Question about Hotpoint Dryers
Tripping electricity working normally without heat
  • 108 Answers
Just a surgestion check heater element not catching case or anything caught in it causing short
Posted on Mar 18, 2014
I have an electric furnace, it worked fine since it was last repaired, had a bad heat sequencer in it.. but now (3weeks later), it is tripping the 30 amp breaker after a few min of operation ????,...
I ran across a similar problem with electric furnaces years ago. One of the heating elements had failed and the coil was actually making contact with the frame in which it was held. This may be the problem but must be checked with the power off as the chassis may be live. Something is definitely amiss if your unit is tripping a 30 amp breaker and probably will show up on a utility bill next month.
Feb 17, 2011 | Heating & Cooling
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Feb 15, 2010 | Candy F248P Electric Single Oven
My scb2001kss ge advantium no longer heats. it turns on and everything else works, but heat
check breakers for oven one side could of tripped if everything else works but the heat this is a normal problem the only other thing could be is that the controles are not working
Jan 26, 2010 | GE Profile Advantium SCB2001KSS Stainless...
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Ariston Oven power trip
Take off the back cover and check whether the terminals on the heating element are touching it. Normally caused by some earth leakage currents flowing from heating element to ground circuit.
Mar 01, 2009 | Ariston Technologies Ariston FO98P...
Smeg SNZ91MFX1 Fan heating not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Dishwasher trips RCD electrics
fault is probably heating element but you need a megga to test it. other disconnect element, tape up wires then check on wash cycle. be carefull!!
Mar 20, 2007 | Electrolux 23 in. ESL624 Built-in...
Dryers Logo
29 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
