Question about Pool & Spa
Spa heater leaking - Pool & Spa
  • 1,631 Answers
What make, model, and where?
Posted on Jan 22, 2013
  • 4 more comments
  • scott mcdonald Jan 23, 2013
    Marquis, Destiny (2007 roughly). It was leaking from the connectiors to the heater,. which in turn soaked the pump and tripped the breaker. I replaced the heater 2 winters ago and it was working fine, however we last used it in the fall and I have no idea when it stopped working.
  • Mike Tellegen Jan 23, 2013
    Is it leaking at the union connections? If so, replace the 2" o-rings with ribbed gaskets. These are preffereed over the o-rings. If it is leaking thru the electrode of the element itself, you can just replace the element with either 4.0, 4.5, 5.5 or 6.0 KW style. They also come in either regular or coated.
  • scott mcdonald Jan 24, 2013
    Yes it is leaking from the union connections and is using the white o rings. Where is a good source for the gaskets?
  • Mike Tellegen Jan 24, 2013
    Contact psmsvc@gmail and the person that replies can assist you. Tell her Mike referred. . You need 2" ribbed gaskets.
    Thanks Mike!
  • scott mcdonald Feb 02, 2013
    I'm back...I got the gaskets as recommended, installed them and began to fill...the nuts are tight and it is still leaking from both sides.Suggestions?
How do I fix a water leak in my hot tub or spa
That's a tough question to answer without more details. The majority of leaks occur in the equipment area of the spa. IE: where the control pac, pumps and heater are located. There should be one side of the spa with a removable panel to access this area. Take a flashlight and look in that area. Look at all the connections where the hoses attach to the pumps and heater. These connections will have gaskets or o rings to create a seal. They where out over time. Look at the connections with the pumps on and with them off. If you don't see a leak in that area you may have to call in a technician to find it. This ca be difficult depending on the make of the spa. Good luck
Sep 07, 2017 | Pool & Spa
Hot tub leaks, not from pump or heater.
Most leaking plumbing issues from a spa are to in depth for a home owner to pay for the repair. Use MARLIG FIX A LEAK and this will fix almost any small-medium leak.
Sep 06, 2010 | Pool & Spa
Hayward Model H250IDL is leaking water from drain valve.
Water leaking from the heater is not a good sign. This is an indication of a leaking heat exhanger. The heat exchanger will have to be replaced and the part is made of copper. It is very expensive, depending on the age, you may just want to replace the entire heater. Exchangers usually leak due to bad water chemistry.
May 09, 2010 | Hayward H Series Pool & Spa Heater 400k...
Heater leaking at manifold
1. Check o-rings at connections and replace if required. 2. Check header for cracks. 3. Remove heat exchanger and check for leaks. Replace parts as required.
Apr 19, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Feb 21, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heater leaking water
The manual is on Pentair's site. If you are leaking water at the plastic conections you might be able to tighten them down a little. Don't go crazy they are only plastic. There are orings in there and may need to be replaced
Nov 10, 2008 | Pentair Mastertemp Pool & Spa Heater Dual...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
