Question about Karcher Garden
What will it cost to make my karcher k3.86 pressurewasher pressurize again?
    Scholar:
  • 90 Answers
What will it cost to fix your car ? It depends what is wrong with it.
Is the engine bogging down? Are the inlet and outlet valves seating properly? Is your unloader valve working properly ? Are your pressure seals worn? All of those things could cause loss of pressure . All are different price to fix
Posted on Jan 22, 2013
How do I fix a problem with my Karcher K4 pressure washer.
Sharon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Grumpy gits and useful tips
How to FIX Karcher pressure washer
Karcher North America Home Garden Online Help
Aug 09, 2016 | Karcher K 5.85 M Electric Pressure Washer
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
Karcher wont start
there is a pressure switch in those machines that goes bad. it is a common problem. if its under warranty let them work on it. if not take it apart and you will see the problem. it is replaceable and you can do it.
Mar 28, 2014 | Garden
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
Karcher 2400 Psi Pressure Washer No gain of pressure
remove the hose from the machine. Check that water is flowing. and there is no corrosion reducing the opening. If that is OK then it is the internal seals and pressure vallve on the pressure unit Cost to have it fixed by Karcher is $200
Thanks for using FIXYA
Sep 26, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Jun 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
Garden Logo
77 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
