Question about Video Game Consoles & Games
How can I fix my glitchy Tron arcade machine?
I recently bought a Tron upright arcade machine and it works, sometimes. But other times it's glitchy, possibly due to grounding issues. I've described and pictured all the problems here: http://www.distantcreations.com/blog/2013/01/19/tron-arcade-machine-acquired-needs-a-little-help/ How can I fix them? Thanks!
    New Friend:
    Problem Solver:
  • 8 Answers
It sounds like your vertical or horivontal sync is going out what i would do is take the old monitor out and i would buy a arcade rgb cga ega yup to vga hd video converter you can usually find them on ebay for 40 dollars or so then all you will need is a flat screen that will except a vga connection you tube can show you how to install these items into your game i have done several and you would be surprised how easy they are installed and if you get a used monitor you can save a lot of money also
Posted on Feb 27, 2013
3 Suggested Answers
chess32
  • 13 Answers
SOURCE: playstation 3 hdmi is not working tried all fixes
your hdmi cable might have gone bad
Posted on Oct 12, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a first gen
The Sony PlayStation Portable has several great features that put it solidly at the cutting edge of gaming consoles. One of these is that Sony periodically releases system software updates and upgrades that introduce new features and enhanced performance. Once you create a network connection for your PSP, you can download updates directly to the console. Alternatively, you can download updates to your PC and transfer the data to your PSP.;
to download Updates Directly to Your PSP;
  1. Fully charge the battery on your PSP.
  2. Connect your AC adaptor to the PSP and then plug it into an outlet.
  3. Insert a Memory Stick Duo into the appropriate slot on your PSP.
  4. Select "Settings" from the Home menu.
  5. Select "Network Update" and then press the "X" button.
  6. Select your connection to connect to the network.
  7. Wait while the system checks whether data is available to download.
  8. Download the data.
  9. When the download is finished, press button "X" to install the update
Alternatively, can download the PSP update to your computer, then transfer the update into the PSP, then run the update;
  1. Connect your PSP to your PC with a USB cable.
  2. Create a folder on the Memory Stick called "PSP."
  3. Create a folder called "Game" withhttp://www.fixya.com/PostAnswer.aspx?thid=7441263&ctgid=180&ref=unslin the "PSP" folder.
  4. Create a folder called "Update" within the "Game" folder.
  5. Download the software update to the "Update" folder. The update must be saved with the file name "EBOOT.PBP".
  6. Fully charge the PSP battery then connect the AC adaptor to the PSP and plug it into an outlet.
  7. Select "Game" from the "Home" menu and then select the "Memory Stick" icon.
  8. Choose the "Update" option then press button "X" to update the system software.
Lastly, read the information on the below link as it might be helpful.
http://us.playstation.com/support/systemupdates/psp/index.htm
Good luck.
Posted on Dec 25, 2010
My PS3 was fine and fast when I bought it. Now all the games are glitchy aswell as the system menu. I have had it for 3 years. Sometimes the game stops for a few seconds then continues, or the sound will...
Sometimes, a system just will NOT work like it used to due to corrosion and the aging of the system. If you use the network, some cyber-trolls may be the cause.
Apr 21, 2013 | Video Game Consoles & Games
Dell Inspiron 1545- Google Chrome & battery problems.
Your Google Chrome glitching is due to needing more memory. (if you have a lot of add-on, I'd remove some of them and see if that helps some)
On the battery issue - your battery is rather old, and needs replacing.
Mar 17, 2013 | Dell Inspiron 1545 Notebook
Sportcraft
Last time Arcade Hoops replacement parts I bought from amazon. Take a look on this link Amazon com Arcade Hoops replacement. I hope this was helpful. cheers
Mar 13, 2012 | Sportcraft Arcade Hoops With Electronic...
I have a kenmore elite microwave oven model 363 63692301 stoped heating food ;. fan & turntable work. HELP!
Hello, two things. The mega-tron tube is gone south, or the HV diode is open/shorted to ground which will cause to open. If the microwave meta-tron tube is bad then recyle your microwave oven and buy a new microwave oven. One can buy a new microwave oven cheaper than buying a microwave tube. GB...stewbison
Sep 12, 2011 | Vacuums
I bought a T2-arcade machine today. I tried it out twice to make sure it worked properly and it did. I got it home and plugged it in and made a "clicking" noise and would not load. Although...
OK - the easiest thing to try first is to open the back and check ALL the wired / plugged connections on the PCB (printed circuit board) - 9 times out of 10 - it is usually corroded or loose connections. All these games are designed to plug into a standard 110V outlet US - unless you are over in Europe - then the machine would be set to 220v. If you are using an extension cord and it is very long, it IS possible that there is some power desegregation. If that is the case trying moving the cabinet to an outlet where you can directly plug it in. HTH
Apr 30, 2017 | Terminator 2: The Arcade Game
I have a ballys mr &ms pacman pinball machine and the sound works sparaticly , will come on random and work fine for 5 mins or so then just cuts out for 10 to 20 min nothing i do will make it come back...
I have a eralier 80's upright Bally's Pac Man arcade machine that I got off a freind of mine. They said that they palyed it all the time up to about a year ago. I got it home set it up and pluged it in... and nothing happens. I've hit the start buttom on the inside and the new game button but still nothing... Is there something else that I may need to check?
Oct 02, 2010 | Arcade Ms Pac Man / Galaga Cocktail Table...
Ms Pacman/Galaga Cocktail Arcade//side 2 not working
1.Check the dip switches for cocktail set up/ no upright.
2.does the screen flip to the player 2? if yes
3.make sure you have good dc ground in player 2 joystick.
4.if no picture flip for player 2, go to solution 1.
Thank You.
Jun 15, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
Uno not working on xbox live arcade
ok so you alredy bought it so delet it and download it for free how u delet it is u press the x oin the middle of the controller fove over 2 the right to console settings then click memory then click games/arcade games then click uno the click delet or go to active downloads click stop download then go to the marketplace and press buy again
Jun 21, 2009 | Microsoft UNO for Xbox Live Arcade Full...
Video Game Consoles & Games Logo
50 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
