My goodmans gdb1225dtr twin tuner will not record even though it will allow me to set a record time etc
I own a GDB1225DTR Freeview and Digital TV recorder. Recently it will not record any tv programs, either by manually attempting to record them whilst they are on, or by setting a recording in the guide window. All other features appear ok. the signal is showing at 95% and the picture is fine. it is still possible to play back previously recorded programs but some of the more recent ones are shown as recorded when in fact there is nothing there; it clicks straight off.
3 Suggested Answers
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Posted on Apr 18, 2010
SOURCE: My Sony digital dvd recorder/player
Sony have now provided an update on their website to correct the recording problem
Posted on May 12, 2011
Philips dvdr 3380
The dvdr3380 has an analogue tuner. It doesn't pick up digital TV.
Your TV picks up digital, but it isn't designed like a TV/cable box to be a signal source to an external device.
If you want to make TV recordings on to the dvdr3380, then you need to buy a TV tuner box (Freeview/Freesat etc) and connect that to your aerial system and to the line input of the dvdr3380.
Aug 18, 2014 | Televison & Video
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
My freeview digital recorder which is a twin tuner will now only record programme being wached and am unable to change channels while recording. would reformatting the hard drive solve problem?
It sounds like you simply don't have the cables hooked up corectly to allow that.Would you please tell me how it is hooked up?For instance,what the outside cable is hooked up to input etc. I need to know everything you have available,and what OUTPUT and what INPUT is connected to where,starting with the outside cable,and if there is a cable box or not.Literally everything connected for use with the TV.Greg
Dec 08, 2010 | Televison & Video
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
May 12, 2009 | LG RH266 Recorder
I have a Philips DVD Rcorder How can I record a programme but watch another one at the same time. Has Freeview installed.
When you have programmed the DVD to record a channel, you can only watch another channel from your TV's channels, or a second freeview box.
The DVD recorder can only be set to one channel at a time, even though it has separate analogue & digital tuners.
Jun 01, 2008 | Televison & Video
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
