Question about Mitsubishi Televison & Video
I'm looking for a bulb for a 7302t60 Mitsubishi tv
I am looking for a bulb that goes in the front of a Mitsubishi 1080p subframe tv. The sku is 7302t60
2 Suggested Answers
pimptwzt
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Posted on Dec 24, 2012
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
My tv want come on at all but it was working fine this morning
Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV
amazon.com/dp/B004ZL2O9U/?tag=80e1-20
Amazon.com, Inc.Amazon.com: Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV (2011 Model): Electronics. ... The Federal Trade Commission (FTC) wants you to know that the ... It is in fact much brighter than my 82" set which also has a 180 watt lamp. ... any lightcoming in; it will cause rather bothersome reflections off the TV screen.
Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV ...
Dec 26, 2015 | Mitsubishi WD-92840 92-Inch 1080p 3D...
I have an 82" Mitsubishi DLP tv. I have replaced the lamps 3 times and just replaced the ballast. I am still getting 6 red blinks and 1 yellow
I hate being the bearer of bad news, had the same problem, and I found out that the problem with DLP is that after so long, nothing that you do will fix it. A TV repairman offered me $100 for my set and I took it, that was 2 years ago and it still goes through bulbs and ballast several times a year. Now when i see him he always says I never should have taken that TV. It never plays long enough to sell it.
On a liter note: 4k si approaching $1000 now, that's the way to go.
Nov 26, 2014 | Mitsubishi Cinema WD-82740 82-inch 1080p...
How do we set the picture to 1080 megapixels from 480i?
U can't just do it on ur own setting like 480i to 1080p when ever u want.No,u only get what ever the tv stations modes they set and send out only.Ur tv have the 1080p mode capability mean ur tv can pickup that 1080p mode.Dosen't mean u can change 480i to 1080p by ur self anytime u want,if the tv station is broadcating tv signal to u only in 480i u get only 480i.
Jun 23, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Where does the bulb go in?
the bulb goes in the front of the tv.remove the lower front panel and look to the left side you should see the door for the lamp.
Feb 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
Direct TV setup indicates my TV is not 1080P but
the only input on the Mitsubishi that is 1080p capable is the rf input.
Sep 19, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Steering Rack boot replacement
In my opinion, removing the front subframe makes this job much easier.
Jack up and suitably support the front of the car so it is in a wheels free state.
With wheels removed;
  • Remove the anti-roll bar drop links from the anti-roll bar
  • Free off the lower arm ball joints off
  • Remove the track rod ends from the swivel hubs
  • Remove the nut and bolt and special clip on the lower steering column universal joint
  • loosen off and disconnect the feed and return pipes to the power ram (beware stinking power steering fluid pouring everywhere!)
Steering and suspension wise, the subframe should be free!
  • Remove the nut and bolt that secures the lower engine mounting to its bracket (the bolt that goes through the big round rubber mount at the back of the engine)
  • Disconnect all relevant gear linkage rods (this will be clear when you are under there!)
  • Support the subframe with a jack or somesuch and free off the 6, 18mm bolts that secure the subframe to the body shell.
  • remove all subframe mounting bolts.
  • lower the jack that is supporting the subframe, it should all drop quite nicely and then get stuck on the steering column universal joint! A good old college shove frees this and then you should be able to remove your subframe assembly from under the car.
Jul 30, 2009 | 1997 Mitsubishi Diamante
How do you get to the bulb on a Mitsubishi 1080p model wd-52628?
look to the right side of tv front remove the 2 screws watch how the filter comes off to replace back look for 3 screws on the lamp remove them and pull the lamp out replace is opposite of removal
Apr 01, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Televison & Video Logo
306 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
