Question about Sony DAVHDX265 System
How to connect DAV-HDX265 to xbox 360 and TV
I have one HDMI cable and a RC cable (red and white). I'm trying to connect everything by connecting the HDMI cable from the Xbox 360 to the TV (WinBook Display), and the RC cables from the TV/Video in from the DAV-HDX265 to the output of the TV. My point was to hear the surround system whether I was watching digital TV or watching something on the Xbox. What am I missing? I went to a electronic store and told me that the RC cables should do the trick, but they didn't. Any input would be appreciated. Thank you.
  • Sony Master
  • 3,904 Answers
Your HDMI cable handles both audio and video. If you would like a "one" source output you need to have a reciever that has multiple inputs with one output. You would then put your audio out from your souce device (xbox, tuner,record player...etc.) to the input of the reciever. Every device should have a different input. From there you would just switch your input selection to what you would like to hear. Let me know if you need a bit more guidance and I will get more detailed. The RCA connection (Red and White) are your stereo leads or (left and right) You will need the yellow one for video..it is separate.
Posted on Jan 20, 2013
2 Suggested Answers
SOURCE: cant connect my xbox 360 to my sony dav-hdx265
did you ever figure out how to do this because i have the same problem and am at a loss
Posted on Jan 10, 2010
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
XBOX 360
How to Connect XBOX 360
This is the back of the Xbox 360. The ports for the power cable, A/V cable, and ethernet cable are pretty easy to find. When you set up your Xbox 360, make sure it is in a well ventilated area that is free of dust. Dust and overheating are the two main causes of problems in electronics so choosing the right placement for your Xbox 360 is important.
This is the standard Xbox 360 A/V cable that comes with the premium version of the Xbox 360. The wide silver end connects to your Xbox 360 while the other end connects to your TV. The Yellow (video) cable is for standard, non-HDTV sets. You will also use the Red+White audio cables for a standard set. If you have a newer TV or an HDTV set, you can use the Red+Green+Blue video connections along with the Red+White audio connections.
This shot shows what the back of most TVs look like. If you have a standard TV, you'll only have the Yellow+Red+White connections. If you have a newer TV or HDTV, you should have the same connections that are shown in the pic. This step isn't too hard since the cables from the Xbox 360 and ports on the back of your TV are all color-coded.
If, and only if, you have an HDTV and want to use your Xbox 360 in 480p, 720p, or 1080i resolutions you have to slide a little switch over on your A/V cable. On the end of the A/V cable that connects to the Xbox 360, there is a little switch that you'll need to click over. If you do not have an HDTV, you can skip this step.
Now that you have the audio/video cables connected, the next step is to hook up the power supply. Connect the two parts as shown in the picture and then connect the "power brick" end to your Xbox 360 and the other end to a wall outlet. The big power brick needs plenty of ventilation just like the main system so try to have an open space on a shelf for it. It is not recommended that you set it on the carpet.
Once you have everything hooked up, you are ready to go. Press the large circular power button to get things started. If you have a wired controller, plug it into a USB port behind the little USB door. If you have a wireless controller, hold the silver "X" button in the middle of the controller until the upper left quadrant of the system power button as well as the ring around the "X" button on the controller light up. If it doesn't light up, press the controller connect button on the Xbox 360 as well as the connect button on the top of the controller.
If this is the first time the system has been used, you'll have to go through an onscreen setup process. This is simply setting up your player profile, choosing HDTV settings if available, and/or signing up for Xbox Live service. The system walks you through everything.
Now you are ready to play.
Sep 06, 2008 | Microsoft Xbox 360 Console
What do i do if a red ring comes on the xbox
This problem depends on how many red lights there are. The problems can be from a corrupt hard drive, to an overheated console. In this solution, I will mention all problems, and solutions.
1 Red Ring means hardware failure in your Xbox console. It can also mean hard drive corruption. There are multiple solutions to this problem. Turn off your console and unplug every single cord, cable, and memory device on your console. Wait about twenty seconds, and plug everything back in into it's origanal spot, and make sure everything is connected correctly. If the problem still occurs, try unplugging the console's hard drive, then turn on your Xbox 360. If your console then works after this, it could mean your hard drive is corrupt, or broken. Make sure to also disconnect all other memory units out of your console, such as a memory card. If the problem continues, contact Microsoft Support at the following link.
http://www.xbox.com/support/contact
2 Red Rings means that your Xbox 360 console is overheating. Overheating is a common problem with Xbox 360 consoles. Turn off your Xbox console. Make sure it is in a roomy spot, and not near a heated spot. Also make sure it is not on top of a towel, or anyplace cluttered. As seen here,
natesprague6_4.jpg NEVER cool off a Xbox 360 in a refridgerator, or freezer. This may cause further problems to your console.
3 Red Rings means there is a hardware problem, or something wrong with your power supply. To solve this, make sure the color on your power supply is always orange, when your Xbox 360 is off. Also make sure the color is always GREEN when it is on. If it is RED when you turn your Xbox on, try unplugging every cord, cable, and memory device on your console, and plugging it back in about 20 seconds after, and make sure all plugs are connected securely into it's socket. If this does not resolve your issue, contact Microsoft support at the link at the following link,
4 Red Rings indicates that there is no audio/video plugs detected from your AV plug. This is a simple problem to fix. Make sure all plugs are connected firmly into the correct color sockets on your TV. The following colors are the ones that need to be plugged in a Flat Screen TV,
2 Red, 1 Green, 1 Blue, 1 White. As seen here,
natesprague6_5.jpg Although, on a small, old TV, you usually only need to connect the yellow, and white cables. Make sure if you're using an old TV that does not support HD, switch the AV cable to 'TV', if it is switched to 'HD'. If this does not work, you may have to buy a new AV cable.
I hope this helped you, and the Fixya community! Contact me if you're still having trouble!
Jul 02, 2011 | Microsoft Xbox 360 Console
Have XBox 360 Elite and Voyetra Turtle Beach X11 Headset. Got new 3D HD TV and when I attached the HDMI cable to the XBox the headset stopped working. I have been told it is because the cable has an...
I myself have a 46" RCA LCD flat screen tv, which I have my xbox 360 connected via HDMI cable. If your tv has audio out "rca plugs", which im sure being a newer 3d HD tv, connect the supplied cable to the audio out (red, white) plugs, and then connect your headphones to that jack!
Dec 31, 2010 | Voyetra Turtle Beach Ear Force X11 Headset...
My cable from my xbox 360 ,will not connect to my tv as i have only red /yellow/white,connections on my tv ,i am trying to get hdmi,i have tried a hdmi cable from xbox to tv ,what else can i try.thanks.
You are going to need to get another cable. Your TV was not made for HDMI input. The best display you can get is standard definition. It would be cheaper and easier to get a new cable vs. getting an HDMI to Component adaptor. Radio Shack sells these cables pretty cheap. Good Luck!
Respectfully,
Don
Oct 27, 2010 | Microsoft Xbox 360 Console
CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Apr 30, 2010 | Microsoft Xbox 360 Console
I get sound but no picture on my xbox 360
Wiggle the end of the cord a little bit. same thing happened to me
Jun 27, 2009 | Microsoft Xbox 360 Console
Cant connect my xbox 360 to my sony dav-hdx265
Jun 03, 2009 | Sony DAVHDX265 System
Xbox 360
What cables are you using to connect to tv?
There's
1) Yellow and Red+White
2) Red+Blue+Green and Red+White
3) HDMI and Red+White
Cable Couplers
1) 3002 and two 685 rca rgb coupler f/f + rca coupler f/f
2) 3002 and two 685 rca rgb coupler f/f + rca coupler f/f
3)3663 15feet hdmi cable
above numbers can be searched at monoprice.com
Jan 24, 2009 | Microsoft Xbox 360 Console
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Sony DAVHDX265 System Logo
120 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
