Question about HP LaserJet 4M Printer
Printer is offline My printer is off line----how do I get it back on line? When I open the control panel and look at my printers, it states that the laserjet 4M is off line. However, the printer itself indicates that it is online. The printer has stopped printing. I am using a cable that is a parallel from the printer but is converted to be used as a usb. I have used the printer before and it has worked fine. I recently moved and had to take down my computer. After I reconnected everything, the printer stopped working.
  • sgrimmett Jan 27, 2009
    The above suggestions does not help. Could someone send me another solution.
  • 101 Answers
Go back to your printer setting and right click on that printer and make sure it is set to default. then if you have multiple printers make sure their is not on default as well
Posted on Jan 26, 2009
Keeps telling me it is off line-how can I correct it so I can print
First check on the device and printer under control panel if the status of your printer is offline or ready. If it is offline check your usb cable if properly connected and if ready state then if you send print job set to offline try to reinstall the driver. hopefully it will help you.
May 13, 2015 | Brother Fax-2840 High Speed Mono Laser Fax
My cannon mx420 says it is offline and won't print. Yes it is pluggled in. This happened before and I found help onlin. I can't remember how to fix it.
Open up your control panel. Go the devices/printers category. Your printer should show up in there. Right click on the printer icon and there should be a drop down menu that allows you to put it back on line.
Nov 24, 2013 | Off-Line Contact Cleaners - off line...
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
Hp deskje d2360 printer showing offline error
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
It states that the printer is offline. i have this machine for my company so how am i able to put it back online?
If you are getting an error message that states USER INTERVENTION REQUIRED or USE PRINTER OFFLINE, the printer driver may have become disabled. Please follow the directions below to resolve this issue.
Please note that the printer must be in an online state/Print mode.
WINDOWS 95/98/ME/NT/2000
1. Click on START, SETTINGS, and PRINTERS.
2. Highlight the icon of your printer with a single click.
3. Click on FILE.
4. The only check mark showing should be beside SET AS DEFAULT.
5. Ensure that there is no check mark beside PAUSE PRINTING or USE PRINTER OFFLINE.
6. Simply click on the check marks to remove it.
7. Try printing.
WINDOWS XP
1. (a. Click START select CONTROL PANEL and click on PRINTERS AND FAXES.
NOTE: If you cannot locate PRINTERS AND FAXES, Follow 1(b..
1. (b. Click START select CONTROL PANEL double click PRINTERS AND OTHER HARDWARE, and click on VIEW INSTALLED PRINTERS AND FAXES.
3. Click on FILE.
7. Try printing.
Jan 13, 2011 | Kyocera Mita KM-5035 Printer
PRINTER "OFFLINE" FROM PC CONTROL PANEL, PRINTER SCREEN READY
Make sure you have the ethernet cable plugged into the printer/network and is working properly. The toner replacement doesn't affect the network functions of the printer
Aug 06, 2009 | Dell 3100cn Laser Printer
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother 640 printer says it is offline
Check the front control panel, and there should be a button that is labeled 'on line' or similar. Press it to bring the printer to an on line state.
Sep 01, 2008 | Brother MFC-640CW All-In-One InkJet...
My printer says it is offline and now it wont print
perform the steps below if the Operating System is XP
Step 1:
Determine if the printer is paused or offline :
1.Open the printers folder, if necessary.
a.Click the Start icon.
b.Click Control Panel.
c.Click Hardware & Sounds.
NOTE: This step is not required when using Classic view in Windows Vista.
d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2:
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Nov 28, 2007 | HP DeskJet 340 InkJet Printer
HP LaserJet 4M Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
