Question about HP Compaq nc4400 Notebook
Laptop charger plugged in but it wont go on - HP Compaq nc4400 Notebook
  • HP Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Jan 20, 2013
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Laptop wont charge. light does not come on
It is most likely a bad battery. Also, if you can find another charger like the one you have you could check to see if the charger itself is the problem. In my experience, the battery is the likely culprit.
Sep 27, 2012 | Samsung Rv-511-a01 Notebook
My advent laptop wont power up
The only way to check the charger which it looks like is
a) When you plug in the charger to the laptop are there any lights that come on anywhere on the laptop ( if so its not the charger )
b) Plug in an external monitor to rule out the screen ?
Apr 19, 2012 | Computers & Internet
Wont charge
The DC plug in the laptop is worn/charger plug, or the DC jack in the laptop is breaking away from the motherboard.
Mar 19, 2012 | ASUS Eee PC 1000 Notebook
Laptop wont start at all. plug in to power supply and battery charging light comes on.still wont start up...
try diconnecting the charger and holding down the power up button for longer, then try plugging in charger- turn on charger at wall then hold down power on button till power button on key lights up, i hope this helps you out ;)
Feb 07, 2011 | Computers & Internet
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Dead laptop
hi guys...can you try to remove the battery then plug the AC/Charger then see what happen..only charger no battery pack in Laptop...
thanks
Apr 05, 2009 | Acer Aspire 5920-6335 Laptop
Computer wont charge. Plugged up and still wont charge. Is it internal, battery or charger?
I'm not asking if the computer will charge, I'm asking if when you have it plugged in does the computer operate normally. You should be able to take the battery out of a laptop and plug in the computer in and the computer should still operate.
Nov 07, 2008 | Computers & Internet
HP Compaq nc4400 Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
