Question about HP Officejet Pro 8500a Plus All-in-one Inkjet Printer W/brand Color Ink
HP Officejet Pro 8500A failed alignment - HP Officejet Pro 8500a Plus All-in-one Inkjet Printer W/brand Color Ink
5 Suggested Answers
  • 25 Answers
SOURCE: HP OfficeJet 6110 xi Self Test "Align Cartridge" Failure
Hello there,
Try cleaning print cartridges from HP toolbox
or reset process
Please see note at bottom re: powering on and off
1) If you know you are going through the re-set process. Ensure there is nothing in your printer que already when you want to power on again.
2) Plug printer/scanner directly into the wall, not a power bar or UPS... Read at one point, it has something to do with the electricity (KW or Voltage or Amps) factor and power requirements to the printer/scanner. However was very technical and don't remember enough details to explain properly, sorry... Anyhow, directly into the wall.
This is what has worked for me. Got original re-set process of solution from sillygirl.
3) Disconnect all cables from printer.
4) Clean the glass on top with alcohol and cotton swabs.
5) Then go through the reset process (press # 6 while plugging the power back into the printer).
6) If you have the CD for your printer it doesn't hurt to put it in your CD carriage in case your printer is looking for files or drivers. If CD starts to go to a un-install or full re-install just cancel and leave in carriage.
7) Sometimes helps if you first plug printer in.
8) Re-boot pc before powering on printer. Once re-boot has started and PC will start to look for printer.
9) Power on printer (press # 6 while plugging the power back into the printer to re-set).
10) Watch for point where your printer icon usually appears and plug the USB into the PC.
_____________________________________
11) If this does not work then take the printer apart and clean the underside of the glass as well. Unfortunately need to go through re-set process again. May need to buy a set of screw drivers for removing the glass. They are different. (Torx)
12) In another solution it states - you must clean all the mirrors inside the scanner assembly q-tips work well (black box closed with two locks) also the lens and the delicate spaghetti-like lamp. Generally this works... Not everyone has done this part but worth a try when the printer is already open.
13) There is a black and white strip at that end of the scanner. Check to ensure the strip is there, in tact and placed correctly. This is what the scanner carriage aligns itself with.
Just so people know. I have posted solutions to this before that have worked for me. However, I really do think this comes down to a driver issue (do we all have XP, mine is actually XP Home Edition). Since HP no longer updates these printers not sure if we will ever see a driver that works perfectly. Once you get it going again it will all work great. The problem lies in powering on and off. Once you get it going without the scanner carriage jamming, leave it on! Even in the case of a power out I usually have to re-set again but can get it going, eventually (it can be very frustrating). Sometimes need to re-boot PC and plug USB into the PC while booting up and just about to look for your printer. This is to ensure it finds the printer/scanner. Also, when really desperate uninstall and re-install the hardware. Sometimes can try for quite some time to get it working again and eventually have to just leave it off for a few days then can get going again afterwards. Not sure if this has something to do with memory.
Posted on Feb 28, 2009
  • 73 Answers
SOURCE: i installed recently HP officejet
Hi There, This is a known issue with this device. Please follow the below steps to fix this issue : Try to do a complete uninstall
*first step*
-run installation media (CD / Download) software
-select uninstall and on the process, select uninstall all hp softwares associated the with the device
-after uninstall , select restart later to reboot the computer later
-go to start > control panel > add/remove programs (XP) programs (Vista)
-uninstall any existing HP softwares (note: for hp computers, skip this process)
-restart later
*2nd step*
-open contents of the installation media
-if you're using the installation CD. go to my computer, select the drive which has your cd in (eg. E:/ , D:/ ) right click on the icon and select open / explore.
-if you're using a downloaded software, click on start and click on run (XP) startsearch (vista), on that box, type in the command ( %temp% ) and press enter. it will open up temporary files folder.
-locate the file that starts with 7z (eg. 7z001cs1) and open it and now you are in the contents of the installer
-on the contents of the installer, locate UTIL folder and open it then locate CCC and open it as well
(note: check your operating system if it is running on a 32-bit or 64-bit . you can check it going to start>control panel>system)
-on CCC folder , locate uninstall L1 (for 32-bit) uninstall L1 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
-on CCC folder , locate uninstall L2 (for 32-bit) uninstall L2 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
on CCC folder , locate uninstall L3 (for 32-bit) uninstall L3 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later (repeat uninstall L3 steps for 3 times)
**********important**********
(do not run uninstall L4)
contiunued in the next post ..............................
Posted on Nov 14, 2010
SOURCE: My officejet pro 8500A prints black vertical lines
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Posted on Oct 18, 2011
  • 6 Answers
SOURCE: officejet pro 8500a plus adf broken
I work for an authorized HP dealer and I just checked HP parts and they do not appear to have any parts for the ADF on this model. You could check Ebay for a used unit or one being sold as is that has a working ADF.
Posted on Sep 21, 2012
Hp officejet pro 8500a shows cleaning print head/alining print head
that might be your printing settings and laptop file formate
Mar 17, 2016 | HP Office Equipment & Supplies
How do I print wirelessly from my Samsung Note 3 to my HP printer?
Go to the Google Market and download an apps called HP All-in-One Remote and install it in your Samsung Note 3.
Then while your Note 3 and HP Officejet were in the same wi-fi network, your Note 3 should be able to detect the HP printer. Then you could select which documents to print and whether B/W or color.
Jul 26, 2014 | HP Officejet Pro 8500A Wireless All-in-One...
Hp 8500a has new print heads and new ink and now cyan has stopped printing
Hi I have two split pipes in my Hp 8500A printer where can I get replacement parts as it is not printing correctly.
Feb 08, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    I am looking to get a uaer guide fo my hp oj pro 8500a printer
    Here's the download website for the UserGuide of your HP Officejet Pro 8500.
    Click here: HPPro8500
    Hope this solves your problem,
    Good Luck!
    Mar 17, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    How do you print labels on a HP Office Jet Pro 8500A Plus and align the labes on the sheet???
    Depending which publisher you use look for mailings or envelopes it all in there.
    Good luck
    Peter.
    Mar 07, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    Need HP officejet pro 8500 Service Manual
    You can find one here: http://downloadfreemanuals.com/officejet-pro-8500a-manual/
    Jan 20, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    Failure of alignment of printheads on setup of HP 8500A
    when feeder is used for scan, fax or copy, a black vertical line appears on the left side of page
    Jan 11, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    HP Officejet Pro 8500a Plus All-in-one Inkjet Printer W/brand Color Ink Logo
    185 people viewed this question
    Seeker5211
    Seeker5211
