Question about IBM ThinkPad A31 Notebook
IBM A31 2652 Video garbled video at boot
IBM Laptop A31 2652 Garbled video even at initial... var g_tryMail = 0; function addthschng() { if($i('at_email') != null) { addthis_sendto('email'); } else { g_tryMail++; if(g_tryMail Report abuse posted by macerq on Jan 25, 2009
Hi my laptop has garbled video: different colored speckles around screen in a repeating patten (varies somewhat each time I resart it) also gets vertical red lines all across screen.
The red lines can vary when I press down firmly in left far corner of NB base, vicinity of F1 key
Sometimes will have normal video after restarting several attempts
Help please thanks macerq@yahoo.com
  • M Cerqueira Jan 27, 2009
    It's not a windows driver issue because it is fouled up even before windows logo screeen.
    Is it possible to repair the LCD?
    Thanks
    Genius:
  • IBM Master
  • 1,102 Answers
Update monitor driver
your screen may be going
how old is the system
Posted on Jan 26, 2009
  • DEKR
    DEKR Jan 27, 2009
    If you updated driver it's either video card problem or the screan
    If you take it to small pc repair shop they'll test the video card for you and the cost when be near as much as a major pc outlet.
    Some smaller repair stores will test the card at no cost on the spot
    and yes it is possible to replace the screen but sometimes its costly unless you can get a used one.
    I am guessing its a video card problem.
Does not boot and monitor garbled
I believe this is happening cause the ram memory is either damaged or not well inserted in slots.. Open the ram memory compartment and remove them all and insert them back one by one and try to boot up with which one at the time .. This way you will see if any of them is damaged cause will do the same or will not boot at all ..
let me know what you've managed to do ..and how it behaved after checking the ram memory ..
Dec 04, 2011 | IBM ThinkPad A31 Notebook
When I turn on the power on my thinkpad the picture on the monitor is garbled and it's almost near impossible to get it ungarbled. It does it right when it starts up
connect an external monitor and check how is the display,if the display is fine on external monitor,then it would be your
LCD OR VIDEO CONNECTION OR CABLE NEED TO CHECK .
If you are getting the garbled picture on the external monitor also it could be
SHARED MEMORY AT FAULT( If the laptop uses shared video memory (part of the main memory is used for the video purposes), it's possible that you have a faulty RAM stick.)
OR
VIDEO CARD (if the video card is discrete replace take out that and check the video with integrated video card and if the video card is integrated then you have to replace the mother board)
Sep 17, 2010 | IBM ThinkPad A31 Notebook
Error "Setup didn't find HDD"
Well, first of all XP is not the latest supported operating system from Microsoft.
That being said, I have not had a garbled screen followed by an error message 'setup didn't find any hard disk drive installed' on a laptop, in my limited experience with laptops (i.e. Acer One, Acer Aspire, Sony Vaio, etc.)
If you have an unexpected garbled screen it points to the pc board or mother board or the video card, but more likely the motherboard.
And, if you couple this with the hard disk drive not being detected, it reminds me of a situation where I had a no hard disk drive detected on a SCSI drive connected to my Windows 95 computer in the 1990s when I had heat related issues with the circuitry on the hard drive getting burnt out capacitors.
If the drive is not recognized, it might mean the boot sector is wiped, and essentially it needs to be reformatted and the operating system needs to be reinstalled (which you evidently tried to do).
To my memory, I never had this problem on Windows XP with a laptop, so I am thinking it's not Windows that is at fault, but the physical hardware is giving you problems.
If you boot from the CD for Windows XP and it doesn't find the drive, it's a big problem for this laptop.
I wish you luck in finding an answer to that one, seeing that it's out of warranty and XP is no longer supported by Microsoft.com.
Jul 19, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Screen flickers and get blurry
It appears that your inverter may be failing, especially if there is a garbled picture and red tint upon initial boot. Buy a new or used inverter on ebay and swap it out yourself.
Mar 08, 2010 | IBM ThinkPad T42 Notebook
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
IBM Laptop A31 2652 Garbled video even at initial boot screen
Connect an external monitor to the laptop, power up the monitor first and then bootup the laptop. The Windows image will automatically divert to the external monitor.
If the images is OK then the video card is OK.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Get back to me if you still have problems together with any error messages etc.
Jan 25, 2009 | HP Compaq Presario F750US
BSoD, Garbled Screen, Boot Failure.
If you are getting garbage on the screen before windows tries to load the laptop probably has a bad motherboard.
It's possibly only the video output is going bad on it, try hooking it to an external monitor and see if you get the same weird stuff on that screen.
Good luck, let me know how it goes
Nov 15, 2007 | Compaq Presario X1000 Notebook
IBM ThinkPad A31 Notebook Logo
289 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Michael Vincent Cruz
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
