Question about Video Cameras
I have a sony vision 16 camcorder with no model number on it and i don't have a manual can you please help me.
I can't find where the film goes it has a big viewfinder lcd on the front it has mitsuba on the other side it has scan reset max min it has a power box battery you can open the front of the camcorder that looks like where you would put in 35mm film .
  • 30 Answers
SOURCE: Hitachi DVD camcorder
The door might be stuck. Try "helping" it open manually after pressing the eject button. Otherwise, something is probably broken and you might have to call a repairman.
Posted on Apr 09, 2006
  • 169 Answers
SOURCE: No display in viewfinder and LCD
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
Posted on Aug 11, 2007
SOURCE: LCD Screen goes blank after opening up
I actually have several of these cameras and have seen this happen many times with this model. The ribbon cable that goes from the body to the LCD tears in the same place in all of my experiences. If you look at the hing area, you can see the black coating on the ribbon cable between the body and the LCD. The top edge of this cable tears right where it enters the LCD component. If it works when only 1/2 way open, it's just a matter of time before it totally stops working...the damage has already begun. A replacement LCD runs >$100. Instead, I search e-bay for parts cameras. Just make sure that the description doesn't say that the LCD is bad.
Taking apart the camera isn't all that hard. Start with the e-bay parts camera just in case something goes wrong. Take off the lens cover (the lens actually stays attached to the camera for this entire fix) by removing a screw on the bottom, one just under the eye piece, one inside the LCD door area (near the top), and one inside the tape area...the one closest to the front of the lens. Then, the lens cover slides forward. Once you get it moving forward, extend the eye piece and the lens cover comes right out.
The 2nd step is to remove the LCD. The easiest fix is to remove the entire left side (LCD and SD flip cover). This is done by removing the 3 screws on the bottom (careful, 1 is smaller than the other 2), the screw in the battery area, a screw near the front of the lens, and 2 screws near the top (one above and 1 below the lens). Once the left side is free, tip it forward, exposing the 2 ribbon cables. The larger one is the LCD. Disconnect it by simply flipping the grey bar where the ribbon cable connects to the body up. The ribbon cable should come out with no effort. The other, smaller ribbon cable is the speaker and the "LCD is Open/Closed switch". Be careful with this one. Hold the white connector in place against the body (I apply pressure using a small, flat screwdriver). Pull the ribbon cable out of the holder at the body with your fingers (it should require only a moderate amount of force). If the white cable connector comes off with the cable, you're in trouble...the wires are extremely thin and difficult to get back in the right place...but it can be done.
Once you've removed the left side portion, do the same with the good LCD. Reconnect everything in the reverse order. I use a small needle nose pliers to put the small ribbon cable back into the connector. The larger one just slides in with little to no effort. Lock it in place by tipping the locking back back down. Once you've connected these 2 cables, you can carefully put a battery in and test that it works. If all goes well, remove the battery before continuing to put it back together again.
When you're done, put the parts camera back together again and keep it. You may need it for the lens assembly (I've had grease inside my lenses at times and the front lens can scratch easily, so a replacement is good to have around).
I've tried replacing just the ribbon cable, but getting it out of the LCD isn't worth the effort since finding a good cable usually means that you've also found a good LCD for the above proceedure.
You can find the repair manual complete with exploded views at http://www.eserviceinfo.com/download.php?fileid=27179.
Posted on Mar 06, 2009
welcomejee
  • 10594 Answers
SOURCE: Problem with Sony CCD TRV138 camcorder
Symptom shows bad CCD IMAGER in camera and requires replacement. (IC951 on CD-465 board, mounted at end of lens mechanism).
Nice to know that you are tech person so buy CCD IMAGER from any part store under following part number..
A-7013-219-A CCD BLOCK ASSY (CCD IMAGER) (TRV138/TRV338)
Good luck.
Posted on Mar 15, 2009
mannforever
  • 23 Answers
SOURCE: LCD screen not working on my Sony Hc 42 camcorder
Hi
The LCD cable is faulty. You need to replace the LCD cable from SONY authorised service center.
It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.
Posted on Aug 11, 2009
User manual
NPF750 is the model number of the battery. Which model camcorder do you have using this battery?
Jun 12, 2013 | Video Cameras
I need a manual for a sony vision 16 camcorder
Google the make and model number, followed by the word manual.
Jun 19, 2017 | Video Cameras
CAN I GET POWER WITHOUT BATTERY OR CAN I USE POWER ADAPTER INSTEAD?
Some camcorders have a manual eject button that will open the compartment and allow you to remove the film/tape. Since you again declined to specify the model of your camcorder, I can't tell you whether this solution applies to you.
If you need further information, please feel free to reply to this post, but be sure to include the model of your camcorder.
Feb 20, 2012 | Sony Video Cameras
The touchscreen LCD screen on my Sony HVR A1E is faulty. The picture appears OK and the p-menu page appears, but some of the menu buttons don't respond or don't correspond to the correct...
I am one of the lead technicians at VideoOneRepair.com toll free 888 283 2228. We are a repair shop that specializes in only Sony and Canon Prosumer camcorders. The problem that you are experiencing with your Sony HVR-A1U camcorder is a common problem with this model camcorder. The ribbon cable that connects the LCD screen to the main part of the camcorder goes faulty and needs to be replaced. Sony also recommends that when this cable is replaced you must also replace a modified part to prevent this from happening again. The estimate to replace both of these parts is $360.19 parts and labor. This also includes cleaning and servicing. We also offer a 6 month guarantee on the entire camcorder, not just what it was sent in for. The estimate and the return shipping are free even if you do not have the camcorder repaired. Please feel free to call, email or post any questions you have and I would be happy to respond.
Aug 24, 2011 | Sony HVR-A1E HDV Digital Camcorder
My HDR-SR12 handycam automatically switches to night vision when it is turned on & stays in night vision. Doesn't switch back. I bought it used, & have been filming with it fine since I got it...
This is a failure of the cameras internal "night vision"switch which is part of the lens assembly. the camera will need to be disassembled to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 11, 2011 | Sony HDR-SR12 HDD Camcorder
I woul like to put all my digicam recordings onto dvds
You should either download video to a computer (using firewire/IEE1394 connexion), then use a video editing software to build DVD films, or a direct firewire to DVD software (no editing, just dump the video on a disk). This is a bit difficult if you are not accustomed with computers, and takes some time if you want to have nice results. An over possibility is with new home DVD recorder / player, much have now a firewire/IEE1394 input that lets you download atomaicaly from your camcorder to a DVD or the internal Hard drive if the player is equiped with. This last seems to be the best for you if you just want to save your video for further visionning, and don't want to du "cut and paste job" that would be made possible with video editing soft on a computer. Then you should look for a home DVD recorder, and be sure to have it with a IEE1394-Firewire input. I hope this will help.
May 28, 2009 | Sony Handycam DCR-PC3 Mini DV Digital...
Video Cameras Logo
158 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
