Question about Garden
HRU196 will start with "start ya *******" but will not continue to run on fuel
Have done the following: stripped carb, cleaned jet, air cleaned ports, changed fuel, cleaned bowl, checked float, cleaned filter, checked exhaust port, fuel cock. Compression seems OK throttle opens/closes OK, choke opens/closes OK.
  • 4 more comments
  • John Clark Jan 21, 2013
    I have been keeping small engines going for some 60 years. never encountered one so intractable. Seems to be fuel, since will start on ether. Have not as yet changed gaskets, but they seem OK. Come on guys! What else?
  • John Clark Jan 24, 2013
    Kelly,Yes! in the carb. Clean jet, float and needle valve OK, Strip again. Thanks
  • John Clark Jan 25, 2013
    This is one of those problems that seem to be insoluble. Motors need fuel, air and ignition. This one is not getting fuel, but for some reason outside the norm. There is a solution, and it will ne found.
  • Kelly Buxton
    Kelly Buxton Jan 25, 2013
    if by cleaning the carb it still won't go buy a new carb. Also you said that the compression appears to be ok. What does the compression gauge read after 5 pulls?
  • John Clark Jan 29, 2013
    FIXED! Stripped, cleaned carb again checking all aspects. Starts first time. Thanks to all respondents.
  • Kelly Buxton
    Kelly Buxton Jan 29, 2013
    glad we could help
    Sergeant:
  • 322 Answers
It is all in the carb. When you shoot ether into it it runs until it is burned off then the carb can't supply the engine with enough fuel to keep it running.
Posted on Jan 23, 2013
  • 82 Answers
SOURCE: Mower not running at set speed, choking
you should have an air/fuel mixture screw on the carb somewhere. Start the engine and turn it one way then the other a small amount at a time. One way it will get worse and one way it will get better. Keep turning till it smooths out
Posted on May 09, 2009
#1 Taper
  • 1040 Answers
SOURCE: Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Posted on Jun 05, 2009
panilling9
  • 284 Answers
SOURCE: 4.5hp Sears/Tecumseh motor starts and dies in 5 - 10 seconds.
metal or plasic float?
Posted on Jun 21, 2009
  • 512 Answers
SOURCE: Briggs and Stratton 19.5 hp 42e707 Hunts and Surges
Are you sure you got all the passageways in the carb cleaned out?
How did it look when you first disassebled it? Full of rust and gunk or just shellac on the surfaces?
Take the fuel line off at the carb and MAKE SURE that fuel flows freely. I have seen trash get in the tank and plub the other end up. Does it have a vaccuum operated fuel pump?
Posted on Sep 10, 2009
  • 5 Answers
SOURCE: Craftsman Eager1 6.75hp mower
How long does it run? If only a few seconds, then it is running on the fuel from priming, and the carb is not supplying fuel to keep it running. If it runs for a minute or longer then stalls, then you have a restriction or blockage in the fuel lines, the tank, or the area where the fuel line connects to the carburetor.
You didn't mention which engine it had. Most carbs will have a round bowl on the bottom, held in place by a brass nut (often 9/16" wrench size)
Remove the bottom nut on the carb bowl. Depending on the carb model, the nut may have some holes on the inside--these are part of the metering system, so don't damage the holes or scrape brass away as you clean out any scale, corrosion, etc.
I find that a piece of 14 gage copper automotive wire works well. Remove the insulation about 3/8" and use the wire strands like a brush. Also run a strand through the holes as well as down the center of the nut.
Spray everything off with carb cleaner. The WalMart Super Tech brand is cheapest and works fine. Brake cleaner will work, too, but it doesn't have the lubricants that carb cleaner has.
Make sure you spray up through the bottom where the carb bowl bolts to the carburetor.
If you have knurled screws on the side or top of the carb, these are the needle valves. BEFORE YOU REMOVE THEM, carefully screw them in, counting the number of turns. Don't screw too tightly, just until slight resistance is felt. Then, screw them out. Spray them with cleaner and wipe down. Also spray the holes they came out of. (Make sure you don't lose the small springs under the screw head--they keep the screws from backing out when the engine is running).
Assemble everything again. Screw the needle valves all the way in, then back out the number of turns you counted when first removing them.
Make sure your fuel tank is clean. Moisture from condensation can collect--clean it all out. Blow out the fuel line with compressed air--even an inflating needle on a tire pump will work if you seal the end of the hose with a rag after inserting the valve. Give the pump a couple strokes and you're done.
Now start the engine. It should run fine. If it doesn't, take it to a small engine mechanic.
Posted on Apr 04, 2010
Will not start, turns over and will run after a shot of petrol into the air inlet then stops after 2-3 seconds
Loosen bowl, while engine is cold, until fuel runs out. , then tighten bowl back up. It may have an air lock problem.
Jun 05, 2015 | Garden
Suzuki lt50 manual
have you tried starting with the air intake pipe/hose removed from the carb ? if still wont start i'd strip carb down and clean out the jets , not forgetting the idle jet at bottom of bowl , also check the diaphram pump is in working order , rubber diaphram still flexable not holed etckeep me posted if you wish
May 26, 2014 | Cars & Trucks
Fuel problems
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Re Bike will not idle with out choke Road Star Forum Yamaha Road Star
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
http://www.yamahaventure.nl/pdf/ownersmanualxvz13tf.pdf
Apr 23, 2014 | 2008 Yamaha Royal Star Venture
Yz 85 2005
Did the bike sit for a long while with gas in it?
What happens over time is the gas starts to break down (go bad).
When it does this, it turns into almost a varnish.
This starts plugging the holes in the jets, and the ports drilled in the carb, starting with the smallest, which is the idle circuit.
What is happening in your case is when you spray carb cleaner down the carb, it starts and runs on that, until it's used up.
You need to remove the carb and "boil it out" (clean and rebuild), paying attention to the idle jets and ports.
This diagram of the carb might help you:
http://www.bikebandit.com/houseofmotorcycles/2005-yamaha-yz85-yz85t-carburetor/o/m145327sch299511
Again, pay attention to the idle jet (pilot jet), #8 in the diagram, inside the float bowl.
Feb 17, 2014 | Motorcycles
Suzuki df4 4hp 4stroke outboard will not start and will not even fire after leaving petrol in during winter. fuel to carb ok. slosh a small amount of fuel into air inlet on carb then it fires but will not...
totally strip carb and clean properly ! as u take it all apart lay it out in order on work top , even take notes etc ! pictures even ! easy !
May 22, 2011 | Suzuki Boating
Bike has been sitting for only 2 months. Will start with choke on, running around 3500-4500 rpms. Once I take the choke off, it immediately dies. Also when it is running with the choke on, a slight roll...
This is probably a blocked idle jet in the carb, caused by standing and fuel gumming the jets up. The jet that the choke uses will allow it to run, but go to normal running and the idle jet is failing. You MIGHT get away with emptying the tank and getting some (expensive) fuel antifreeze (This is ethol alchohol they use in race cars) run through the bike. It might just melt the gumk and clean things out. If it doesn't, then its probably carb off and strip time :-(
Feb 09, 2011 | 2002 Suzuki GS 500 E
Generator will not run. Can start generator by spraying gas directly in to carburetor but will not idle/continue to run. Not currently connected to load. Trying to prepare for hurricane season. Can...
you have a blocked up card jet strip carb and clean out all jets
check fule flow from tank as well also clean all filters air + fule
best advice on missing hurricanes,,is move away?
Aug 14, 2010 | Honeywell HW5500E Portable Generator Not...
1996 gsxr750 sat for 8 years. No start, cleaned carbs,fuel tank. fresh fuel. now it starts but not very well. #1 cylinder seems to run very lean(put a rag over air horn, smooths out). Exhaust tube...
did you run needle in the jet while you where clean carbs?? as you need to remove the air fuel screw if didn't already. spary carb in the air fuel screw hole and make sure it come out the pilot hole and in the carb mouth. i have lint from a rag block a pilot jet before to. and yes sycnhonieing the carb will help after you get all 4 holes banging.
Mark
C.C. Motorsports
Mar 18, 2010 | 1996 Suzuki GSX-R 750 T
Clogged carburator, how do I get it out to clean?
BEFORE YOU START
Make sure that dirty carbs are actually your problem. Lots of things can make a bike run poorly or not start. Weak battery, corroded electrics, old spark plugs, bad timing, low compression, mis-adjusted valves, dirty air filter, and plugged exhausts can all cause poor running. I'll write an article eventually on how to diagnose poor running conditions shortly, but for now - lets just deal with the carbs.
There are many passageways and openings to check and clean. All are important in function and when obstructed or not working properly, have subtle to radical effects on engine performance. Vacuum leaks and carburetor synchronization also effect performance and should be inspected and adjusted following the below procedures.
Carb Cleaning 101
Warning: Remove all rubber parts before you begin. These parts usually include vacuum diaphragms, needle valves, o'rings, hoses, and other parts. Spray cleaners will damage these parts. Do not disassemble individual carbs from the carb bracket.
Air & Fuel Passageways: Trace and learn individual fuel and air circuits from beginning to end. Machines can only drill straight through the cast passageways. To change direction, another angled passageway must be drilled. The union is plugged with a brass or bronze bead. Inspect and clean each passageway with spray cleaner, brushes/pipe cleaners/etc, and compressed air. Remove any discoloration and debris. Look for spray cleaner to exit from one or more passageways.
Jet Cleaning: Inspect jets by holding to light and look through them. You should see an unobstructed round hole. Clean the jets with one or more of the following: jet cleaning wires, soak solutions, carb spray cleaners and compressed air. Re-inspect jets after cleaning and install when clear of obstructions. Some main jets have paper-like gaskets. Most have metal spacers between the jet and the emulsion tube. Some screw directly into a brass emulsion tube which is machined for a 7mm wrench at its float chamber exposed base.
Inlet Fuel Valve: Inspect the needle valve & spring. Press down the tiny metal rod that protrudes from the **** or float end of the needle valve. The spring should move freely and return the rod to its location. Check the needle valve's seat area for a groove or other wear. It should appear highly polished. Some needle valve seats are rubber and wear may not be visible. Inspect the needle valve jet seat. You can clean the jet seat with Q-tips and semi-chrome polish if necessary.
Carb Body Castings: Blow air through the atmospheric vent holes located on the dome of each float bowl chamber. Air should exit via hoses or brass nipples. Inspect the emulsion tubes and passageways (cast towers that jets thread into) for discoloration and debris. Clean interior emulsion towers with a soft bristle gun cleaning brush. Clean each Venturi (main carb bore).
Needle Jets & Jet Needles: Clean the needle jets, jet needles, and passageway or tower that needle jet screws into. Clean the emulsion tube (pipe between needle jet and main jet) (Main Jet may screw into emulsion tube). Jet needles are part of the throttle slides. See below…
Throttle Slides: There are several types of throttle slides: Mechanical linkage, vacuum, diaphragm, and cable. Disassembling the jet needle from the slide is not always required for cleaning. If you have vacuum piston type throttle slides (large diameter solid metal slide), avoid cleaning the lubrication from sides and caps. If piston type check cap vents and passageways with air. Clean if necessary and re-lube. If you have rubber vacuum throttle diaphragms, inspect for dry-rot, defects, and tears by gently stretching rubber away from center. Do this until all areas around diaphragm have been inspected. Replace any defective part as described above. Clean carb body areas around diaphragm including air passageways and air jets. Diaphragms have a locator loop or tab fabricated into their sealing edge. Observe this locator upon reassembly. Avoid pinching the diaphragm when reinstalling caps.
Fuel Screws: Fuel screws have sharp tapered ends. Carefully turn one fuel screw in while counting the turns until it seats lightly. Warning: These screws are very easily damaged if over tightened into their seats. Record amount of "turns-in" and remove the fuel screw, spring, washer, and o'ring. The fuel screw is part of the enrichment (choke) circuit...clean passageways as described above. When carbs are assembled, spray low PSI compressed air into diaphragm air vents located at intake side of carbs. Throttle slides should rise, then fall when air is removed. Lightly lube external moving linkages. Reinstall carbs and follow through with carburetor synchronization.
Throttle Cables: Lubricate cables periodically. If cables are disconnected from carbs or removed for replacement, etc . . . remember cable routing and ensure proper reinstallation routing. Avoid bread-tying, sharp bends, and pinching cables. Adjust cables so throttle grip has about 5mm of play or throttle slides or butterfly valves may not open completely (full throttle)(wide full open).
Float Bowls: Inspect float bowls for sediment, gum or varnish, crystallization, and defects. Clean all pipes, tubes, passageways, and embedded jets with cleaners and compressed air. Remove and clean the drain screw and area. Inspect bowl gasket and replace if necessary. Clean and inspect overflow pipes and tubes, look for vertical cracks.
Floats: There are several types of float materials: plastic, brass, black composite, tin, and others. Handle floats carefully. Avoid bending, twisting, denting, or other means of mishandling. Most floats are adjustable by bending a small metal tab near the float axle end. Do not change the float adjuster tab unless tuning fuel service levels. Clean metal floats by soaking or by spraying cleaner and wiping clean. Other material type floats may require replacement if cleaning is necessary. Inspect the needle valve (float valve) and seat. Check needle valve's spring loaded pin. It should depress and return smoothly and without resistance. Check the needle valve's tip for a worn groove. Replace needle valve and seat if either symptom exists. These parts wear together and must be replaced as a set.
Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
Notes: While carbs are apart, record the jet sizes. Look for a very small number imprinted on the body of the jets. Verify that numbers are the same for all jets on models with in-line cylinders. A few transverse-4 models and V-engines, the inner and outer carbs use some different size jets and it's important to not mix them up. If you have dial or veneer calipers, measure and record float heights. Perform measurements with floats just touching needle valves, though not depressing the needle valve rods. Replace fuel and vacuum hoses. Be sure to use fuel rated hose for fuel. Install or replace in-line fuel filters. It's a good time to remove and clean interior petcock fuel filters. Inspect carb manifolds for dry-rotting, inspect all clamps and air ducts. Inspect, clean, lube, and/or replace air filter(s).
Nov 24, 2009 | 2007 Yamaha V Star Classic
I have a troy built self propelled mower, it ran great last season, now it will not stay running. I checked to see if it was getting fuel and it is. I primed it and it acts like it is going to run and then...
The jets in carbs are really small and clog easily. If you stored your mower with gas in it start by replacing the gas. Remove the air filter and prime the carb. Start the engine and place your fingers over the air intake on the carb. This will cause the engine to stall as it will be starved for air. It will also create a powerful suction on the jets and possibly dislodge a blockage. Prime the engine again and start. If does not continue to run, repeat the steps again. If after 3-4 tries your engine wont run you will have to remove the carb and clean the jets manually. The reason your engine runs for a short time is because it is burning the fuel that you put in there by priming it. After that the fuel comes through the jets in the carb and if these jets are clogged the engine will die.
Jun 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
