Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony WEGA KV-27FS120 connected to LG BP200 - Sony FD Trinitron WEGA KV-27FS120 27" TV
    Top Expert:
  • Sony Master
  • 75,311 Answers
What is the problem you faces when connecting this TV with LG Blu-Ray player?
Posted on Jan 20, 2013
  • Susan Jan 20, 2013
    I have this old tv that only has rca out/in and the LG blu-ray has built-in wifi but only HDMI connection. Is there a good fix for this? Do I need a digital converter box?
  • The Knight
    The Knight Jan 21, 2013
    You can't connect this TV with this blu-ray player. As you mentioned here, it needs a converter.
  • 116 Answers
SOURCE: Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Posted on Mar 01, 2008
jerryg50
  • 1689 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Posted on Jul 12, 2008
Shuttle83
  • 1139 Answers
SOURCE: KV-36XBR450, FD Trinitron WEGA
Hello maymet,
This sounds like the HV protection circuit is cutting off the TV due to a high current event in the set. This could be a problem in the High Voltage section of your TV (Horizontal output transistor, Integrated High Voltage Transformer, and y of the deflection components, and or the CRT in cases of shorts).
I would suggest that if you do not have a background in electronics, you should have an experienced TV technician troubleshoot and repair this problem.
This is due to the nature of the dangerous voltages that are present in the television.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 23, 2008
SOURCE: sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Posted on May 01, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
How to reset the parential controle on a sony trinitron wega KV-27fs120
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given.
Jan 07, 2015 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Lg crt tv on after few second tv off
Check its main power regulator circuit section for any loose solder terminals. Re-solder all suspected solder terminals by applying a little more fresh solder.
Nov 01, 2012 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Solutions to auto shut off lg crt tv 21
check for a defective horizontal output transistor.
Aug 16, 2012 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My sony trintron is stuck in stand by mode
If model number listed here (kv-27fs120) is correct the set if not coming on is in shutdown because either a problem in its power supply or something elsewhere pulling the supply voltages down and triggering shut down.
Someone would have to open and first check for voltages and or shorts--no real other easy way to troubleshoot this.
Mar 19, 2012 | Sony FD Trinitron WEGA KV-27FS120 27" TV
MY SONY KD-28DL10U WONT LET ME RETUNE DIGITAL SIGNAL
you can download kv-27fs120 (should work for 100) 81pages complete service manual from me at computec40@hotmail.com i will direct you to my ftp sight to download it.
Nov 04, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony wega tv was on and it shut itself off and we tried to reset power and the standby light is now blinking red 6 times with no picture.
Why not try this.
If it is a tube type.
1. Turn off the TV.
2. Disconnect it from the outlet.
3. Connect the power cord after 1 minute
4. Power the TV.
Mar 01, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Wega KV-27FS120
This may be a power supply, and or a high voltage, or a scan ampplifier failure. The set would have to be properly trouble shooted by an experienced TV tech to determine the exact failure. This is not something you can fix yourself at home.
Jerry G.
Apr 15, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
