Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Paper Jam I tried to copy 3 pages and 1 page went through the copier and copied then it sucked the copied page back into the copier. Now it is saying I have a paper jam and I do not see a paper jamed inside . It does make a striping souind like one of the gears is not engaging. Fot the life of me I can not see anything out of the ordinary. The copier is a all in one Brother MFC-240C I also un-isnstalled the machine thinking that might help now I can't find ther cd to reinstall
  • rasher909 Jan 27, 2009
    I Think there is something wrong with the gears. I put the card board through it and nothng came out. Thanks for the suggestion
    Mike
    Problem Solver:
  • 6 Answers
Stick a 9x11 piece of cardboard down into the paper tray. It will push any small piece of paper that may be caught there.
Marue
Posted on Jan 26, 2009
How do I fix my Utax CD 1315 every time it makes a copy J40 appears in the window and won't make anymore copies
J40 is a paper jam might be a pickup roller check complete paper path might also be a hung exit sensor
Sep 16, 2016 | Office Equipment & Supplies
Tip
How to Fix a Paper Jam in a Copy Machine
It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
  1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  2. Step 2 Turn off the copy machine before pulling out the paper.
  3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  4. Step 4 Check for any paper fragments and clean up any torn pieces.
  5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  6. Step 6 Replace the cover and paper tray and turn the machine back on.
  7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
on Jul 14, 2010 | Office Equipment & Supplies
The out copied paper is not fully copied
First turn off at the wall outlet and count to 20 and plug back in to reset.
If that doesn't work, it sounds like there is a zoom feature and it is set to copy at 110%, making it too big to fit on the A4 paper and it is continuing on Page 2.
Jul 29, 2017 | Canon NP 6050 Copier
Cannon d1320 false paper jam
this happens due to overheating of the fuser unit.try resetting it
Jan 25, 2014 | Canon Imageclass D1320, Copy, Print, Scan...
There is a document jam 1. After I remove the paper and code goes away, the printer may print a page or two and then jam again. I have tried a new pack of paper (fanning it) I have tried a new...
You refer to a document jam then you mention fanning new paper but that refers to a paper jam.Which one is the problem? What does the screen say? If document jam then its your originals you are copying. If paper jam then its the paper in the machine. I cant help you any more because your do not state the make or model. Please repost with a lot more detail. Cheers
May 16, 2011 | Office Equipment & Supplies
I went to copy a sheet of paper this morning and my copier worked. Then i went to copy another page and i got a paper jam, and then System Error E000 appeared, and now i don't know how to fix it.
There still might be a tiny piece of paper caught in there. Take out the toner, and if you can open any panels, check inside those too.
Hope this helps
Dec 17, 2010 | Office Equipment & Supplies
I AM TRYING TO FIND HOW TO COPY FRONT AND BACK PAGES.
copy the front page and when it prints, put the copy in the paper holder backwards and copy the back page. This new copy will have the front page and back page on the same sheet of paper.
Oct 07, 2010 | Canon imageRUNNER 2010F Copier
Printer says paper jam and stops- but it is not jammed
your description indicates you need to thoroughly check printer for any bit of paper ........rolller too has to be checked so that paper is moving smoothly ......
Feb 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
43 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
