Question about Sewing Machines
My serger keeps breaking the left needle. It works fine as a 3 thread but not with the 4th thread.
I have operated this serger for many years and never had this problem. I have replaced both needles, oiled the machine, cleaned out all the lint possibilities and rethreaded the machine numberous times just in case something was threaded wrong. All to no avail. I would appreciate any help you could give me in solving this problem as I live out of town and cannot easily access a repair centre. Thank you.
  • Sewing Machines Master
  • 7,365 Answers
Make sure the left needle is inserted correctly into the needle
holder, if you have flat sided needles make sure that the flat side is
put correctly to the side it suppose to be.
check the tension on the left needle, it may be too tight
Posted on Jan 21, 2013
SOURCE: bernina 2500DCET serger keeps breaking the centre
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Posted on Mar 02, 2009
bargainbox
  • 1388 Answers
SOURCE: mock safety stitch
Sounds like the timing is a little out.
If you remove the needle plate and turn the handwheel manually watch for the lower looper as it swings behind the Left needle....the needles ought to rise by only about 2mm before the looper passes......the looper must pass the needle above the eye to catch the thread, and be so close as to be barely touching the rear of the needles......if the left needle thread is not picked up, it may be the timing, or the distance between needle and looper.
For the uninitiated, there are a myriad of variables in correctly timing an overlocker (serger), and without the manual to refer to the correct parameters, you will rapidly descend down a road of despair....if you move a looper to advance or ****** the timing, you risk looper collision and a broken looper is almost as much as a service, so my advice is do the test to see if the timing is the likely culprit, and if so, take the opportunity to give the old girl a treat.
If you need to save for a while to do it, just use the 3 thread option for the time being.
www.bargainbox.com.au
Posted on May 10, 2008
akylas
  • 26 Answers
SOURCE: thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
Posted on May 28, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
Posted on Sep 10, 2009
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
I have a bernette 134 and the tread keeps breaking , the lower loop thread , no matter how I set the tension , upper or lower this thread keeps breaking , HELP
10.check in the needle plate area to see if there is a burr
11. Check the looper to see if there is a burr or if it looks damaged
If all of the above suggestions don't help then the serger needs to be checked to see if there is something wrong with the loopers and also see if there is a problem with the tension.
Aug 22, 2013 | Sewing Machines
Janome 9200d overlocker
Aug 18, 2013 | Sewing Machines
Kenmore serger thread keeps breaking
Mar 26, 2013 | Sewing Machines
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Jan 01, 2013 | Sewing Machines
Why does the 4th thread keeps breaking on my serger? I've re-threadedi it a dozen times carefully following the diagram. What am I doing wrong?
Most likely it is either your tension on thay thread being too high, or the needle is too big for the project you are working. Lower that tension, use the next size up needle, and thay should fix it. Also, I STRONGLY suggest only using maxi-locks thread. They are more expensive than other serger threads, but they are always half-price at hancock... Any other thread I have tried using causes breakage, especially on the the lower looper (the 4th thread). Although, of you keep the tension low-below 3 or so, you should be ok. If these tips don't help, I would also check your cutting width, if your machine has an adjustable one. If it is leaving too much gabric to the right of the needles, out is conceivable that this is putting too much pressure on the threads. Let me know if this helps!
Jun 23, 2011 | Simplicity Sewing Machines
Left needle thread keeps breaking on my White Superlock 2000 ATS serger
the tension must be too tight or check to make sure the spool does not have a crack that is catching the thread in the middle of using the serger. When the serger is working and the spool has a crack it catching the thread then you press to go on and it gives a break the needle because the spool is still holding onto the thread
May 02, 2010 | White Sewing Superlock 2000 ATS Mechanical...
Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Jun 12, 2009 | Baby Lock Eclipse Serger
BabyLock Proline upper looper thread keeps breaking
I ended up switching the spools of thread around. Apparently, even though I had purchased good quality threads, one of the spools was wound in a way that made the thread loop and twist around. So I put the offending spool of thread through one of the needles and put the needle thread on the upper looper. That seems to be working. By the way, BabyLoc was very unhelpful dealing with this problem.  Thank you!
Aug 26, 2008 | Baby Lock Eclipse Serger
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
