Question about Coleman Powermate 1,850 W Portable Generator Pm0401853
My generator wont start it sat for two years and now its getting fire and gas is filling the bowl in carb but no fuel is going to intake if i prime it it will only start
  • 4088 Answers
SOURCE: wont stay running
If the bowl has fresh gas (smell it), then the jetting is plugged up. Remove the carburetor, disassemble the jets (Idle and main) and soak in carburetor spray cleaner--blow out with compressed air. If the fuel in the bowl smells stale, then remove the float and needle valve. Wash the needle valve seat, but not the needle--just wipe clean. Check that fuel runs out of the fuel hose--if not, check for a plugged filter or bad hose. Hope this gets you running.
Posted on Sep 30, 2009
  • 63 Answers
SOURCE: generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Posted on Mar 16, 2009
SOURCE: Coleman6250 Generator PM0545007 - Won't start/run.
Most gasoline engines need three basic things to run: proper air/fuel mixture, sufficient compression, and a properly timed spark. Check the easiest, cheapest things first, then check the "Gee, I forgot to turn on the gas" kind of things next, then work your way onwards from there.
Compression can be guesstimated with the proverbial thumb-over-the-empty-spark-plug-hole routine as you turn it over casually to check compression. If it doesn't blow your thumb out of position, you could have a hole in the piston (overheating response) or a stuck or damaged intake or exhaust valve.
Check for fuel flow by carefully disconnecting the fuel line to the carburetor and letting some run into a tin can (no styrofoam coffee cups, please). It should dribble freely. If not, you have to back-track the line and find out where the blockage is.
Spark is one that sounds like you've already tested (spark plug out of the cylinder head, hooked up and laying on the metal engine as you turn it over?) so check timing. You will probably need a manual for this test, although a good estimate is that the plug should fire just a wee bit before Top Dead Center position of the piston. Like I said, a manual comes in handy here.
From what you've mentioned, though, I'd start trouble-shooting at the fuel flow part first.
Good luck,
GRB
Posted on Jun 08, 2009
  • 15 Answers
SOURCE: float bowl drain plug stripped,
When you replace the carbs on these motors it can take a bit of time for them to start and run. If there is a primer bulb pump it up and keep pumping, this is basicly force feeding the carb until it has the vacumn to get the regular supply of fuel coming in.
Posted on Mar 25, 2010
  • 12 Answers
SOURCE: Spark but no fuel . coleman Powermate 6250
if it's flooding the float may have a tiny hole which makes it not float as well and too much fuel will stall the engine...If it's not getting enough fuel to keep running then its usually because of a small piece of dirt blocking a hole..under the carb there should be a brass bolt...take that off and check that the two side holes are clear...then check the center orifice and blow it out...there is also a tiny little hole up near where the threads start...use a wire from a wire brush to make sure its clean....also clean out the bowl and then reassemble...this works 90% of the time for me
Posted on Jul 02, 2010
Not getting gass but fuel pump works & gas is clean, also it has sat inside for 12 years
Well if the pump works then follow the pump fuel lines to the engine,you will find the fuel filter then replace it and will also see petrol if any in it ,if not pump isent working ,if dirty replace it and blow air back from carby to filter to clean out pipe
,turn on ign fuel should come to filter and then with new filter in turn on fuel and see if any comes to carby if ok it should start and run.
Have a goodday,
Mar 19, 2015 | 1986 Toyota Hilux 2200
91 isuzu pick up sat for 2 years and now wont start
I\'d try 2 things. One, some, or many, motors and fuel pumps, even electric ones, need to be "primed".
You might try to figure out how to suck the fuel from the tank up to the motor somehow.
I do not necessarily mean using your mouth.
You could also take a rag and an air hose, and GENTLY blow air into the gas tank to "prime" the system.
Another thing is, is there some part of the engine where gasoline could have congealed or turned to gummy deposits preventing the gas flow?
This is why they suggest mowers and generators be run until they run out of gas before storage, to prevent gummy deposits caused by evaporated gas.
Be blessed.
Apr 04, 2013 | 1989 Isuzu Pickup 2WD
5.0hp tecumseh power sport wont start
you have to take the bowl off the carb and see if the Jets are clogged.
How long did it run before you shut it off?
Oct 04, 2012 | Garden
My generator won't start. I started it when I first got it about a year ago. It's been in my garage for about a year.
Remove and clean/check/replace the spark plug first, spray some WD-40 in the cylinder, Remove all old fuel and just fill with enough fuel to run it. If you are comfortable removing the carb then it should be dipped/cleaned. Check to ensure the kill switch is not engaged/unplugged. Lemmee know then we can go further!
Jul 18, 2011 | Coleman Powermate Powermate 5000W...
Starts but wont keep running
The fuel bowl has a float and needle, the bowl is filled with gas and over time the float gets filled with gas or just don't float as it should within the bowl. the needle is pulled up by the float which lets fuel flow into the carb. A repair kit can be bought for $5 and is easily replaced. After you take this apart, it's a good idea to clean the carb with a carb cleaner. You'll have to take off quiet a bit which looks difficult but it's really not.
May 03, 2010 | Poulan Pro " Pro" Self Propelled Mower
I have an onan 5500 gas generator that wont start
What is the model? Chances are the carb needs cleaning or replaced.
Sep 21, 2009 | Watts Onan Portable Generator - 4000 ,...
Fuel will not pass through the carb
The carb is probably plugged up with 'varnish' that occurs if the gas sat in the carb too long. Try letting some carb cleaner sit in it over night. It may end up having to be pulled apart to clean it throughly. Always use 'stable' in your gas and if you don't run for extended periods, let it run all the gas out until it stops running. That way the carb is empty.
Sep 14, 2009 | Electrical Supplies
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Mar 29, 2009 | Electrical Supplies
Blaster wont start
Hi, If it starts on ether, then the plug is probably not too bad, spray your premix in instead and if fires OK then your carb is clogged, you can start with the float valve, open the drain screw on the float bowl and make sure it is filling, if it is, then its probably the jets or vanes are lacquered from sitting and they simply must be cleaned. Air pressure and a carb solvent works good when cleaning but other than that no magic. Good Luck, this should Fixya!
Feb 28, 2009 | 2003 Yamaha YZ 125
Coleman Powermate 1,850 W Portable Generator Pm0401853 Logo
46 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
