Looking for cable connector pin
The connector thay goes through the cable(flat)that plugs into compact disc player has broken,need new part system is SC-HD5150
  • 56 Answers
Try MCM Electronics, not sure but might have something that works, GOOD LUCK
Posted on Jan 26, 2009
Need USB cord
It could be a mini USB connector, but on Wikipedia, you can find all USB connectors with name and picture.
Mar 21, 2014 | Hello Kitty Sanrio - KT7002 - Compact...
Were to connect the power switch to an emachines t3642
My intel tells me this is the motherboard for an eMachines T3642 Desktop PC,
http://www.ebay.com/itm/GATEWAY-EMACHINES-W3644-MCP61SM2MA-4006232R-MOTHERBOARD-T5246-T3646-T3642-S3649-/330737918167?pt=Motherboards&hash=item4d018420d7
If this holds true,
http://support.gateway.com/s/MOTHERBD/Shared/4006232R/4006232Rnv.shtml
In the list click on the blue - Product Views
The Ebay link shows you where the letters, of the above Gateway link, are on the motherboard.
1) B - Auxiliary 12 Volt ATX connector.
This is where the 4-pin ATX +12 Volt power cable plugs in,
Example of power cable from Power Supply,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power for the Processor (CPU) Do NOT forget it.
2) E - Main Power Connector
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note* Color of connectors for 1) above, and 2), do NOT matter.
What the connector is, Does.
Note also that there is a pivoting Lock, on both power cable connectors.
The matching motherboard connector has a Lock TAB.
When the power cables are deemed to be plugged in tightly, and correctly; the Lock's hooked end will be over the Lock Tab.
[Squeeze the top of the Lock in, to release. Release when removing.
The Lock works on the same action as a seesaw on a playground ]
3) F- Floppy Disk Drive Connector
A 34 wire thin ribbon IDE cable, connects here on the motherboard, and plugs into the back of the Floppy Drive. The cable is the Data cable.
The power cable that goes to it is a 4-pin Small peripheral power cable. Looks like this example,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
IF a Memory Card Reader, (Media Card Reader. Same/same) is used instead; it will use the SAME power cable.
The data cables are different though. They connect to a Front USB header on the motherboard, and are a rounded cable.
ONE of the Front USB headers on the motherboard, will be used for the Card Reader.
Click on S - USB 2.0 Connectors
[NOTE* In EACH USB header are provisions for attaching to TWO USB ports. Front OR back of computer.
One will be used for the TWO data cables, going to the Card Reader. Which one? Pick one.
BIOS will set up a new Interrupt Request for it. (IRQ) ]
G - Parallel ATA IDE Connector
40 wire flat ribbon data cable goes here. (ONLY 39 wires are actually used, though)
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
Now I'm going to get a little lengthy, and detailed;
See the two small 'ribs' on the Top/Middle of the connector?
(May just be one solid block, also)
That is a Locating Lug. When you plug the connector into the motherboard, it lines up with a Cutout in the motherboard connector.
IF there is NO Locating Lug;
Look at the side of the cable that has the faint Red stripe.
This Red stripe is on the SAME side as Number 1 wire.
When plugging into the motherboard connector, the side of the cable that has the Red stripe, goes DOWN. Down towards the Bottom of the motherboard.
Number 1 pin in the motherboard connector, is at the Bottom of the motherboard connector.
If no Locating Lug when plugging into a device; Harddrive or Optical Drive, (CD/DVD drive);
The side of the flat data ribbon cable that has the Red stripe, goes towards the POWER CABLE pins, on the device.
Let's look at an IDE (PATA) harddrive, and the 4-pin Peripheral power cable that plugs into it;
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
See where the power cable plugs in? The Red stripe on the IDE flat ribbon cable, will be next to the power cable.
Also can be said as, when the IDE flat ribbon cable is plugged into the Harddrive, the Red stripe will be on the Right.
Same with an Optical Drive.
You MAY have an optical drive's flat data cable plugged in here.
IF it is an IDE (PATA) optical drive.
MORE than likely though, your Harddrive is a SATA unit, and plugs into a SATA connector on the motherboard.
U - SATA Connectors
Note there are two. SATA1 and SATA2.
The Harddrive is supposed to plug into SATA1.
The beauty of SATA is though, that you can plug the Harddrive into SATA1, OR SATA 2.
BIOS will find the device.
This is an example of a SATA data cable, and it's connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
(Your SATA connector on the motherboard, is different than the example shown)
Between a SATA data cable's connector, and a SATA power cable's connector; a SATA power cable connector is the Larger of the two.
A SATA data cable connector has 7-PINS.
A SATA power cable connector has 15-PINS.
Note also the L-shaped opening. This lines up with an L-shape on the Harddrive connector, or an Optical Drive connector. (Data cable connector)
Note also that a SATA power cable has this same L-shaped opening.
More to follow in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | Computers & Internet
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
I did not hook my cords up properly inside me e machine T 3642
Okay. Let's start with the motherboard, and power cables coming from the Power Supply;
A) The eMachines T3642 Desktop PC uses a
Foxconn (WinFast) MCP61SM2MA motherboard,
1) http://www.ebay.com/itm/eMachines-T5246-T3646-T3642-4006232R-Motherboard-/140665743077?pt=Motherboards&hash=item20c054e6e5
2) http://support.gateway.com/s/MOTHERBD/Shared/4006232R/4006232Rnv.shtml
(The Form Factor is Micro-ATX. (uATX)
It uses an AM2 processor socket )
[NOTE*
Power unplugged from computer, AND Anti-Static Precautions FOLLOWED.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return ]
Click on the link in 1) above. This shows the bare motherboard with no hardware components attached, or power cables from the Power Supply, or any other cables attached. (Cables = Wires)
Scroll down to the photo of the motherboard.
Look at the Yellow long, Ram Memory slots, that are vertical. (2 each)
To the right of them.
A1) The whitish connector that has two columns of 12 socket holes, is the 24-pin ATX main power cable connector.
This is a general example of a 24-pin ATX power cable, and it's respective connector on the motherboard,
(NOTE* Color of power cable connector, and connector on motherboard, Does Not matter),
View the photo to the far right. Note the Lock on the power cable's connector, and the Lock Tab on the motherboard's connector.
The hooked end of the Lock, MUST be hooked over the tab, to ensure the power cable is plugged in tightly, and correctly.
A2) Look at link 1) again.
Look at the Top/Left side of the motherboard. See that whitish square connector with 4 socket holes?
That is a 4-pin ATX +12 Volt power connector.
A 4-pin ATX +12 Volt power cable plugs into it. This power cable's connector also has a Lock,
A3) The Harddrive is a SATA unit. It has a SATA power cable that plugs into it, and a SATA data cable that plugs into it.
The SATA headers (Connectors) on the motherboard, are seen in link 1), and are to the bottom/right. There are 2.
They are Blue in color, and are above the green headers.
This is where the SATA data cable of the harddrive plugs in.
Straight connector. Elbow connector plugs into the back of the Harddrive.
The SATA data cable connector has 7 pins.
The SATA power cable has 15 pins. It is the longer connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Which SATA header on the motherboard, should the SATA harddrive's data cable plug into?
SATA1. The top header. (Connector)
The beauty of SATA however, is that you can connect in EITHER connector, and BIOS will find the harddrive.
Note the L shape on the inside of the power cable connector, and the data cable connector. There is a matching L shape for the connectors on the motherboard, and the back of the Harddrive. Line these up when installing the cables.
A4) The optical drive/s (CD/DVD drive) may be SATA, but I'm betting the optical drive/s are IDE. (PATA)
The optical drive/s will use a flat ribbon cable, for a data cable, and it plugs into the long Blue connector, seen in link 1), to the bottom right of the whitish 24-pin ATX main power cable connector.
On the flat ribbon cable is a faint red stripe. It is on one side, and the side that has number 1 pin.
To line the cable up correctly when installing To the motherboard, use the cutout in the connector. The flat ribbon cable's connector, should have a Lug on the outside, which lines up with the cutout.
IF NOT, the faint red stripe side of the cable, goes down towards the bottom of the motherboard.
Looking at the photo, and the IDE (PATA) connector on the motherboard, number 1 pin is at the Bottom/Right corner, of the motherboard connector.
The flat ribbon cable's Lug, also lines up with a cutout in the connector, at the back of the optical drive.
IF the cutout is not present at the back of the optical drive, or there isn't a Lug on the connector, the faint red stripe goes to the RIGHT side of the optical drive.
(Doesn't matter if the flat ribbon cable is twisted. The faint red stripe ALWAYS goes toward the power cable connection, on a drive.
Harddrive, or optical drive.
Number 1 pin is the pin closest to the power cable connection on the drive.
More in a Comment.
Regards,
joecoolvette
Feb 01, 2012 | eMachines T3642 Refurbished AMD Desktop...
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
I LIKE TO KNOW HOW TO KNOW WHETHER THE PRODUCT IS STILL FUNCTIONING OR NOT? PLEASE ADVISE. SHOW ME HOW TO DO THE CONNECTION OF THE IDE CABLE TO THE HARD DISC AND THE POWER CABLE? HOPEFULLY THESE ARE NOT...
No product support question is stupid, Peter.
1) An IDE cable should be plugged in with the Number 1 socket hole in the IDE cable's connector, going on the Number 1 pin on the harddrive.
Number 1 pin on an IDE optical drive, or harddrive, is next to the 4-pin power connection.
http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Illustration which shows the back of an IDE (PATA) harddrive.
See the area marked as IDE Connector?
Two rows of pins.
Next over are the Jumper pins in the Jumper Block.
Finally, next to the Jumper Block is the 4-pin power connection.
To make sure the IDE flat ribbon cable, is inserted into the harddrive in the correct position, a Locating Lug is usually on the IDE flat ribbon cable's connector.
A small rectangle, or two bumps side by side, on the top edge of the connector.
http://en.wikipedia.org/wiki/File:ATA_Plug.svg
This Locating Lug lines up with a cutout, in the circuit board of the harddrive.
A Locating Notch.
Sometimes there isn't a Locating Lug.
In this case look at the side edge of the IDE cable for the faint Red stripe.
This red stripe is on the same side as Number 1 pin.
http://en.wikipedia.org/wiki/File:Nappe.svg
So when you go to plug the IDE cable in, make sure the Red stripe is facing the 4-pin power connection.
Goes for an optical drive (CD/DVD drive), or a Harddrive.
(On the motherboard there are usually two IDE headers. {Connectors}
One for the Primary IDE device, a Harddrive, and one for the Secondary IDE device.
Usually an optical drive.
Next to the Primary IDE connector on the motherboard may be PRI, or Pri, or Primary, or IDE 1.
{ In TINY letter/numbers }
Next to the Secondary IDE connector on the motherboard, may be SEC, or Sec, or Secondary, or IDE 2.
Sometimes only the Secondary connector is marked. This tells you the other connector is the Primary connector.
Number 1 pin is towards the marking. Primary, or Secondary.
The Red stripe goes towards the marking on the motherboard )
Also;
There are two rows of pins on the back of the Harddrive for the IDE cable.
With a cursory glance it may look as though there are two rows of 20 pins.
There is not.
One pin has been removed. One row only has 19 pins.
Generally, but NOT always, the matching socket hole in the IDE cable's connector, is blocked off with a plug.
An IDE cable only uses 39 socket holes even if there are 40 shown.
Also; NOT a good idea to put a Harddrive, and an Optical Drive, on the same IDE cable.
BIOS looks to see which drive has the Master Boot Record.
Windows master boot record.
This is on the Harddrive.
BIOS will look at both, the Harddrive, and the Optical Drive.
This slows the computer down, for one.
For two, BIOS may not find which drive has the master boot record, with both drives on the same IDE flat ribbon cable.
Harddrive goes to the Primary IDE cable.
Optical drive/s go to the Secondary IDE cable.
2) As for the power cable it is a 4-pin standard Peripheral power cable.
Often misnomered as a 'Molex' cable.
[Molex was the model name given by the first company to produce this connector.
It stuck.
Kind of like referring to an open-end wrench as a Crescent wrench ]
It is also a STANDARD 4-pin Peripheral power cable, because there two 4-pin Peripheral power cables.
4-pin Standard Peripheral power cable,
Note in the center photo the shape of the connector.
The top two corners are rounded.
Only plugs in, in one direction.
{The Yellow wire is a 12 Volt wire.
Red = 5 Volts
Black wires are Ground wires }
4-pin Small Peripheral power cable,
Older computers used this power cable for a Floppy Drive.
Newer computers use it for a Card Reader.
Regards,
joecoolvette
Oct 01, 2011 | Computers & Internet
How do you get the hard drive out of a Toshiba Equium 7100D computer?
It's been a Long time since I have worked on one of these, so forgive me if my information is somewhat sketchy.
If memory serves the Left side of the case comes off. (Viewing the desktop computer from the front.)
There are clips underneath that need to be depressed, in order to remove this side cover.
From there with a flashlight, you should be able to view the other corresponding clips to depress, and remove the rest of the cover. Believe it lifts up so far, then slides forward.
At the Front Right side is the CD drive. There is a single screw you remove, and then the CD drive tilts up. From there you will see a single screw, that holds the harddrive in.
Once you are able to lift the harddrive up a bit, you wiggle the whitish colored plastic plug, side to side, as you pull out. This is a 4-pin Molex connector. It provides power from the power supply to the harddrive.
Sometimes this Molex connector can be QUITE tight, and hard to remove. DO NOT pull on the wires! If you use finesse, you can use a pair of pliers to wiggle it out. I advise using a Lot of finesse, as you can crush the plug. Sometimes it requires a bit of force!
The Molex plug looks like this,
http://en.wikipedia.org/wiki/File:Molex_female_connector.jpg
Then the 40-pin interface cable connector is removed. (Flat ribbon cable goes to this connector) Use a Lot of finesse here, as the tiny pins can be bent Quite easily!
Now the harddrive is in your hand, and you can examine it more closely.
The 4-pin Molex connector only goes in the harddrive, in one direction.
The top corners are tapered, and allow the plug to be installed only one way.
The 40-pin connector may be another story!
Looking at the connector itself, observe if there is a square lug on top. (Square plastic protrusion, emanating from the top edge of the rectangular plug)
This square lug lines up with a cutout in the back of the harddrive. It puts the 40-pin connector, in the proper position in the harddrive.
If this square lug is absent, don't fret when you go to re-install.
I will advise you the way to do it properly.
On one side of that flat ribbon cable you will see a faint Red line, or stripe. This Red line corresponds with Number 1 pin in the ribbon cable. Number 1 pin is on the side where the Red line is.
Viewing the back of your harddrive that you're going to install, (It is an IDE harddrive. Also referred to as EIDE, ATA, or PATA), note the pin locations.
All the way to the right are 4 pins. This is where the 4-pin Molex connector plugs into.
To the immediate Left are the Jumper pins.
To the Left of the Jumper pins are the 40, (39 actually), pins where the flat ribbon cable plugs into.
Number 1 pin goes towards the power connection.
The Red stripe on the flat ribbon cable, will be facing the 4-pin power connection on the harddrive.
If you have any further questions on this, please come back, and post them in an additional comment.
Oct 18, 2009 | Toshiba Equium 7100D PC Desktop
I need a wiring diagram for the stereo and eq of my 93 ford probe
Digital Audio Compact Disc Player
Section 15-01: Radio, Tape Chassis and Digital Audio Compact Disc Player 1996 Probe Workshop Manual
REMOVAL AND INSTALLATION Compact Disc Player, Digital Audio SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Radio Removing Tool T87P-19061-A
Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the instrument panel finish panel (044D70). Refer to Section 01-12 for the removal procedure.
  1. Insert the Radio Removing Tool T87P-19061-A into the face plate holes until the tension of the tool locking into place can be felt. (There are tension clips that this tool pushes out of the way so the radio can pull out. Maybe you can insert 4 pins that will do the same thing.)
  1. Flex outward on both sides of the radio chassis (18806) simultaneously and pull the radio chassis from the instrument panel (04320) using the tool as handles.
  1. Disconnect the electrical connectors and the radio antenna lead in cable (18812) from the radio chassis.
Mar 17, 2009 | 1993 Ford Probe
Dvd player, pvd-709
Hi lindy,
My kid broke the ribbon tape, so I took it apart. It is easy to fix all you have to do is plug it back in if the connectors are in tact. 1 goes to the reader and the other plugs into the circuit board. My problem is that I cant find a new flat ribbon cable/wire anywhere.
Aug 12, 2008 | Durabrand PDV-709
Broken connector on new USB keyboard
I would contact the store that sold you the keyboard, and found out where you can find replacement parts. I went to the iOne website and there wasn't a support section, that I could find.
May 22, 2008 | Computers & Internet
126 people viewed this question
 Grubhead
Grubhead
