Question about RCA Televison & Video
I don't have my original remote for my rca rear projection tv can i still adjust my convergence
    Master:
  • 482 Answers
Mine is in the set-up menu accessed from the buttons on the front of the tv
Posted on Feb 28, 2013
techman007
  • 1112 Answers
SOURCE: 55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Posted on Oct 01, 2009
techman
  • 3130 Answers
SOURCE: rca 52' projection convergence problem
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
Posted on May 22, 2006
TODDAS
  • 431 Answers
SOURCE: rca rear projection fuse blown
U NEED A E-PROM
Posted on May 12, 2009
Slinteriors
  • 8617 Answers
SOURCE: 52' rca projection tv convergence will not adjust color
Repalce the STK730-130 IC on the Convergence power board. You can get a new IC at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/stk730130/cName/convergence-ics
Posted on Jun 19, 2009
  • 13 Answers
SOURCE: RCA D52W20 Rear Projection, Green and red shadow
Makaba is incorrect. This set does not use the STK IC's found in many rear projection sets.
All you need is a $3 fuse and be sure to resolder the joints at the flyback.
I don't have the remote for a Samsung rear
Go looking for a used remote--I have one I hang onto for just convergence alignments on their sets--no universal will cut this.
The original remotes among other things had a data button to save the adjustments.
May 29, 2012 | Samsung Televison & Video
The red is wavy and doesn't line up
Sounds like you are trying to adjust convergence through the menu setting on your TV. Make sure you are using that TV's original remote to make these adjustments. If you are unable to make these adjustments then typically it is because one or both of your TV's convergence chips are burnt and need to be replaced. You can find these chips fairly easily but make sure you are purchasing OEM chips made by Sanyo. Sanyo made the majority of the convergence chips for most major brand rear projection TV's. You can find good quality chips at convergencechips.com. Hope this helps,James
Feb 15, 2012 | Hitachi 57F500 57" Rear Projection...
The projection is out of alignment on my tv. Well i've tried adjusting the convergence at the 5 points on the tv but no matter how many times i press the adjust buttons the crosshairs don't move....
the convergence board is bad you need to replace the convergence ICs', to have it repair you are looking at 300-400 and if it was me I just buy a new LCD.
Aug 18, 2011 | Mitsubishi VS-55609 55" Rear Projection...
SHould AN RCA RCU400E. RCA RCU404N UNiveRsal Remote AuTomatically WorK. On an RCA P56950 model TV without the codes?
No,only the original tv remote that design for that tv model will work only for that tv without a universal codes.All universal remotes have to have a codes enter to program it to make work for the tv dose not mater same model or simular.All the rest same model of tv or simulair tvs the original remote only 50/50 should work,some fuctions just not there or just don't have it.
Aug 14, 2011 | RCA P56950 56" Rear Projection Television
I have an older model rca rear projection tv. The problem with the tv is that the picture bends into curve after about 5 minutes after it has been turned on. Please help.
Check the convergence IC's for cold solders, check for leaking capacitors in the area. Check the voltage regulator with a Variac.
Usually these sets just need the 2 big convergence IC's replaced with new ones. Clean all 3 picture tube lenses, mirror and screen. Get the original RCA remote that came with the set and MANUALLY align the convergence.
Rarely the bow on the bottom of the screen is not repairable.
Jul 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Convergance adjustment
if the convergence option is missing from the on screen menu you will need to replace DL231, CL230, and FL231 to restore the option. You can get the parts and instructions at the following link for less than 20.00. They also most likely have the original remote for your set also. Leave them a email to inquire.
Jan 30, 2009 | RCA D52W19 52" Rear Projection Television
RCA 46" Rear Projection TV-How do you adjust the convergence colors
are you looking to correct the problem or make and adjustment
adjustments you can do from the remote once you in the menu
however if that doesn't fix your problem most likely it need convergence ic's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
65 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
