It worked this morning then when putting on the last load the light flashed then wouldn't go on again! Checked plugs under lid but all looks fine. Checked fuse too. Any ideas?
  • Washing Mach... Master
  • 16,181 Answers
What is the make and model?
Posted on Jan 19, 2013
  • 1462 Answers
SOURCE: zanussi electrolux aquacycle 1400 xc 6 fx1465 w
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Posted on Mar 21, 2007
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Posted on May 31, 2007
  • 8 Answers
SOURCE: No Power
HI THIS SOUNDS LIKE A CIRCUIT BOARD FAULT PROBABLY BLOWN 3 SMALL COMPONENTS & A BIT OF TRACK ON THE BOTTOM RIGHT HAND SIDE OF BOARD.IT IS USUALLY ONE OF 2 FAULTS THAT CAUSE THIS EITHER A MOTOR PROBLEM IE CARBON BRUSHES TOO LOW OR FAULTY MOTOR THE OTHER THING THAT USUALLY BLOWS THE BOARD IS THE DOOR INTERLOCK GOING FAULTY. I HAVE REPAIRED LOADS OF THESE BOARDS & 9 TIMES OUT OF 10 ITS ONE OF THEM THAT BLOWS IT HOPE THIS HELPS!
Posted on Jul 30, 2008
  • 121 Answers
SOURCE: Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
Posted on May 05, 2009
stephanos18
  • 144 Answers
SOURCE: Blowing lid fuse. Lid switch tested fine. Other Ideas?
You might want to test the inlet valves for a very low resistance reading or a dead short Also check the motor etc for a short to earth using a Insulation Tester. Does it pop the fuse while it's meant to be filling up or while it should be spinning or washing? Cheers
Posted on May 15, 2009
Kenmore top load HE just bought 2yr old after hooked up it worked fine;then loud grinding noise then lid latch light stated flashing only way to det lid open; turn off unplug then plug back in light s
I see a phone call in your near future. Please call a local appliance repair dealer in your area. The HE line of washers were made by whirlpool. kenmore-top-load-just-bought-2yr-old-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Jan 09, 2015 | Kenmore Washing Machines
I have a WBSR3140G1WW GE washer. I have notice that my clothes are not spinning dry or mixing. The first thing i checked was the washer timer. That was the same it was not spinning or mixing soap up. So i...
It sure sounds like a relay switch, the reason its coming on when you unplug is something reset so its not broke yet. I would replace the door switch anyway.
Oct 30, 2013 | General Electric WBSR3140GWW Top Load...
Stalls losing electric power
How old is the battery & have you tested it?
How is it that a month went by & your using
any vehicle that could let you down?
Why have all issues not been resolved ,as soon
as they started?
Have you checked for codes?
Have you had a professional scan tool on it
& checked data,that has to be done along with
many other checks or tests,unless it's just a battery
issue.
No one can solve any vehicle issue over the internet
There is always more to the story & you need the patient
Jul 19, 2013 | 2004 GMC Envoy
2010 Z1000 in Australia. bike was 100% fine less than a week ago, got it out last night and it wouldn't start. The dash lights up, but doesn't show neutral light when it's in neutral. Also the...
get the dealer to sort this out as taking it apart yourself could invalidate the warranty. its classed as third party interferance, and as you are not a kawasaki mechanic they could wash their hands of the warranty.
Sep 08, 2011 | 2010 kawasaki Z1000
Hotpoint Aqualtis AQ9L29I 1200 9kg washer has stopped working! It was working fine, got up one morning to load up and it wouldn't switch on! Door wouldn't open, no lights on, nothing, dead!...
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 12, 2011 | Hotpoint Washing Machines
My n145 netbook was working fine last nite then this morning i tried to get on & the start up screen wouldn't show. i waited then the screen showed the restart screen, i entered my password &...
try looking it under a light or in the sun if you can make out the screen but the light is out then you either have a bad back light or inverter
Jun 14, 2011 | Samsung N145-JP01US Netbook
Brand new condenser vhc 680f starts cycle and then stops after ten seconds and lights flash. checked filter
Hi my dryer was the same. Apparently condenser dyers wont work under 5c, with all this mega cold weather my utility room was freezing brr and the dryer stoped after 10-15 sec and started flashing checked everything but still wouldn;t work. Found a swedish website (after spending DAYS looking for an answer) that said it mght be to cold so I brought the dryer into my house and wa hey its working again. Hope this helps xxx
Oct 18, 2009 | Mattel UB FUNKEYS Dream State Dyer and...
No sound from any source from speakers
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
May 05, 2009 | Denon AVR-687
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
