Question about Westinghouse Televison & Video
My Westinghouse flat panel tv model cw40t2rw needs a code to scan basic channels. Called Westinghouse for the code and I'm getting the run around. My tv is ATSC and not QAM. Any help would be gre
My model # is cw40t2rw
SOURCE: User Manual for (Dynex) DX-LCDTV19
Go to the Dynex web site. Type your model number in the search box and follow the link to the user manual.
Posted on Jan 06, 2009
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
  • 280 Answers
SOURCE: how to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Posted on Jun 16, 2009
SOURCE: Venturer TV
to program the direct tv remote to any non listed device, press and hold the tv button until all lights stay lit, then press the small red tv power button, then press the channel up button repeatedly until the tv turns off, then press the red record button. may have to find the best code that wokrs all functions by repeating the above steps several times-
Paul
Posted on Jul 01, 2009
  • 7 Answers
SOURCE: Scan No Longer Working
Do you have Verizon? The problem you are having is a long standing issue with Verizon. It was recently corrected for some of us. Certain TV's could not receive QAM channels, because of a Verizon caused issue. They blamed the TV manufacturer and the manufacturer blamed Verizon.
My TV's are Sharps, but I recall Vizio as also having the problem. Although it was fixed in my area MA, and in the Philadelphia area, other areas are still reporting the issue My problem disappeared shortly after the recent channel realignment.
Here is a link to a lengthy thread on the subject at the AVS forum;
http://www.dslreports.com/forum/r19439993-QAM-Changes-from-Philly-VHO
Posted on Jul 17, 2009
Wesinghouse digital llc Model #cw40T2RW wont turn on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 18, 2017 | Televison & Video
Model cw40t2rw. Why is there audio but no video?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 27, 2015 | Westinghouse Televison & Video
I need a channel access code to set up my tv.
here is the number to call to get a code,
Jan 19, 2015 | Televison & Video
Need remote code for CW40T2RW
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 22, 2014 | Westinghouse Televison & Video
Please run scan/ how?
You should have a menu button that will get in into the next menu for initial setup. It will be under something like channel search or channel scan.
Apr 09, 2014 | Westinghouse Electric LD-2655VX 26 in. TV
Westinghouse auto scan
Obtaining and using a replacement remote might help.
Mar 03, 2014 | Westinghouse Televison & Video
Westinghouse cw40t2rw. installed new main board & now picture is upside down. Is there a service menu function cure this and if so how do I access it
That is a vertical problem turn the yoke around or switch the vertical wire and that will solve the upside down picture
Feb 13, 2014 | Sceptre X37sv-Naga 37 in. LCD Television
Needing the channel access code for a westinghouse tv model DW39F1Y1 serial number 7532V33500473
I need Code the Channel Access, WestingHouse Tv
Modelo: DW39F1Y1
N?mero De Serie: 7531V34300250
Jan 04, 2014 | Televison & Video
Televison & Video Logo
459 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
