Question about Pool & Spa
Can you replace a one speed spa motor with a two speed spa motor
This is what I have and I can only find a replacement part with 2 speeds how does that work and can I use a two speed replacement
  • 372 Answers
Yes, you can use a two speed, although they cost significantly more than a single speed. It surprises me that a single speed motor is not available. Wire the motor for Hi speed, which has the same RPMs as a single speed motor.
Posted on Jan 20, 2013
wayneard
  • 1901 Answers
SOURCE: What does SF mean on pool and spa pumps?
SF stands for Service Factor. It has to do with how much overload your motor can handle without damage. Here is some information about it:
http://www.engineeringtoolbox.com/service-factor-d_735.html
You should not be feeling any "trickle" of electricity. You are correct...it is NOT SAFE! I would definitely have another qualified electrician check your wiring out.
Thanks for using Fixya.
Posted on May 16, 2009
SOURCE: Pump will not work in high speed
Clean the relay contacts on the board. Cut the power, ofcourse. Also, try switching the hot wire on the low side of the pump to the high side to rule out the pump.
Posted on Jun 08, 2009
  • 3600 Answers
SOURCE: Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Posted on Jul 05, 2009
muralme
  • 20 Answers
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
SOURCE: I HAVE A CENTURY LASAR POOL/SPA MOTOR W/ A HIGH
Faulty centrifugal switch, internal, faulty, temp sensor, internal, faulty start run capacitor (If used). bad brushes, (If any) Faulty Winding.
Posted on Feb 03, 2010
How to replac bearings in century pool & spa motor
if bearings are bad motor overheating and ruining seals replace whole unit less hassle
May 10, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Replacing plug on a 2 speed magnetek 1.5 hp motor
More often than not red is high and black is low. The white is the common and of course green is ground. If High and low are backwards, swap the red and black.
Jul 31, 2009 | Pool & Spa
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Pump will not start on low speed
It sounds to me as though there may be a problem with the small run capacitor on the motor. If that has failed the motor will fail to start on low speed.
The motor shop should know what they're doing as this is a common motor issue. Take it back to them and explain the problem to them.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Jun 02, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
High speed spa pump shuts off
Pump speed Selector Switch Contact Probably Missing, Checkout
Feb 01, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Pool & Spa Logo
73 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
