Question about Stoves 720EF Electric Double Oven
Oven won't work after the mains have been switched off
Can not start the ovens and can not seem to set the time when the power has been switched off. Only after some time of pushing all the buttons simultaneously, in different combinations etc, does it start. Some times the alarm will go off in the middle of the night. Driving us mad and can't always guarantee we will have a meal in good time. Can any one help please
  • 2 more comments
  • Frank Jan 20, 2013
    It's a 720ef, that's all I can see on the oven
  • Richard Roth
    Richard Roth Jan 20, 2013
    Who is the maker of the unit?
  • Richard Roth
    That model number comes back as a dryer
    Stoves 720ef oven
    Top Expert:
  • Stoves Master
  • 9,472 Answers
What is the complete model number?
Posted on Jan 20, 2013
  • 18 Answers
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Posted on Jan 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Posted on Apr 22, 2009
  • 250 Answers
SOURCE: manual for stoves 720ef double oven
Supply an email address on this post and I will give you access to my BT Digital Vault for you to take a copy.
Posted on Aug 05, 2009
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Posted on Oct 05, 2009
barkencoa
  • 3463 Answers
SOURCE: Hi. I think I've had a
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Posted on Oct 15, 2010
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
I've read the "getting started" instructions regarding the auto matic switch on and it doesn't seem to make sense. I can get it to turn off automatically but not on. Sorry for being dim.
Firstly, make sure the actual time is correct. Set the oven (if it's a double oven the clock function will only work on the main oven) to the setting and temp required. The first timer setting you put in is the cooking duration (not the start time) ie if it's a casserole that you want on low for a couple of hours, adjust the first setting to 2:00, when you press for the next setting you will see the the timer has already added 2hrs to the current time, adjust this to the time you want the item to finish (eg, You want it ready for 6pm, adjust to 18:00). Don't press anything else, give it a second or two and the oven will switch off. The oven will switch on 2hrs (or whatever time you have set) before the end time. Whilst the oven is waiting to switch back on, on some models the cooling fan will run continually, this is normal. If you are a little slow enter the times the clock will time ut and return to the actual time.
Hope this helps
Feb 21, 2013 | Neff Ovens
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
Hi Maurice.
Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
Here an extract from manual.
There is no preheat unless you set temperature. That is why you get the fan from start.
Oct 20, 2011 | De Dietrich Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Nov 22, 2008 | Neff U1721 Double circotherm Electric Oven
Stoves 720EF Electric Double Oven Logo
95 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
