Question about HP 530 Notebook PC
Windows will not boot up in any mode asks for setup password
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Are you saying when you start your computer it ask for a password before it gets to the windows screen
  • 33 Answers
When your Windows were installed, the engineer may have put the password to go to setup. Ask the said engineer regarding that password. If he gives you the password, revert to me.
Posted on Jan 26, 2009
Why does my computer on bootup ask for system password then locks up too many attempts?
If you mean Bios password try this:
Resetting the BIOS PSSWRD, Open the computer case and look inside on the motherboard. Dell has diagrams of this. Locate the Little Jumper. It should have small print if you can read on the mother board indicating PSSWRD CLR. Boot the computer to Setup. Carefully remove jumper, becareful of static, and then once removed hit enter. Shutdown the computer, and restart and enter Setup again F2. The password should be CLR. Turn OFF and PUT Jumper back into place and Turn Back ON. You should be able to access Setup.
If you then boot to setup-check your hard drives and floppy that are seen. You may solve those issues in setup.
If you mean the windows password: boot to F8 safe mode and log
on to the ADMINISTRATOR not your log in that has admin rights.
Disable all passwords and restart.
Aug 16, 2014 | Dell Dimension 4600 PC Desktop
Pls help me out to get my password
1. Boot up your computer and immediately hold down f1. If it boots up normally then restart your computer and try f2. try all of the f keys and try del or esc until it boots up into your BIOS setup. This will look like a bunch of very blocky graphics. (usually the buttons are either f1, f2, f8, f10, del, or esc)
2. Once in your BIOS, navigate with the arrow keys and enter until you find the option to boot into "safe mode with command prompt" select that option, save your preferences and reboot your computer.
3.Once you've booted into safe mode, log on as the administrator or guest. Usually it does not require a password.
4. At the command prompt type "net user *" but type that without quotes and where it says you're user name just type you're user name without the 's.
5. It will ask you for a password. Type in the password you would like (It won't show the keys or even * that you are typing so that's ok). It will ask you to retype the password so do that.
6. reboot your computer and hold down whichever key that you used to get into setup.
7. Once in setup change the option from booting into "safe mode with command prompt" to the default option which will usually say boot into windows or something to that effect.
8. Log in as yourself using the password that you typed in at the command prompt.
Hope that helps
May 08, 2011 | Computers & Internet
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
Lost my windows xp password , I can't log on.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Sep 23, 2009 | Gateway GT5220 PC Desktop
Son locked me out of my lap top
This WILL WORK for you if you have XP.
2. Keep your eye on the screen messages for booting to your cd. Typically, it will be “Press any key to boot from cd”
Sep 09, 2009 | Acer Aspire 5050-3242 Notebook
Acer asire 5920 wont boot up cant get to windows to type anything in just a black screen asking for password or harddisk password. have acer aspire 5920 system disk it works asks for recovery disk 2 runs a...
For the psswords i can recomend to reset them from BIOS but to do that you must first know them. The problem with recovery disks is solvable if you boot from an XP disc and format the C: partition in NTFS file sistem and when it starts copying files to install the windows stop the installation ( F3 or press the power button for more than 4 seconds.. don't worry you will not sustain disk damage... done it myself with the same notebook for a dozen times ) After formatting the partition C: try recovery again and it will work.
NOTE: for the formatting of the partition you must set the HDD mode from AHCI to ATA witch permits the XP setup utility to "see" the HDD. If it is set in AHCI mode the setup utility for windows XP will not detect youre HDD
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Logon windows password and username
Ask you mother the password, or ask her to setup a separate user account in your name with your own password.
May 05, 2009 | IBM ThinkPad T60 Notebook
Boot sequence / bios password issues with Acer Aspire 5100
Hoping you are using some version of windows OS. Go to safe mode... press the power button to boot and while booting keep pressing F8 which will allow you to go to safe mode and reboot the machine if you are able to sucessfully able to go to safe mode. Now boot to normal mode as usual boot. If you still notice BSOD(blue screen of death) then once more go to safe mode and uninstall the new softwares if you have installed any on your laptop recently like graphics device driver or audio driver so on.... if you are not sure of new softwares installed.. use system restore method in safe mode to restore the system to older date it should resolve your problem. system restore tool of windows will be in start-> program -> accesories-> system tools-> system restore.
Dec 13, 2008 | Acer TravelMate 2300 Notebook
Can't get by the windows log in screen
Feb 23, 2008 | ASUS F3Jm Notebook
HP 530 Notebook PC Logo
32 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
