Question about GE JBP90 Electric Kitchen Range
Oven touchpad doesn't work
Our oven touchpad doesn't work -- the CLEAR/OFF button beeps, but nothing else does even that. The stovetop works just fine. If I persist in trying to get the buttons to work, eventually I get an F1 code and a steady tone until I turn off the breaker. Sometimes, it will come back to life if I turn off the breaker and leave it off for a while before turning it back on, but now that doesn't even work. We've had it apart, and there's no sign of any damage to the circuit boards -- no burns, etc. -- and no obvious loose connections. If the touchpad module has to be replaced, do you know how much it would cost? In other words, would it be worth fixing a 13-year-old stove, or should we just replace it? Many thanks!
    Problem Solver:
  • 15 Answers
Sometimes it may just be a build up grease and dirt on the pad over a period of time.try taking it apart as much as possible and cleaning it with some type of spirits and the clean with some eucalyptus oil as both of these have capabilities of breaking down oils and fat.
Posted on Jul 19, 2007
SOURCE:
Maytag electric range model# MERH752CAS oven and stovetop stopped working.
Check the breakers. The range runs on 220v and one of the breakers may have tripped and it is running on 110v. Post back the results.
Feb 10, 2013 | Kitchen Ranges
The General Electric under the counter oven is beeping and only stops when I push the Clear/Off button. Then it resumes beeping 1-2 minutes later. Also "F7" appears to the left of the time...
The F7 error code means that a key on the touchpad has shorted and the touchpad needs to be replaced... sometimes it's a electronic anaomily, since you have pushed Clear/off and the F7 returns it surly means that touchpad is bad.
GENE
Sep 09, 2011 | General Electric Ovens
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
F7 Error code while cleaning stovetop
Usually a stuck keypad. Try pushing all buttons at random several times each including cancel. If that does not correct it this time you will need a new touchpad and ERC.
May 03, 2009 | Ovens
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Touchpad doesn't work, F1 code
Most likley you have a bad touchpad. Most times its a key that is stuck and there is nothing much you can do except replace the touchpad control. It is a common problem with all electronic ranges. If the range is 13 years old I would thik about replaceing it. Good luck
Jul 15, 2007 | GE JBP90 Electric Kitchen Range
GE JBP90 Electric Kitchen Range Logo
191 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
