Question about Kitchen Ranges
Hi, I had a fire in my apartment a few weeks ago when I was not home. The fire department broke in and determined the heat source to be the electric stove. The stove came on and burnt some material that was resting above it on a counter. The strange thing is, I had never used the stove and the fire department confirmed that none of the knobs were turned to the on position. Just before the fire started, my neighbor flipped the breakers because his stove was not working; shortly after he did this, he saw smoke coming from my apartment and called 911. Has anyone ever heard of an electic stove coming on after flipping the breaker and without actually turning it on?
  • Julie Jan 20, 2013
    Perhaps it's the case that the stove didn't actually turn on, but emitted sparks after the breaker was flipped? I suppose that is more plausible. It's just so hard to figure out since no one was there to witness it.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
That's a new one on me!
Posted on Jan 19, 2013
  • 1314 Answers
SOURCE: oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Posted on Jan 24, 2008
daddy1264
  • 76 Answers
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Posted on Jan 01, 2009
garing
  • 998 Answers
SOURCE: our frigidaire oven (model #FEF-366-CCC) shut off
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Posted on Aug 22, 2009
  • 42 Answers
SOURCE: I have a GE jbp24 free standing electric stove. I
sounds like something has burnt out on your clock/programmer.
Posted on Sep 30, 2009
  • 215 Answers
SOURCE: Kitchenaid electric stove - knob doesn't want to
Sounds if the wires that connect to the knob is touching some metal, turn off the breaker, and remove the panel, you will find that something is touching, and it will have a burnt spot where it is touching. It may be two wires or the connector, touching, this is what is tripping the breaker, or the control knob itself may be bad and need replacing.
Posted on Feb 01, 2010
What could cause lost voltage in house lights?
its a dimmer switch which reduces voltage to make lights dim -and test switch with a meter and wiring with a meter breaker may trip because to much wattage for switch
Aug 30, 2016 | Electrical Supplies
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
My son spilled a drink on his laptop (yesterday) and now it wont turn on at all. do you think it will dry out? we only bought it a few weeks ago and it was expensive!
Hi
Thank you for your query
Unfortunatley it is one of these issues where you will have to wait, I would try to place the laptop near a warm heat source (please note this is done at your own risk in the sense that it is NOT to be put near a gas fire or any other appliance where it can catch fire), to dry up and then you can retry
If alot of drink was spilt then it will probably have seeped pass the keyboard down into the internals
If it is only a few weeks old did you purchase some sort of accidental cover? as you may be able to get it exchanged, to be honest it may be worth trying to exchange it anyway as it is only a few weeks old the manager of the store may allow it
I hope this has been useful
Mar 08, 2010 | Acer Computers & Internet
Is it 120 02 240
There should be a label that tells you that. Most home dryers are 120
Mar 05, 2010 | Samsung DV328AE Electric Dryer
Heats when unit is not on
Same thing just happened to my DEGX1. I took it apart and one of the heating elements had broken and fell to the bottom of the metal case. I think it was creating a short to ground and making it heat. I removed the broken element wires and attached them back best I could and did a test run with no problems. It is not heating when off now either. searspartsdirect.com had the elements for $67 so I ordered a set and will replace both of them (part #395583). My dryer is only 4 years old and 3 weeks ago the driver belt broke. Irritating they can't make them last any longer these days.
Jan 22, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
