Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
2010 distrubuter problems
My john deere 2010 distrubuter doesn't turn when I crank it over - I took it out and the problem is further down as the distrubuter its self is ok - wondering how much there is to fixing this - Monty
  • 2 more comments
  • mgmalcolm Jan 27, 2009
    This is a 2010 gasoline farm tractor - I was talking to some guys at work and they think it could be that the timming gear may be shot - you supose that would be a place to start?
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    mr.monty,it;s more than likely the camshaft gear, i had an old chevy that dine the same thing. if you repair yourself make notes&drawings how things came out to put back sameway.your local john deere dealer can order manuels for that engine.wish i was there to help you! please give me a rateing on help.thank you,good luck.MrFixIt.
  • JERRY ABELL
    hello! what type of john deere do you have;lawn tractor or farm tractor;engine mobel number,make of engine,horse power,you know that sort of thing,thank you.
  • JERRY ABELL
    hello mr monty! well i done some looking in my tractor book;you have a kawaski fc 420v-15 or kohler engine, kawaski i have no information on this engine. kohler i have plenty of information on. i need kind of engine model number if is kohler engine.hope i can help you;MrFixIt.
The timing gear is made from material which will break if the gears are not meshed correctly, if the distrubiter has come loose at some time, this can chew out the timing gear and leads to all sorts of problems (ie correct timing)
Posted on Feb 12, 2009
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
Jon Deere mower LX277 won't crank
Try replacing the starter solenoid. If that doesn't do it, try replacing the whole starter.
May 05, 2012 | John Deere Garden
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Where can I get a new carb four 2010 john deere not rebuild .will not start when worm.
You should be able to get a new carb from any john Deere dealer.You may want to check the tractor for fire when it's warm,you may have a coil breaking down when warm due to the oil has leaked out over the years.I would check to see if you have spark or not before buying a new carb.
May 05, 2010 | John Deere 2010 Tractor Basic Carburetor...
Possible starter problem?
Check the ring gear that it meshes with as it may have damaged teeth!
Turn it a full 360 degrees & check all the teeth!as when they are turned off they often stop in the same area due to motor ballance thus wearing out teeth in one area!
Cheers Rob
Sep 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
143 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
