Question about Samsung PL120 Digital Camera
My Samsung PL120 won't take a picture -
The button simply won't click to take a picture. Sometimes it will work, most times it won't. I had the camera for a year and it was working fine, then all of a sudden this problem started to happen.
    Genius:
  • Samsung Master
  • 1,019 Answers
The switch assembly is not making contact, needs to be repaired.
Posted on Jan 25, 2013
mail2pvs
  • 390 Answers
SOURCE: camera over-exposes all pics, and the =/- button does not work.
hi
the Exposure button will generally be disabled in auto mode
try changing it to 'P' (Program) mode and then change the exposure by pressing the +/- button and then you would generally see a scale on the LCD now press the left button to decrease the exposure
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and otehr settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
Posted on Jul 05, 2009
  • 11967 Answers
SOURCE: Samsung L313 camera - lense is not retracting when off &...
You could return it (recommended) or try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 07, 2010
SOURCE: Camera was working fine, but suddenly battery life is short
dang I thought it was just me. I put so many brand new batteries in the camera,all kinds, no matter what it completely dead in about 2 minutes.. its frustrating b/c I got the camera last year as a xmas gift, so I really thought I was just an idiot when it came to operating the camera.. glad to know its just a crappy product; I still don't have a resolution though... sorry
Posted on Jan 10, 2010
SOURCE: My Samsung PL50 camera suddenly has two white
I dn't know either... I got it for my birthday... n the same thing happens to me... if it was LG, they would have had a courier service pick it up and return it to me fixed... Samsung is ridiculous... There should be a recall on this camera...
Posted on Nov 26, 2010
  • 11967 Answers
SOURCE: I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Posted on Aug 20, 2011
I lost my samsung pl120 installation CD. My new system doesn't recognize my camera. How to get the basic software ?
Do you really need the Samsung software?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Mar 31, 2014 | Samsung PL120 Digital Camera
Shutter clicks ever time I press a button & it won't take pictures
I had this problem this afternoon, and it resolved itself when I took the memory card out. It's been fine so far, all working as normal again! :)
Apr 16, 2012 | Pentax Kr Digital Camera
My samsung pl120 won't turn on
You need to get fresh batteries in hope it will power on.
Mar 19, 2012 | Samsung PL120 Digital Camera
How to use samsung pl120 as webcam
you can't use this device as webcam!
Jan 10, 2012 | Samsung PL120 Digital Camera
MY SAMSUNG PL120
Hello.
Used - full work.
ebay.com
Item number:170740619194Item location:morrow, GA, United StatesShips to:Worldwide
Nov 11, 2011 | Samsung PL120 Digital Camera
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
Why does it take too long for samsung pl120 to process pictures after taking a shot? My friend does not experience the same problem with his pl120 digicam.
Does your card have a lot more pics on it than your friends' card? Is your friend's card a faster rated card than yours?
Jul 03, 2011 | Samsung PL120 Digital Camera
On my SGH-A737 some times my buttons won't work so
pull it apart and clean the contacts with a rubber eraser where the silicon buttons push onto it . if you google this up there will be a link to show you how to pull it apart it is not that hard to do. regards terry PS.it is under samsung and your model number.just type in how do you pull apart samsung etc ther are pictures to guide you through it..
May 23, 2011 | Samsung Cell Phones
Samsung PL120 Digital Camera Logo
73 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
