Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Canon sd750 does not hold date/time setting
My canon sd750 no longer holds the date and time setting. Is there an internal battery to replace? How do I replace the internal battery?
  • 477 Answers
Yes there is a internal battery the camera has to be opened up to replace it. we replace the battery on this model for 45.00
Posted on Sep 12, 2009
4 Suggested Answers
  • 75 Answers
SOURCE: Camera looses date & time setting
There is a cmos battery (or a memory battery) on the main circuit that like any battery wears out eventually. If you are familiar with repairing electronic circuits you can get the part from Olympus. There is no part number just "memory battery for C-740" will suffice. Your other two choices are to take the camera to a shop where they can do the kob for you. Don't let them sell you a complete new board, you don't need one. Not for this problem anyway. Or you can ignore the problem and reset the camera (or not)each time you change batteries.
Posted on Mar 31, 2007
robmcd27
  • 423 Answers
SOURCE: Canon sd 750 how to put the date in the picture?
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this: First,
Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Posted on Feb 25, 2009
LongPockets
  • 1177 Answers
SOURCE: how do you turn on
On my Canon this function is only available when the camera's resolution/format is set to Postcard.
Posted on Nov 20, 2010
Canon G16 is asking me to set the date/time every time I change its battery
There is a small battery INSIDE of the camera. It may need to be replaced OR the camera may have a short inside causing it to drain. If you need to have it serviced or if you need the correct battery, try this site: www.CamerasAndParts.com They just deal with the Canon's and they know these Canons well. They can either service it for you OR they should be able to sell you the part. It's the only place we recommend for the Canons. They are excellent and about half the cost on services as most other places.
Nov 29, 2014 | Cameras
Every time I turn on camera it ask to set date,
The Time/Date battery is a small round lithium battery the size of a dime in the battery compartment. You can get the numbers off it and buy one at Walmart or Ebay.
Instructions for replacing it:
http://www.manualslib.com/manual/275745/Canon-Powershot-Sx10-Is.html?page=267
Jun 06, 2014 | Canon PowerShot SX10 IS Digital Camera
Everytime I turn on my camera it asks me to set date/time. It goes to the default date/time setting of 00.00.0000 00:00 mm/dd/yy. What do I do to set the date/time so that it permanent? The photos are...
It takes around four hours for a freshly charged main battery to charge the internal backup battery. It you do that and it still doesn't charge it, you need a new internal battery. The fully charged internal battery in most of them will hold the charge for up to 3 weeks with the main battery out of the camera.
Oct 19, 2011 | Canon G12 Digital Camera
I need to replace the internal battery for date/time memory on a Canon SD750 camera. Please let me know the battery type.
Not sure what model # the battery is, but if you're opening the camera to replace it then just pull the old battery off the main PCB.
If you can't find a replacement somewhere feel free to let me know, I can check and see if we can get them new. I'm sure I will have old ones off of boards that will not power that you could have at no charge.
Thomas Drayton,
Owner: Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a Canon SD750 camera. It was the victim of a water flood and I dried the unit completely. After recharging the battery, I couldn't get it to power up. I took the camera apart and found several...
Unfortunately with water damage the camera may work for a few days or even weeks after you first dry it out, but then it will stop working completely. If you have corrosion from water exposure then the camera is gone, it's not worth trying to fix. Even if you replace the main PCB it probably has damage to the lens, LCD screen and flash as well.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
I have a Gateway solo 9550 laptop. When I turn it on it says ERROR Invalid system configuration data- run configuration utility. What exactly is wrong? Windows boots up when I press f1. How do I stop this...
You usually gets this message when you leave the system unplugged for a long period of time. Whe the internal battery drained out the system loses the configuration data. Normally the internal battery will get recharged when you plug the power back. Just have to go into the BIOS and set the date back to the current date. In some case the internal battery needs to be replaced if no longer holds a charge.
Dec 18, 2010 | Gateway Computers & Internet
The date and time will not stay set. I set the date time . take pictures and when I shut the camera off. the next time I turn it on the date and time is zeros again...
The world of compact digital cameras is fast and furious blink and you'll miss the new model. These pocket point and shooters are cram packed full of features that most people neglect to utilize. So it's uncommon for the problem you describe to occur however it's simple and fairly inexpensive to repair. What you need is to replace the camera's internal battery which holds the custom functions and date time settings after the camera has been shut off. Normal internal battery life is greater then five years and a lot of my cameras go ten years before replacement. A camera store not your big box type but one that actually sells cameras and does film and print processing. I don't know where you are to even suggest someone. However at the bottom of the camera where you would place the memory card and batteries there is another slot for the internal battery. This link half way down the page will show the open battery door and where the internal battery is located.
http://www.digitalcamerareview.com/default.asp?newsID=2981&review=canon+powershot+a710+is
There has been few complaints or problem with this camera except for the very weak internal flash.
Dec 17, 2010 | Canon PowerShot A710 IS Digital Camera
Won't turn on
Are you sure the battery is back in the right direction? If it is, try holding the power button down longer than usuall. If none of this works then it might have some internal damage.
May 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
371 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
