Question about NetGear PS121 Print Server
Netgear ps121v2 Smart Wizard does not appear - NetGear PS121 Print Server
  • 3 Answers
If you are running WIndows 7 64 bit, you need to run the 64 bit version of the installer. Look in the directory ...\bin\driver\MFP\Utilityx64
Also in, Windows 7 you need to run the install wizard as administrator, since it is installing drivers.Right click on SetupWizard.exe and select "Run As Asministrator".
Posted on Aug 11, 2013
2 Suggested Answers
dongkikz
  • 440 Answers
SOURCE: Is the Netgear PS121v2 compatible with windows 7?
YES OFCOURSE
Posted on Apr 01, 2010
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I lost my password to my netgear. How can I retrieve it?
Go to NETGEAR Router.
After connecting the Router into your network, you must configure it. You can do this using the Smart Setup Wizard -- where the wizard will attempt to auto-detect the type of Internet service you have through your ISP -- or you can configure the router manually. It is recommended that, if you aren't used to setting up Internet connections, you let the Smart Setup Wizard do some of the work for you.
To configure the router, you'll use the information that you filled out earlier in the Installation Guide.
To get started:
  1. Select Yes if you want to use the Smart Setup Wizard.
    or
    Select No to configure the router manually.
  2. Click Next.
Nov 06, 2010 | NetGear WGR614 Router
Good day to all. I have a problem of my NETGEARWPN824V3
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
Configuring Smart Wizard for WEP encryption:
  1. Click Start then go to All programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  2. NETGEAR Smart Wizard wireless utility should appear on your desktop screen.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless network within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit the Connect button.
  5. On the Settings tab, click WEP under the Security option then select Enter Key Manually.
    Note: If the network key consists of 10 characters, set it to 64 Bits. If the network key consists of 26 characters, set it to 128 Bits.
  6. Type the 10 or 26 characters (Hexa decimal) keys on the space provided.
  7. In the Profiles field, assign a name to help you remember this wireless network settings in the future, then click Save Profile.
  8. Click on Apply to validate the settings.
  9. Once connected wirelessly, go to About tab and check for an IP address.
Configuring Smart Wizard for WPA encryption:
  1. Click Start then go to All Programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless networks within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit Connect button.
  5. On the Settings tab, select WPA under the Security option.
  6. Type the WPA password/passphrase inside the empty field next to the WPA drop down menu.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | NetGear RangeMax WPN824 Router
NETGEAR WPN111 Smart Wizard auto-shut down
Download the latest drivers, wpn111 3.0 from netgear website, install, restart, if problem persist;
open control panel, add hardware, manually install the device drivers, usually the list it shows you has a yellow mark. After doing this you should be able to open and follow the instructions.
I had the same problem and this it solved it.
Mar 26, 2010 | NetGear WPN111 RangeMax Wireless USB 2.0...
Smart Wizard for WGT624
The Smart Wizard is on the CD, but the web setup is built into the router. There are 4 versions of the software, so click on the following link http://kb.netgear.com/app/products/family/a_id/1297
and select the version you have (it's on the label on the router), then click on the Documentation tab and grab the Setup (manual setup) instructions.
Carl
Nov 11, 2009 | Computers & Internet
Where to get or download smart wizard
Your install cd is here.
If this helped you, then please help me and vote kindly. Thank you
Oct 14, 2009 | NetGear DG834G Router
PS121v2 does not install successfully
Check if your printer has been mentioned in the compatibility list:
http://kb.netgear.com/app/answers/detail/a_id/137
Aug 05, 2009 | NetGear PS121 Print Server
NETGEAr support
not sure exactly why you would need the setup software... you should be able to plug it in and access the routers firmware and set it up that way.
here is the link to the site for your hardware.
http://kb.netgear.com/app/products/model/a_id/2591
Jun 01, 2009 | NetGear WGR614 Wireless Router
NetGear PS121 Print Server Logo
125 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
