Question about Graco Baby Gear
Brakes do not work.
Just bought and assenmbled graco dynamo lite (Carolina) model. Both brakes do not work. we thought that maybe we attached the rear axle backwards!? we tried to re-assemble axle ( with attached breaks) but axle has clicked in place and will not slide out. Also, it looks like the parts on the axle, that is supposed to break the wheel faces inward on axle, not towards the wheel. Maybe bad part? We are stuck! Please help.
SOURCE: Hoover Floormate wheel assembly
In replacing the front wheel assembly, I incorporated a couple of hints from here - first, taking the gray top off by releasing the 6 tabs - 2 front - 2 back - and one on each side - carefully. Then stand the machine up - you need to remove two screws on each side, by the rear wheels and pull those black pieces up some so you have room on the under side for the wheel assembly round things that hold the assembly in place. Turn the machine over and work the round tabs on the assembly in the holders - you need to work it, putting the longest side in first. After getting that in place, carefully - carefully - align the screw thing in the front to where it is suppose to go and carefully work it in place by pushing the screw head carefully through the hole on the arm where it belongs. Be careful not to break anything! After your assembly is in place - stand the machine up and get those black holders along side of the rear wheels back in place and screw them in - 2 screws each. Then carefully snap the gray piece back in place and you are good to go. I don't have a parts list to know exactly what all the names are for the parts, but I hope you get the jest of it. I tried not to use words like do-ma-hicky and thing-a-ma-jig (I'm a woman) haha
Posted on Jan 23, 2008
  • 98 Answers
SOURCE: rear brakes uneven breaking as per mot tester
The Chardes have a diagonal split system, so one of the front discs is plumbed to the diagonally located rear drum.
You may need to check the front brakes too and that they have been bleed properly.
Other common cause of uneven braking are:
seized wheel cylinder;
brake hose obstruction or weakend wall;
weak pull off spring on shoe;
uneven drum roundness;
compensator/proportioning valve dicky.
Posted on Oct 07, 2008
  • 32 Answers
SOURCE: My Graco stroller model -
You can order parts here:
http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Posted on Nov 18, 2008
losflip
  • 94 Answers
SOURCE: Having difficulty removing rear brake drum on 2003 Suzuki Aerio.
Yes the phillips head screws have to be removed, on some models there are two more holes in the face of the drum to insert threaded bolts to remove the drum, simply thread the bolts in to remove the drum.
Posted on Nov 25, 2008
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
Contact Graco directly...the will send out a free replacement wheel. The whole unit comes together and snaps on.
Posted on Feb 08, 2009
Mower wont move forward or backwards and makes a ticking noise when pushed.
Just a thought , maybe the key that locks the pulley to the input shaft on top of the transmission has sheared and the pulley is just spinning on the shaft or the key on the axle shaft that locks the wheel to the axle and that would allow the brakes not to work.
May 19, 2016 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How do you remove swing arm on a 99 yamaha big bear 350
Easy - take off tires, then caps over axle/castle nuts if you have them.
- take cotter pins and axle nuts off both ends of axle. Right side - remove brake drum, then remove two brake shoes, simple Springs connect them, you can pull apart intact, remove any collars, washers off the axle behind brakes, then there might be 4 bolts and a plate - the other side you can see the bearing. Now - this is important - for. The side with the brakes, take a socket bigger than the threads but size of axle lip - and you place that deep socket (side with brakes!) over the threads (threads will be inside deep socket) lip of socket touches lip of axle about 2-3 inches down - hit that w a hammer and the axle will go out to the left if facing rear of four wheeler. Next - remove brake lines and breather hose for rear end.
There are bolts that attach the rear end to the swing arm (to the right) take them out and maybe the bottom guard for rear end. Then where the rear end attaches to drive shaft tube portion of swing arm there are four bolts - when all that is done you'll be able to remove rear end. Undo top bolt or you might get away w/bottom for shock - next two pivot shaft nuts - big socket like, Allen head in middle - remove nut from pivot shaft (left and right side where swing arm pivots) then takeallAllen head and unscrew two thick bolts that the pivot shaft nuts tighten to our - there's a collar and bearing in there where the bike's swing arms pivot at. I've done it a dozen times - if you have any problems or that wasn't too clear, message me, I'll dig up some tech sheets from a service manual I got on a bike that year - close to same model - same mechanics, Yamaha was pretty universal. I got a 98 & 99 Yamaha 2wd and a 96 Yamaha 3504wd. All pretty easy to work on. I have a swing arm I might get rid of from Florida and a decent rate if yours is done for and you gotta replace. I sell and buy off eBay to keep most of my toys on the trail.Good luck
Nov 20, 2014 | Motorcycles
Graco Ready2Grow stroller rear axle brake broken
Graco Customer Support is available Monday through Friday, 8am to 5pm EST.
800-345-4109 (US)
800-667-8184 (Canada - 8:30am to 5pm EST)
Graco UK & Ireland
Halifax Avenue
Fradley Park
Lichfield
Staffordshire
WS13 8SS
Consumer Service Desk (UK enquiries only)
Dialling from UK: 0844 412 1212
Dialling from ROI: 0818 221 422
graco.info@newellco.com
Note: When emailing, please mention the model number which can be found on either the rear left leg or under the footrest.
Apr 16, 2013 | Graco Ready2Grow LX Baby Stoller &...
Seprate hub from knuckle broken stud
If you look behind the hub assembly, you can see where it is bolted in with four bolts. You will have to take the axle nut off so the hub assenmbly will slide off over the cv axle. This will mean that you have to remove all the brake components also.
Jul 30, 2011 | 1995 Dodge Caravan
Graco lite rider navigator SL stroller broken seat holder clip
I've got a navigotor stroller and I can't unlock the back wheel brake or fold it
Dec 09, 2009 | Graco LiteRider 6712SFT Stroller
I have a 94 jeep wrangler front left axle seal bad. I took the left side apart and not sure how to get the seal back in. Do I need to open the inspection cover on the diff. and take the gears out?
Rear Axle Notes
  1. Raise and support vehicle.
  2. Remove rear wheels.
  3. Scribe alignment marks on propeller shaft and axle for proper assembly, then disconnect propeller shaft from axle.
  4. Disconnect the track bar from axle mounting bracket.
  5. Disconnect parking brake cable at equalizer.
  6. Disconnect shock absorbers at axle tubes.
  7. Disconnect hydraulic brake hose at rear axle Tee-fitting, then tape ends of hose and fitting to prevent contamination.
  8. Disconnect axle vent tube from axle.
  9. Remove U-bolts and tie plates.
  10. Loosen spring mounting bolts.
  11. If equipped, disconnect ABS wiring connections at axle.
  12. Support axle with suitable jack.
  13. Remove spring-to-shackle attaching bolts and lower spring to the floor.
  14. Remove axle assembly.
  15. Reverse procedure to install.
Front Axle Notes
  1. Raise and support vehicle at frame behind front springs.
  2. Remove front wheels.
  3. Scribe alignment marks on propeller shaft and axle yoke for proper assembly, then disconnect propeller shaft at axle yoke.
  4. Disconnect connecting rod at steering knuckles.
  5. Disconnect shock absorbers at axle housing.
  6. Remove stabilizer bar connecting links to spring tie plates attaching bolts, if equipped.
  7. Disconnect breather tube at axle housing.
  8. Disconnect stabilizer bar link bolts at spring clips.
  9. Remove disc brake calipers, rotors and brake shields.
  10. Remove U-bolts and tie plates.
  11. Support axle assembly with suitable jack to relieve spring tension.
  12. Loosen rear spring shackle to spring attaching bolts.
  13. Remove front spring shackle to spring attaching bolts and lower spring to floor.
  14. Remove axle from under vehicle.
Jul 21, 2009 | 1994 Jeep Wrangler
Broken rear wheel on graco duo stroller
You can order replacement parts from the Graco website.
Go to the Help Center, then Order Replacement parts. You'll need the model number and serial number or manufacture date. Site helps you locate the information on your product.
Jun 09, 2009 | Graco DuoGlider 7444 Twin Seat Stroller
Instruction manual for Graco - Sarah 4-in-1 Convertible Crib, Che
My wife and I bought this same crib. We thought the same as well. We looked everywhere for the instructions- so we thought. We finally found someone to call and ask for help and she told us to
" Look in the box that has the mattress springs in them. The instructions are normally attached to them."
As I was on the phone with the lady helping us, I opened the spring box and there they were attached to it inside a white envelope.
Jan 08, 2009 | Graco Ultra Deluxe 5-in-1 4605 Crib
Rear Brake Proportioning Valve
did you ask GM (trackers are GM) not all parts are same GM tracker to sidekicks ( i can name many)
suzuki sells it. and try car-parts.com for wrecker used sources.
used brakes , hummmmmm
96 is a major year, change, so watch out of wrong answers.
there are 2 valve, 2door and 4
suz pn is.
4 = 51930-56B20
2 = 51930-60A40
dont by the wrong one, or danger awaits you. and thin wallet.
1 of 2 valves here.
http://www.oemsuzukiparts.com/parts/index.cfm?make=Suzuki&year=&searchText=51930-56B20&action=oePartSearch&siteid=214330
Nov 14, 2008 | 1996 Geo Tracker 2 Door
Baby Gear Logo
77 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
