Question about Zenith B25A02Z TV
Problem programming zenith tv
We have a zenith tv that we obtained from a hotel. It was set to on demand. we brought it home and we cannot get it to show a picture we have directv. how do we program it..
    Problem Solver:
  • 7 Answers
Same solution as before using the factory set-up menu changing the channel search parameters either CATV/Antennae
Posted on Mar 26, 2009
Zenith concierge code
The Hotel sets use a special remote--only way to get one is via the Zenith division of LG. Not cheap and likely why someone got rid of the set.
May 29, 2012 | Zenith Televison & Video
Zenith hotel TV turns itself on
Most of the Hotel sets use a different remote to enter the hidden menus--the system that set uses was likely on channel 81 and where it was used they needed it to come on at a specific time----going to get that specific service remote and info on how to change settings---this is the issue with buying these commercial sets.
Zenith is part of LG but different phone numbers etc
May 24, 2012 | Televison & Video
H2534y3 at a hotel and can't get tv on aux.
Press TV to control the TV - the hotel remote may not have anything programmed for AUX,
and even if it does, you've determined that its not the Zenith H2534Y3 Flat Panel TV
Feb 20, 2011 | Zenith Televison & Video
I have a Zenith Tv that I bought from a resale store after it had been used by a hotel. When the hotel had owned it they had programmed it to return to a specified channel every time that it is turned off...
there should be an auto program on the menu, but you can also download the complete manual for this model here http://www.retrevo.com/support/Zenith-B27A11Z-TVs-manual/id/277dj086/t/2/
Jan 13, 2011 | Zenith B27A11Z 27" TV
Can't auto program Zenith TV for cable channels
  1. Did you try to call LG/Zenith customer support and see if they can help you? If not find your nearest LG/Zenith service center (not Best Buy) preferably a small service shop to see if they have a service remote to unlock it
Aug 23, 2009 | Zenith Z37LZ5D 37 in. LCD TV
I have a philips tv whith no remote from a hotel how can i program it so i get all channels ?
If this has been a hotel TV then you cannot tune it in manually as the Hotel Mode will be activated & can only be re set to normal TV use by using a specific code from the remote control. The only other way is to re-initialise the internal memory using software that is only obtainable from a Philips dealer.
Jul 12, 2009 | Philips Televison & Video
We have a zenith concierge tv that was donated to a group home. WE have tried programming it so that the cable tv stations can be used but it has a lock on the auto program and I can't figure out how to...
You have to purchase the master remote from Zenith or a hotel supply company. This is the only way to gain access to programming the concierge. The remote is currently $24.99.
Jan 22, 2009 | Televison & Video
I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
Dec 13, 2008 | Zenith C27A24T 27" TV
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
Zenith Concierge H25W35DT 27"
The CORRECT answer is you must purchase a LP702 remote. Google it to find one to buy. You must unlock channels and program the channels fresh.
Some standard zenith remotes allow you to reset the tv by popping off the cover of the remote and pressing an unmarked button.
Mar 09, 2008 | Zenith C27A24T 27" TV
Zenith B25A02Z TV Logo
262 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
