Question about Black Bull Air Tools & Compressors
My Black bull 4 gallon 5.0 CFM 2 HP air compressor will not start. Regardless of whether the on or off position is selected, all I get is a humming sound for about 2 seconds, then it goes silent. After a moment, the humming starts up and stops again. The startup was attempted at 50 degrees F., no extension cord, oil level at proper level. The unit is only 1 year old and only used three or four times to inflate tires. Solution?
I need the diaphram in the On/Off pressure switch on a Black Bull- 4 Gal., 2 HP, 5.0 cfm @ 90 PSI 120 v /13.8 amp . Batch # 0911. These are the only # I can find
Posted on Apr 14, 2016
virgils
  • 39 Answers
SOURCE: craftsman air compressor, oil build up in the air line
worn compressor rings, not a real issue, I assume it is more of a build up over time, say a gram of oil is blown into the lines every year, well one gram would not be noticed nor two but since it soes not evaporate it builds up to the point that you can see it, some oil is blown by brand new compressors and over time gets to be more and more, but as long as you are still getting full pressure you do not have to service the compressor, but since this is being used on water pipes I would install a trap inline to catch the oil
Posted on Oct 13, 2008
SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Posted on Nov 26, 2008
  • 47 Answers
SOURCE: Husky 1.5 HP 6 gallon compressor motor runs but
Your manual pressure release valve might be stuck open or blocked open by some debree. It should have a steel pull ring on the end of it. Exercise it and try running it again. Also the pressure regulator adjustment might have been backed off to zero. Crank it clockwise and see if this helps. Check the air output lines from the compressor to the tank for leaks.
Posted on Jun 22, 2009
Milrite
  • 79 Answers
SOURCE: air compressor struggles to start but eventually starts
If the proplem only happens after the initial start-up with the tank empty, then your back flow valve is sticking and preventing the compressor from kicking over imediately. If it does it all the time, even when the tanik is empty, then your capacitor on the motor is not charging correctly.
Posted on Jan 17, 2010
  • 36 Answers
SOURCE: Compressor will not run
could be the capacitor, also try looking at the wires around the windings
Posted on Jul 30, 2010
I just bought a craftsman pneumatic 1/2-in drive impact wrench. And used it with my craftsman 4-gallon 1hp air compressor tried to loosen the bolts on my car wheel wouldn't loosen them help
Pneumatic tools are rated in cfm (cubic feet per minute). Your 1 HP air compressor is rated at probably not more than 3 cfm while the 1/2 " impact driver needs at least 8 cfm, maybe 12 chm of air.
The compressor must provide more chm than tool rating needs.
It is a problem, by the time you look at five horse power air compressors and larger, a lot of electric power is needed. A circuit of 220 volts, 20, 30, or more amps would be required to run those large expensive compressors.
If you can, return the air tool and get a good electric tool instead.
Leave those high air volume air tools to shops that are so equipped to use, or invest if you must.
Jul 24, 2017 | Craftsman Air Tools & Compressors
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
Why won't my compressor start?
If it's new I would return it. However that model number 16638 is for a Huffy Bicycle.
Sep 06, 2014 | Craftsman 1 hp Air Compressor, 4 gal. -...
What grade of oil do air compessors use
iso 32 // 30wt. compressor oil, or no additive mineral oil, never use automotive oil in a air compressor
May 06, 2014 | Eagle C5160v1 - Single Stage - 5hp 60...
All Trade 5 Gal just humms wont turn on
The start capacitor has gone bad. Needs to be replaced. That's what's inside that bump on the side of the motor.
Mar 25, 2013 | Alltrade 830241 5 Gallons 3 HP Twin Tank...
Question is whether to get an Kobalt 80 gallon 14 CFM at 90 one stage or a 60 gallon IR 18CFM at 90 if the price is the same and CFM is not the issue, but the quality of the item?
your choice of an air compressor should be based on what you are going to be using it for first of all .single stage compressors are good for about 125 psi 2 stage up to 175.which whatever one you choose do not get a oilless they wont last .you want a cast iron pump which requires oil lubrication.pumps which are made of aluminum are throw a ways
Aug 04, 2010 | Air Tools & Compressors
I have a Cleman 4 Gallon, 1.75 HP, Powermate air
When mine hums and trips, it is one of two things, Not warm enough, only does this when it is cold out, and 2 would be not enough juice, I have to have a 20 amp breaker or it doesn't run. And if I use a cord, it has to big. The slightest drop in amperage and it will not run, yours might have the same problem, mine is only 1 1/2 HP. It draws some 16 amps at start up and then idles down to 13 to run. A 15 amp breaker, forget it. Cold out, forget it. It wasn't just mine though, we did a house last winter and made one bathroom heated with a gas heater with 3 compressors in there just to keep them warm, there was no room for us. Hope this helps.
Jul 20, 2010 | Coleman Powermate 11 Gallon Air Compressor
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Compressor Support
Home Use: Compressed-air power tools can dramatically decrease the amount of time spent on a project. Many homeowners will use smaller, portable units (either hand-carried or wheeled) that move easily from the garage to the house, yard or roof. Common air toolsAir Tools such as brad nailersAir Nailers, reversible drillsAir Drills, and impact wrenchesAir Impact Wrenches require about 0–5 CFM (Cubic feet per minute — units in which air flow is measured). It's important to know if the compressor you purchase will drive the air tool you'll need for your project. For example, smaller air nailersAir Nailers run on 2 to 5 CFM at 70 to 90 PSI, while larger shearsShears, sandersSanders and polishersPolishers require up to 10 or more CFM and 100 to 120 PSI. Business Use: Air compressors used for business/professional applications are often classified “industrial grade.” They're packed with features that let you take on more demanding jobs with more horsepower, more CFM, more PSI and more (longer) run times. Though some industrial-grade compressors are portable, many are stationary units with large-capacity, ASME certified air tanks (up to 120 gallons), greater HP, more CFM air volume and faster recovery time to run a wide variety of air tools for as long as you need them to do the job.
Aug 27, 2008 | Jenny Products Inc AM780-HC4H 4 Gallon...
Air Tools & Compressors Logo
702 people viewed this question
Top Black Bull Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Black Bull Air Tool and Compressor Expert? Answer questions, earn points and help others
