Question about Waterco Pool & Spa
Manual for waterco sand filter - Waterco Pool & Spa
3 Suggested Answers
adamh294
  • 310 Answers
SOURCE: How do I replace the
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
Posted on Nov 01, 2010
john224
  • 1378 Answers
SOURCE: when waterco sand filter is
Thank you for posting your question here on Fixya.com.
Since you already replaced the gasket you will need to check two others things: First, inspect the groove the new gasket is sitting in as well as the mating surface of the diffuser. Be sure none of the old gasket is still there. Thoroughly clean all surfaces as well to ensure the new gasket is fully seating in the valve. If that does not cure the leak you will need a closer inspection of the mating surfaces to find a crack. Without any pump pressure on the valve it will be tough to find. It will appear as a hair like line but once the pump is on it will open up enough to let water pass. If you find a crack you can try to use a two-part plastic approved epoxy to seal it or else you will need to replace that part.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 18, 2010
How much sand goes in a waterco 8600 sand filter
Leave 10"-12" empty space above sand (freeboard).
Dec 18, 2016 | Waterco Pool & Spa
I have a waterco pump and sand filter and can't get a high flow thru the pump to operate the creepy crawly
see if it works on recirculate if it does change sand or backwash if suction based and you have multiple inlets close the ones not being used if it is connected to a pool return close the other return valves or plug them while cleaning
Sep 14, 2015 | Waterco Pool & Spa
How do I change the sand in a sand filter model t500
Remove top of filter tank, use shop vac and vacuum away.
Mar 03, 2015 | Waterco Pool & Spa
How do I replace the sand in my waterco t400 pool pump. Is there a manual available
To start this:
Nov 01, 2010 | Pool & Spa
How much sand goes into a waterco t600 sand pool filter
Hello. 265 pounds of sand required. Here is the link
http://www.aqua-man.com/row_num.asp?ic=51945&froogle=1
please rate my answer as very helpful. thanks. Joe
Mar 31, 2010 | Garden
Pool & Spa Logo
91 people viewed this question
Top Waterco Pool & Spa Experts
Andrew Taylor
Andrew Taylor
bigdawg7299
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
