Question about Charging & Starting Systems for Daewoo Leganza
There is a light on dashboard saying "check" but it does not say what to check. Also it is revving between 1 and 2 when stationary
  • 60 Answers
Sounds like a vacum leak in or around your manifold, maybe EGR valve...
Posted on Jan 22, 2013
My car is over revving going to 1000 rpm at idle what is it please help Audi A3 s line 2.0 tdi
Revving on Idle ' Audi-Sport.net
www.audi-sport.net > ... > A3/S3/Sportback (8P Chassis)
Feb 1, 2012 - My Car 58 S3, as of last night decided to start revving whilst on idle, I found a clip ... I can do or is it going to be a trip to audi for them to pull my pants down! ... Lots of members all over the UK have VCDS, have a look at the VCDS .....and as the engine warms up it'll auto-rev to 1000rpm every time i sit at idle. Car revving itself on idle ?
Sep 23, 2013
Whining noise when accelerating, any ideas?
Mar 15, 2012
More results from www.audi-sport.net
[FIXED] Audi A4 RPM Idle Problem - YouTube
? 2:48
https://www.youtube.com/watch?v=EG71Jz9l6qY
Feb 5, 2011 - Uploaded by RickyTomatoes
[FIXED] Audi A4 RPM Idle Problem .... whole lot more and sometime i can even feel like the engine is just gonna die. sometimes it does it some other times it does ... Our cars shouldidle at 900. ... AUDI A3 1.6 IDLE PROBLEM!
When getting into first gear, is revving to 2000 RPMs before ...
https://www.reddit.com/.../cars/.../when_getting_into_first_gear_is...
RedditSep 3, 2014 - When getting into first gear, I bring the revs up to around 2000 RPM right ... Being able to get going without any throttle is fairly dependent on car size and ...Thats how I have a 300,000 kay clutch still on my audi with no slippage. ... Clutches ought to last well over 100,000 miles if they are not abused, and ...
Revs going up and down while car is stationary - AudiForums.com
www.audiforums.com > ... > Audi Models > Audi A4 > B7 Models
Jan 21, 2016 | Cars & Trucks
I have a 2006 Scion XA. Few days ago noticed revving sounds while driving the car. Originally thought engine was revving but noticed RPM gauge is normal. The humming/revving sound starts about 20 mins...
under the bonnet on the radiator is an automatic fan, now if the radiator is low or you need to replace the coolant in it or top it up but the car may need a service and let them know the problem.
Jan 27, 2014 | 2006 Scion xA
Engine revving itself
Sounds like you have a vacuum leak .check the vacuum hose that goes onto the throttle body
Jul 27, 2013 | 2004 Opel Zafira 2.0
1 month ago replaced catalytic (sp?) convertor, battery, starter switch and now the check engine light came on and the car is revving high at times while driving
replacing these items won`t cause your problem.you will have to find out what code set the light and go from there.you don`t say if the revving is at idle or not if it is you could have a bad idle control motor or a cracked vacuum hose that acts up at certain times.even a bad throttle position sensor(tps),egr valve,so its important to know what set the light on.
Mar 28, 2011 | Toyota Camry Cars & Trucks
Car with spanner on dash &willnot rev more than 3000 revs
Hi there. Usually the car with spanner you describe on your dashboard could be 1 of 2 things.
1 it could be your engine management light (meaning there is a fault somewhere in your engine)
2 it could be your service light (meaning your car is due a service)
The only way you will be able to find out exactly what this simbol means is by looking in your cars manual (usually a black book that comes with your car)
Due to your car only revving upto 3000revs, This could be a number of things.
1, lift your bonnet and unscrew the oil cap (yellow cap with oil logo on it)
If there is a mustard coloured residue on the cap and inside the engine, your head gasket is going or it has blown. (This is usually the main cause of your car only revving low and very expensive to fix.)
2, there may be a problem along the exhaust (a hole in the exhaust or broken joint , not so expensive to fix)
Hope this helps and please rate. If you need any further assistance please feel free to comment and i will get back to you asap.
Mar 16, 2011 | HP Vectra VEi7 (D8131T#ABA) PC Desktop
1999 toyota corolla (manual) 153,000 miles 1. check engine light on (blinks when engine jerks) 2. engine jerks when accelerating, but runs smoothly when revving while stationary what could be the...
You should have this problem scanned as soon as possible. Usually when the engine light comes on, it means you have a problem But if it blinks its a warning that u should pull over and shut it off to prevent damage to your engine & its parts. It sounds like a fuel injection/emissions problem. I ignored this problem once & it melted my catalytic converters!
Jan 10, 2011 | 1999 Toyota Corolla
Renault Espace ABS light on constantly, break fault/stop light
hi abs light indicating you have sensor down on brakes or master cilinder is on its way out,try checking sensor will need to go to a back street garage cheaper
Mar 19, 2010 | 2005 Renault 18I
On the dashboard circle that shows the numbers that tell how the engine is revving (?), etc...a red light has been coming on and then going off a few minutes later...symbol: small black arrow pointing down...
Red lights are always a warning of some kind. In this case you don't mention the make or model of car but I'm willing to bet it means the water level is low. Check the coolant level or the washer bottle level.
Nov 04, 2009 | 2001 Saturn SL
When my car goes up a slight incline, it remains stationary and sounds as if it's in neutral...I shake my stick gear and then it goes. Same at a red light, when I go to drive again, it's stationary and the...
if its making a wierd noise when you press the clutch in and let it out again i would say it is your thrust bearing in gearbox. if it automatic i would check your linkage between engine and bulkhead(back part of engine bay) as this is where it connects.
Mar 05, 2009 | 1989 Ford Festiva
I would guess the idle control/stepper motor.
I think you could pic one up cheap at rockauto or ebay
Feb 12, 2009 | Hyundai Elantra Cars & Trucks
Charging & Starting Systems for Daewoo Leganza Logo
Top Daewoo Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Daewoo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
