Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
My Williams wall heater model 25-35-50 pilot light will not stay lit. I know how to light the heater. I just will not syat lit. Even after holding the pilot in for three minutes. What is the problem?
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
  • 2976 Answers
SOURCE: williams wall heater
It can be shut off, but do not just blow it out.
Posted on Mar 04, 2009
SOURCE: Williams 3003622 Wall Mounted Panel Heater Draft Blows Pilot Out.
yes. open cover, set to pilot and push in then light with a long nosed butane lighter like the ones used for lighting stoves. Hold pilot in for a few minutes, then close pilot cover and turn pilot knob to on position. that should take care of it unless you need a new coupler. good luck as the couplers go out on these heaters prematurely.
Posted on Mar 10, 2009
koolbreezes
  • 540 Answers
SOURCE: williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Posted on Dec 22, 2009
  • 2597 Answers
SOURCE: Pilot wont' stay lit
try clean pilot ..... replace thermocouple on heater
Posted on Dec 30, 2009
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
How do i light the pilot?
Turn the Gas Control Knob inside the heater compartment from OFF to PILOT. Push in the knob and hold it, at the sametime push the ignitor button (will probably be a Red button). Once the pilot lights, continue to hold the Control Knob down for one minute. Then ease off of it. If the pilot stays lit, turn the Control Knob to the ON position. The burner should light, if the Thermostat is set higher than the ambient temperature in the house. If the Ignitor button doesn't work, you can match light the pilot. Just be careful and follow the instructions above, once it's lit.
Hope this helps solve your problem.
Feb 23, 2011 | Williams (5009622) Ceramic Gas Wall...
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Nov 11, 2010 | Williams 6508732 Gas Heater
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
Williams debonair wall heater + pilot light problems
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Need to turn on pilot light of Williams 3003622 serial # 400518D
Find the gas valve and turn it to pilot. (Or light) Use a long reach lighter. Light the lighter and press the knob in. Light the pilot and continue to hold the knob in for about 15 seconds. When you release it, the pilot should stay lit. If it doesn't, you need a new thermocouple. That's the small tube that the flame touches when the pilot's lit. They're inexpensive and usually not too hard to replace.
Jan 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
189 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
