Question about Creda C362E Electric Kitchen Range
My creda oven c362e over heats evan at 100
Yorkshire pudding burn after 5 min evan on 100
    Top Expert:
  • Creda Master
  • 9,472 Answers
Replace the oven sensor.
Posted on Jan 19, 2013
4 Suggested Answers
SOURCE: creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Posted on Sep 06, 2008
  • 57 Answers
SOURCE: CREDA OVEN FAN NOT WORKING OVEN BARELY HEATING
As a first port of call, you can remove the fan by removing the inner back panel (4 screws) and taking the fan blade off (anti clockwise screw) The drop the fan out through the back of the cooker. If you apply WD40 to the two bearings you may get the fan going again. Otherwise you'll have to replace it.
Posted on Dec 11, 2009
heatman101
  • 43501 Answers
SOURCE: Self cleaning mode
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 20, 2010
Self cleaning mode
heatman101
Apr 20, 2010 | Creda C362E Electric Kitchen Range
I have a creda collection C362E everything seems to work except the main oven, any ideas?
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 14, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
CAN I CONNECT A CREDA 2000W PLINTH HEATER USEING A FUSED PLUG?CREDA 2000W PLINTH FAN HEATER
Yes ,you can and fuse at 13amp.
Although the correct way would be to terminate the plinth heater in a switched fused spur or an unswitched fused spur fused at 13 amp
This can either replace a single or double socket or it can be taken of the socket by using 2.5mm2 twin and earth cable.
All parts availiable from hardware store or electrical retailer
Oct 06, 2009 | Creda C362E Electric Kitchen Range
Creda grill will not switch to oven when i shut the door
Model Number TGF334BCWF Gas Stove.....When I turn the burner on the top front right my oven is coming on without me turning the on. What is going on?
Feb 21, 2009 | Creda C362E Electric Kitchen Range
Not heating up
If fan is working o/k , then you need to replace the heater element.
This is located behind a removable panel at the rear of the oven compartment,
Undo screws and remove element .disconnect leads, be careful not to lose them inside, fit new element, fit cover back.
Plz rate this solution.
Tthanks, and merry exmas.
Nov 16, 2008 | Creda C362E Electric Kitchen Range
I have a creda c362e double oven cooker and the main oven does not heat up at all the grill, top oven and hob all still work
Depends on how handy you are with a screwdriver as to whether you want to repair yourself, although it is really basic. First turn off at the wall and remove the shelves from the bottom oven. The rear wall of the oven is held in place by 4 screws and one light cover and the heater element is behind this. Unscrew at the top, unclip from the bottom and remove the wires attached to the back. Test with a circuit tester but does sound like its no longer working. Very easy to order off the net for around £10 if you search for c362e element. Refitting is just a reversal of this. If you are not confident with electrics or if its still under warranty... get out an engineer.
Sep 13, 2008 | Hotpoint Kitchen Ranges
Old Creda double oven keeps runing when switch off
sounds simple but look at the knob to see if it is cracked and hence not turning the shaft
Jun 22, 2008 | Creda C362E Electric Kitchen Range
Creda cooker not working properly
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Creda C362E Electric Kitchen Range Logo
133 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
