Question about Monte Carlo Dryers
Stuck mach two light glob
Can not remove glass dome
    Genius:
  • Monte Carlo Master
  • 1,617 Answers
Try spraying with WD-40
Posted on Jan 23, 2013
Who to remove the light glob
Presume that a "light glob" is actually a "light globe" or a light bulb for owens.
So looks it's stuck, probably burned in and it's kind of messy to take it out. Turn it OFF, break the bulb and try to unscrew the base with a tong. Take it out in pieces without damaging the socket. This "invasive" procedure worked for me
Jul 19, 2015 | Ovens
Back dome light will not shut off
Does it have its own switch? If so remove the dome and check the switch to see if its stuck on.
Oct 20, 2014 | Cars & Trucks
I have a Hampton Bay ceiling fan/lamp where the lamp dome is apparently very tight into the housing. I pressed up and turned in the direction noted to remove the dome. The dome houseing came down and is...
Most light domes twist on or off or have thumb screws to loosen and lower the dome.It sounds like you removed the light kit assembly instead of the dome.Try to put back by twisting in place the light kit assembly and look for screws,or hold back on trim and turn just glass dome do not use too much force .I checked web site but can't find your model.It is unusual to not be able to just remove glass dome.Look closely at how the glass dome is positioned. If no screws are visible either the glass part unscrews or the ring unscrews allowing glass dome to be removed.Good Luck.I have installed many ceiling fans the problem is if you didn't install it your at a disadvantage.GOOD LUCK.
Jan 04, 2011 | Heating & Cooling
How to replace interior dome light bulb?
1) Remove the key from the ignition. Make sure the doors are closed, so the new bulb does not illuminate when you are installing it.
2) Make sure the dome light switch is turned to the "Off" position. Pry the plastic lens away from the dome light. Use a small, flat-head screwdriver.
3) Push back the side bulb clamp. Pull out the old dome lightbulb. Wipe the area with a paper towel if it is dirty.
4) Wrap the new bulb in a paper towel (oil from your skin will shorten its life). Insert it into the dome lightbulb holder. Push it up gently to secure it.
5) Turn the switch to "On" to test the bulb. Reposition the cover and push up to lock the clips into place.
If the bulb doesn't work, you've got a bad switch somewhere, probably on the drivers door.
Dec 26, 2010 | 2006 Toyota Highlander
How do i remove the glass in order to replace the bulb
Place hand firmly over the glass dome and apply firm pressure and turn the glass dome in a counter clockwise direction.
Jun 20, 2010 | Monte Carlo 5DI52WHD Discus White Ceiling...
I wanted to replace the oven light in my Maytag electric oven but I can't get the glass cover or dome off. Does it turn a particular way or direction?
it turns off but might be stuck or melted on possibly because the heat or the factory overtightened it, it will come off might just need a lil elbow grease but be carefull sometimes people break those tryin to remove. i believe its just a 40watt appliance bulb , hope this helps let me know
Feb 19, 2010 | Maytag Kitchen Ranges
Closet ceiling light, simple dome and metal ring,
Hello. There is always a way to remove the dome. If there is a metal nipple in the center of the dome, it will unscrew. Otherwise, the entire glass dome will unscrew. Regards, Joe
Jan 09, 2010 | Dryers
Dome light stuck on
check the rear glass and doors the button thing that tells the dome light to come on when u open it might be stuck in the outward position..that or check by your headlight switches usually u can turn it on manually over there
Oct 28, 2008 | 1995 Jeep Grand Cherokee
Minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Mar 30, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Oct 23, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Dryers Logo
Top Monte Carlo Dryers Experts
ka4iup
ka4iup
Tom Chichester
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
