Question about HP DeskJet F4280 All In One Printer InkJet
My ink cartridge cannot be recognized. . . . - HP DeskJet F4280 All In One Printer InkJet
  • sk82jack Feb 03, 2009
    yea i got the same problem, i just printed out one sheet, and when i tried to print out another 2 minutes later it said that there was an error because the ink cartridge is wrong, its been working fine since end of september but just stopped now
    Genius:
  • HP Master
  • 1,102 Answers
When did it start do this
Posted on Jan 26, 2009
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
My black ink is cartridges is not recognized..i have a epson tx121
hi,
epson tx210 ink cartridge not recognized, epson tx121 ink not recognize, ... tx200 does not recognise the black ink cartridge, epson tx 210 product ... How serious are you to have that body you want for summer? ...
www.sulit.com.ph/index.php/...Epson+TX121/.../TX400 - Cached
May 30, 2011 | Office Equipment & Supplies
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Nov 17, 2009 | Epson Office Equipment & Supplies
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP DeskJet F4280 All In One Printer InkJet Logo
110 people viewed this question
Seeker5211
Seeker5211
