I have a carrier weathermaker 1993 model it's 58 dxc and my secondary heat exchanger is cracked. Should i repair or replace the unit?
  • 49 Answers
SOURCE: Carrier Weathermaker SX
If you are running it in the cooling function, your drain maybe backed up. Find your drain outside if you can and suck it with a shop vac.
Posted on Nov 28, 2007
  • 121 Answers
SOURCE: carrier 8000 weathermaker filter
The filter should be located in the front there should be some kind of tab to pull out the filter.
Posted on Oct 15, 2008
koolbreezes
  • 540 Answers
SOURCE: Carrier weathermaker 8000
Hey Crystakwi, lets find out why with the informations you gave! this got to be a heat pump,-- up flow--you live in a cold climate--probably in the upper United States--! The Heat pump takes the heat out of the air down to 40*, then the auxillary heat kicks in , or you can just turn the thermostat to auxillary heat and it will kick in the back up heater, whethet it be gas heat --oil-- or electric heat to provide the heat from any degrees out side temperatures. Its cool , its just doing it job! Thank-you- very- much!
Posted on Nov 14, 2008
boanhtgclg
  • 34 Answers
SOURCE: NO HEAT???? freezing
go to the furnace, there should be a service switch on the outside of the unit.  make sure the door is on good, does the blower motor come on?
Posted on Nov 17, 2008
  • 232 Answers
SOURCE: Carrier Weathermaker 8000 furnace blowing COLD AIR
you have a dirty flame sensor. just needs mantenance.
Posted on Dec 28, 2009
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
My heating unit is coming on and just running not blowing heat at all. what could be wrong?
my first impression is that the filters are too dirty and they caused the high limit to trip. needs serviced.
Jan 31, 2015 | Carrier WEATHERMAKER 48TCEA 4.0 ton Gas...
Code 24 on carrier weathermaker 8000ts
Turn power off to unit. Open air handler and take a picture of the low voltage (tstat) wires and where they are landed. Remove all thermostat wires from control board. Then replace the 5 amp fuse that is likely on the board. Fuse likely looks like one for a car (blade style). Put a jumper (small piece of wire) from the R terminal to the G terminal and turn power back on to unit. This should bring on the indoor blower. Let me know how that goes!!
May 12, 2017 | Heating & Cooling
I have a Carrier model # 58MXA080-F-15112. I think my furnace is 30 plus years old. it isn't heating properly. The blower turns on and sometimes the flames come on, but sometimes they don't. As...
A 13 code means the furnace cycled on limit more than three times consecutively and is in a lockout for 3 hours. A 14 is ignition lockout. An ignitor does not intermittently quit working. I'm the service mgr at our shop, and I know that particular furnace model has a service bulletin out on bad secondary heat exchangers. If your lucky the filter is dirty, or the furnace condensate trap or drain is clogged. Most likely the secondary heat exchanger is plugged up and isn't allowing the pressure switch to make. Or the furnace is overheating due to it not being able to properly vent hot gas. Which would explain the high limit lockouts. Call an authorized carrier dealer so you can take advantage of the free heat exchangers and the $300 labor credit. You can also call an authorized Bryant dealer to perform the work for you. Only an authorized dealer can rectify this problem because the Bryant corp requires testing and paperwork in order to get your free parts and labor credit.
Good luck.
Dec 23, 2012 | Heating & Cooling
Changing filter
The filter should be located in the return air flow duct either inside the furnace or in the ductwork
you should have it inspected by a service contractor
as far as when it should be replaced depends on the condition of the heat exchanger and overall condition of the rest of the parts it could start to nickel and dime you
Dec 31, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier weathermaker sx 58 furnace
I have serviced these furnaces for 20 years and I can tell you most of these models did not have diagnostic lite on them. (although some did, especially if the control board has been replaced) The problem is most likely a bad 3 wire pilot. This will cause exactly what you describe. 2 things to consider though. 1, If you were to replace the pilot don't get a cheaper knockoff. In my experience these do not last long at all. Get the right one from a carrier dealer. It will cost more but be much more reliable. 2 What is the condition of the secondary heat exchanger? Most if not all of the sx series had issues with the secondary heat exchangers rotting out and leaking. If the furnace is out of warranty you would be much better replacing the furnace as the cost of replacing the secondary heat exchanger will probably be almost the same as a new furnace. ( those babies are EXPENSIVE!)
Dec 17, 2007 | Heating & Cooling
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
