Question about Garden
What will cause the brakes to lock on a toro zero turn mower
When you engage the hand controls it dies, the brakes are locked
  • 30 Answers
Are the brakes locked or is the safety switch on the brake lever faulty? the model of the machine would also help.
Posted on Jan 27, 2013
SOURCE: My cub cadet zero turn mower won't engage the
I have a cub cadet zero turn 50' mower, i start mowing and after about 10 minutes it starts running out of gas, i pull out the choke to keep it going but it just keeps getting worse to the point of quitting. If i slow it down to a idle or just a little more it will stay running but that is not fast enough to cut the grass. does anybody out there know why i am runnung out of gas. I put a new filter on it, It did not help.
Posted on Jun 20, 2009
  • 77 Answers
SOURCE: My Toro Lawn Mower Model 20016 no longer moves
Your transmission is bad,need to have one ordered.
Posted on Aug 12, 2009
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
  • 4340 Answers
SOURCE: i have a 19 hp kohler courage on my toro zero turn
This sounds like the carb is plugged. Sometimes fuel thickens and makes globs...
If you verified the fuel flow to the inlet of the carb, then you need to take the carb off and open it up....
So, what needs to happen is you blow out all of the passageways with carb cleaner.
Any adjustable jets: make note of the position it is in, and FINGER TIGHT turn it clockwise until it closes (typically 1 to 1 1/2 turns) SOOOOO, you can set this jet back to the same positon....when finished blowing everything out, bottom the jet and back out the number of turns out, noted for that jet.
Open the float chamber, and clean as necessary, Inspect the float adjustment: invert the carb, and observe the angle of the float, relative to the carb body.... Usually almost parallel, but not necessarily.
Inspect the inlet valve, and clean those areas...
I usually use all new gaskets and valves, but if you are not a carb person, cleaning is effective and I think old gaskets may be okay, if not torn or damaged.
Posted on Mar 11, 2011
2strokeJim
  • 577 Answers
SOURCE: I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Posted on Aug 01, 2011
When you move control arms to engage transmission the engine dies. the brake is not engaged but it is acting like brake is engaged.
rear end is locked up,put it in neutral and try it,if it doesnt work,then your rear end is frozen,undo your drive belt and try to move by hand
Jun 08, 2015 | Garden
Toro zero turn starts fine and stalls as soon as I disengage brake
Sounds like the seat switch is not reading you are in the seat. Without a wiring diagram, it is difficult to say exactly.
May 30, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
My toro 3200 seems like the transmission is locked
check the brake make sure its disengaged
if it wasnt moved in awhile brake can stick
Feb 07, 2015 | Toro Mowers - Time Cutter SS3200 32""...
Engine locked up while changing the blade and mower leaned over carb side was up it will not move either direction
blade brake is engaged unhook it and try turning the blade by hand should work
Aug 14, 2014 | Toro Garden
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
Jul 24, 2014 | Toro TimeCutter SS4260 - 22HP 42 Zero Turn...
TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Aug 23, 2009 | Garden
Toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Jim
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
