Question about Electrical Supplies
ITE Imperial EQ8S&F panel.
I need to install a 220 VAC circuit for an electric dryer. What breakers will fit this panel?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Well only one due to insurance ITE, but there are 3 others that would work in a bind.Siemens,Westinghouse, and Cutler hammer.
Posted on Apr 07, 2013
Application
Use siemens for old ITE breaker box.
Square D will not work:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment and describe product, and attach photos.
May 26, 2013 | Square D Co. HOM130C Circuit Breaker
Will a Siemens ITE Q1515 15 amp tandem breaker fit into a 200amp Siemens Series E panel G4040ml1200?
yes it will, you need to always make sure that you put the same brand in the panel box, good luck
Sep 18, 2011 | Siemens Ite Twin Q1515 Circuit Breaker...
Dryer is tripping all electric in the garage everytime it is put on any ideas why? (looked at plug, checked wiring, changed fuse, emptied water and fluff filter)
First of all, if your dryer is tripping ALL the electric in the garage, you may be overloading the circuit capacity of the garage service. A major appliance such as a dryer should have its own dedicated circuit. That is, a circuit that ONLY the dryer is connected to with a separate service breaker. You may not have a problem with the appliance at all. It may be just be a matter of overloading. You should have a 220 VAC circuit breaker rated at a minimum of 30 amps for an ELECTRIC dryer. Or, a 120VAC circuit breaker rated at 15 to 20 amps for a GAS dryer.
You may also want to check to make sure you have the appliance wired correctly. If this is an ELECTRIC dryer, the following link explains how the appliance needs to wired:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have a GAS dryer, it should use a 110-120VAC configuration using either 14 gauge wiring for a 15 amp breaker and 12 gauge wiring for a 20amp. The power cord should be of the three-prong variety (HOT, NEUTRAL and GROUND). The color code for the wiring is as follows:
BLACK - HOT (110-120VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND (Usually wired to a terminal lug at the terminal block on the appliance)
If you're dryer is already configured with a dedicated circuit breaker, please post back with a MODEL NUMBER and WHICH fuse you are referring to that is blowing. I hope this information is helpful.
Apr 25, 2011 | Dryers
I have an ITE breaker panel (G2020MB1100) with Q115 breakers, but need to add a 15 amp circuit. Will a Q1515NC fit into one of the Q115 slots?
Yes they will fit. They are both a single pole breaker. Turn the breakers over. They should look the same and snap into a single slot in the panel the same.
Not sure what you mean by No Clip? A Square D QO Breaker has a metal clip that snaps into the panel on the breaker mount and one on the Bus Bar.
Feb 22, 2011 | Siemens Q1515NC Circuit Breaker Two1Poles...
I need to buy a 20/20 Amp Bulldog breaker for a dryer and any installation tipes
Most electrical dryers are 220 volt. They usually require at least a two pole 30 amp circuit with #10 wire. The breakers you need can be found at most hardware and buidling type stores, Ace , Home depot, Lowes.
Yes they would have the 20/20 breaker also.
Please Vote !!
Apr 24, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
Installing a 220 circuit breaker
First you must have space for a double pole 30 amp breaker in your panel.
Otherwise is is almost the same as the one you installed before, exception is 2 hots both going to the breaker.
The green goes to ground. The white goes to neutral. The black and red go to the breaker.
Mar 13, 2009 | Whirlpool LER5636P Electric Dryer
Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
Jan 23, 2008 | Dryers
Electrical Supplies Logo
113 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
