppmmv . Any solution? With the external monitor (in VGA mode) there are some vertical pink blinking lines. Any solution?
    Problem Solver:
  • 10 Answers
Update the video drives, if that doesn't work replace the vga cable. If that doesn't work try it on another monitor.
Posted on Jan 20, 2013
Pink lines running across screen
Sounds like your lcd screen is bad and needs to be replaced. Try connecting an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without the lines, then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same lines as your lcd screen then your video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 07, 2012 | Computers & Internet
Broken vertical lines acer aspire 5670 laptop and
This is usually the actual screen driving transistors packing up, real common. replace the screen, if cheap enough, often though they are more than a new machine.
Feb 23, 2010 | Acer Aspire 5670 Notebook
How to remove pink line on my lenovo
Is it a pink line down the screen vertical or horizontal. Most likely it is a screen problem and you will need to replace the screen. Check the repair directory on FixYa.com for a reputable laptop service to take care of the problem if you are not comfortable replacing the screen yourself.
Aug 02, 2009 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
How to connect my Acer Aspire 5670 outgoing to my TV? I have an SV cable and I believe there is an sv output plug for it. I'm not very technical.
You laptop can connect to any television or display device with S-video input through the S-video/TV-out (NTSC/PAL) port, located on the right side of the laptop (this is the round whitish port located between the two USB ports and the ventilation slots.
The computer has also an external display (VGA) port by which the laptop can be connected to a display device (e.g., external monitor, LCD projector).This is the port on the right side nearest the end of the computer.
Jul 27, 2009 | Acer Aspire 5670 Notebook
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
My screen of my laptop acer aspire 5670 is smaller
3 possible solutions
1. There is a monitor mode to display correctly when connected to a larger monitor, look at the top line of keys on your keyboard for a key with 2 monitors on it. You usually need to press the FN (Function key, bottom left) hold it down then press the monitor at the top
2. Your display drivers are incorrect see http://www.howtofixanything.co.uk/howto-52.html to update your video driver
3. Try starting Internet Explorer and click Tools (At the top) --> Windows Update
See if any updated Video Drivers are available
If you cannot see tools at the top in the menu bar pres the <alt> key once
Jan 13, 2009 | Acer Aspire 5670 Notebook
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
Computers & Internet Logo
David Payne
David Payne
