Question about Hunter 27185 Remote Control
Tac490 ver 1.1 remote control replacement - Hunter 27185 Remote Control
My access master garage door opener 1/3 hp works with the switch but does not respond to remote. I have reprogrammed the remote and changed the battery.
Do you have another remote? These things do fail new battery or not, if that fails the problem lies in the GDO receiver.
May 10, 2018 | Building Materials
Not playing NTSC DVDs
I can see if there is an unlock code for your device
Apr 21, 2008 | Yamaha DVR-S150 DVD Player
Need an English user manual for our Tadiran TAC490 air conditioning remote
Try Googling (tadiran)(TAC490)(manual) without pares. You may have to refine your search to get a version in English.
May 03, 2018 | Heating & Cooling
Urc 11 3910
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 16, 2014 | Televison & Video
L32V11C -AU dvd unlock code
L32V11C region unlock instructions
All on your remote:
1. Switch to DVD Mode
2. Press the Eject button on your remote (mostly to make sure there are no discs inside)
3. Enter either one of 5 1 6 8 (ver. AA) or 9 7 3 5 (ver. AB) - whichever works
4. When the menu pops up, select Region 0 and press okay
5. Press Exit
6. Enjoy
Jun 03, 2012 | Televison & Video
Cmo se programa un contol remoto dedish para q haga una sola funcion
tengo 2 tv con 2 diferentes controles pero uno no funciona y mis dos tv tienen la misma programacion por decir el control #1 controla las dos y el control # 2 no tiene ningun mando hayer el 1 y2 trabajaban correctamente y podia ver dos diferentes programaciones
Feb 18, 2011 | DISH Network IR Remote Control
I had a IRC 550 starchoice remote and it ran my panasonic home theater system but quit working so I purchased a IRC 551 and couldn't get it to run the audio Shaw suggested i try a ir 600 remote and I found...
SEARCHING FOR YOUR CODE=irc 551
If your home entertainment device does not respond to
the Star Choice IRC 551 IR and Star Choice URC 551 IR/
UHF Remote Controls after trying all of the codes listed
for your brand, or if your brand is not listed at all, try
searching for your code.
For example, to search for a code for your TV:
1. Turn on your TV.
7. To search for the codes of your other devices,
repeat steps 1 through 5, but substitute the
appropriate key (e.g., AUX, DVD, AUD, or SAT)
for the device you are searching for.
Jan 29, 2011 | Panasonic Home Theater System System
Code for Zenega satellite receiver for DishTV DTH service India
dish tv code ver 154 code 15935764
ver 123 code 86427531
ver 155 code 6834
ver old code 9009
Oct 27, 2008 | GE JASRM24912 Remote Control
Televison & Video Logo
667 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
