Question about Amana D565e Dehumidifier
No water runs but will not pull water into tank
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    Unit runs constatntly, but is not pulling out any moisture. tank barely has any water in it
    There are many reasons why a dehumidifier willnot work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
    Dehumidifier is running but no water is in bucket
    heatman101
    Aug 06, 2011 | Whirlpool AD25BBK Dehumidifier
    The water won't run continuously out, instead the tank fill up. I have it set up to run continuous but the tank keeps filling up. I have the Westpointe dehumidifier.
    Some dehumidifiers don't require that the bucket be in place, when a drain hose is attached to the unit. I'm not sure that's the case with yours, because I'm unfamiliar with the Westpointe brand. You should also check the drain connection that the hose is connected to. It may be clogged, which forces the water into the bucket instead of draining through the hose. If you have something flexible like a long plastic Zip Tie, that can easily be run into the hose connection and slowly pulled back out, while rotating it should loosen any clogs. Be prepared for water to follow. Do not use a wire coat hanger to do this and be sure the unit is OFF and unplugged from the wall, before attempting it.
    Hope this helped you to troubleshoot and solve the problem. Please let me know.
    May 03, 2011 | Midea MDC-45AE Dehumidifier
    The water is not going into the collection tank and just leaking all over the floor
    When you pull the tank out and look on top-right of the underside of the machine, (image being on top of the tank while it's sitting in the dehumidifier), can you see the nozzle properly sitting there? Imagining that the collection tank is inside of the machine, the water should be dripping directly out of that nozzle, into the tank. Also make sure that nothing is attached to that nozzle, cause the water to be redirected elsewhere.
    Aug 04, 2010 | Kenmore 54501 Dehumidifier
    My 40 pint Soleus dehumidifier doesn't pull any water into the tank even though the fan blows normal.
    There are many reasons why a dehumidifier will not work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
    heatman101
    Jun 18, 2010 | Soleus CFM-40 Dehumidifier
    Not removing water and says tank it full
    I just had one giving me the somewhat the same problem. Upon taking it apart I found that the entire inside was filthy. This thing runs in a work area in my basement and sucks up all of the dirty air. When you take the water out of the dirty air you have nothing but the dirt and the water. When you mix those together you get mud which is what clogged everything up in mine.
    Dehumidifiers need to be clean on the inside to run properly especially all of the fins on the condensor. You will probably have to take it apart and clean it. Concentrate on the fins and the water collection areas. Dehumidifiers remove heat from the air which causes the humidity to collect on the condensor. As it collects it turns into water droplets. Gravity pulls the water droplets into the water collection areas and that flows to your tank. There is some sort of float in your tank that lets the dehumidifier know it is full and shuts it off with some sort of switch. It does this so it does not just keep running and eventually pour water onto your floor. It sounds like your switch and/or float is stuck. Find the float and switch and manually work them to make certain they are working freely, clean if necessary.
    If the dehumidifier does not remove water like it should it is probably not getting good airflow. There are ice sensors on the evaporator that tells the compressor to stop working. However the fan will still run to pull warm air across the ice so that it melts, goes into the water collection area and into your tank. Some of these ice sensors work by measuring air flow. If there is no air flow or very limited air flow the sensor will tell the compressor not to work. The fan will run again to melt the ice so that it melts and is removed. If your condensor is dirty and does not allow the air to flow, this could cause your problem.
    Mar 24, 2010 | Danby DDR6588EE Dehumidifier
    Humidifer will not work , runs fine all lights are correct but pulls no water into tank
    feel the coil in the back, is it cold, if not you don't have any coolant, may have a small leak. if so some appliance repair people can resoder
    Jul 07, 2009 | DeLonghi Dehumidifiers
    Dehumidifier running but no pulling any water from the room
    Check float switch some of the unit have afloat switch hooked to the unit. Next check the condenser coilsThey do get stopped up cat,dog hair and just plain get dirty vaccuum them out and try unit. Rusty
    Jun 12, 2009 | Bionaire BDQ24 Quietech Dehumidifier
    Danby DDR451 water tank
    I had this to. Check to see if there is any packing tape just above the tank. The tape on mine was not tapping the tank shut; it had been there for a year (not interfering with anything), but i pulled it all out anyways, and the tank let go!
    that's what worked for me... hope this helps
    Mar 08, 2008 | Danby DDR451 Dehumidifier
    Amana D565e Dehumidifier Logo
    Top Amana Dehumidifiers Experts
    jasbo
    jasbo
    Gil Shultz
    Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
