Question about Kenmore 42822 Front Load Washer
Kenmore HE flashing code F02...not draining. help.
Manual says that f02 is a clogged drain. I pulled the washer out and disconnected the drain hose. I has full of a slimey mung. cleaned out the hose and it still dosent drain too good. What causes the residue build-up in the drain and how do I clean out the line from ote back of the machine down thru the pump (I'm guessing the residue is also inside the machine.
  • bydfort Feb 16, 2009
    i have the same problem, i removed bottom panenel and clean pump the problem is still there F02
    President:
  • Kenmore Master
  • 2,651 Answers
No noeed to clean that justyet, i would imagine that the blockageis in the pump housing itself, you can gain acess to this by removing the lower panel of washer and unscrewing the "button trap"
Posted on Jan 26, 2009
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 23, 2012 | KitchenAid KHWV01RSS
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Stops cycle reads suds or F2
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. "Sud" code flashes 4 minutes after the pump is turned on and 4 minutes later "F02" flashes. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F02 appearing. Not fully draining.
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Oct 26, 2010 | Kenmore 44832 Front Load Washer
F02 error code
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$!$
Jul 24, 2010 | Kenmore 42822 Front Load Washer
Washer has an F02 code in the middle of the cycle, which has stopped, and I don't have the manual.
F02 = Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and
"F/02" is flashed.
The most common cause is a clogged drain filter. Remove your lower front panel. The filter is located in the discharge hose before the pump (often white in color).
Remove the filter and clean out any debris (socks, nails, coins etc..)
If this is not the problem then here is directly fronm the manual.
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the
pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer... code flashes saying 02 F ... Help!
F-02(Long Drain)
HI. This code is an indication of a failed drain cycle(Long Drain Issue). Kindly, follow the steps below to address this issue further.
4. Check the drain pump filter for foreign objects.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After f02 code came up ran a test and get c00 andhttp://www.fixya
Sep 27, 2009 | Kenmore Washing Machines
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite F02 code even after changing to a new pump.
remove compartment cover under the front load door. There is a drain there that will catch large items left in your clothes, ie pens paper etc
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 42822 Front Load Washer Logo
132 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
